[petsc-users] Segmentation faults: Derived types
Santiago Ospina De Los Rios
sospinar at unal.edu.co
Mon Aug 1 15:41:59 CDT 2016
Hello there,
I'm having problems defining some variables into derived types in Fortran.
Before, I had a similar problems with an allocatable array "PetsInt" but I
solved it just doing a non-collective Petsc Vec. Today I'm having troubles
with "PetscBool" or "Logical":
In a module which define the variables, I have the following:
MODULE ANISOFLOW_Types
> IMPLICIT NONE
> #include <petsc/finclude/petscsys.h>
> #include <petsc/finclude/petscvec.h>
> TYPE ConductivityField
> PetscBool ::
> DefinedByCvtZones=.FALSE. ! It produces the segmentation fault.
> PetscBool ::
> DefinedByPptZones=.FALSE. ! It produces the segmentation fault.
> PetscBool :: DefinedByCell=.FALSE.
> ! Conductivity defined by zones (Local):
> Vec :: ZoneID
> TYPE(Tensor),ALLOCATABLE :: Zone(:)
> ! Conductivity defined on every cell (Local):
> Vec :: Cell
> END TYPE ConductivityField
> TYPE SpecificStorageField
> PetscBool ::
> DefinedByStoZones=.FALSE. ! It produces the segmentation fault.
> PetscBool ::
> ! Specific Storage defined by zones (Local):
> Vec :: ZoneID
> Vec :: Zone
> ! Specific Storage defined on every cell (Global).:
> Vec :: Cell
> END TYPE SpecificStorageField
> TYPE PropertiesField
> TYPE(ConductivityField) :: Cvt
> TYPE(SpecificStorageField) :: Sto
> ! Property defined by zones (Local):
> PetscBool :: DefinedByPptZones=.FALSE.
> Vec :: ZoneID
> END TYPE PropertiesField
> CONTAINS
> END MODULE ANISOFLOW_Types
Later I use it in the main program, with something like this
PROGRAM ANISOFLOW
> USE ANISOFLOW_Types, ONLY : ... ,PropertiesField, ...
> IMPLICIT NONE
> TYPE(PropertiesField) :: PptFld
> CALL PetscInitialize(PETSC_COMM_WORLD,ierr)
> CALL PetscFinalize(ierr)
> END PROGRAM
When I run the program appears a Segmentation Fault, which disappears when
I comment the booleans marked in the code. Because I need them, I used
Valgrind to figure out what is happening but it is yet a mistery to me.
Valgrind message:
> ==5160==
> ==5160== Invalid read of size 1
> ==5160== at 0x4FB2156: petscinitialize_ (zstart.c:433)
> ==5160== by 0x4030EA: MAIN__ (ANISOFLOW.F90:29) # line of petsc
> inizalitation
> ==5160== by 0x404380: main (ANISOFLOW.F90:3) # line of "USE
> ANISOFLOW_Types, ONLY : ... ,PropertiesField, ..."
> ==5160== Address 0xc54fff is not stack'd, malloc'd or (recently) free'd
> ==5160==
> Program received signal SIGSEGV: Segmentation fault - invalid memory
> reference.
> Backtrace for this error:
> #0 0x699E777
> #1 0x699ED7E
> #2 0x6F0BCAF
> #3 0x4FB2156
> #4 0x4030EA in anisoflow at ANISOFLOW.F90:29
I think it is maybe related with petsc because the error popped out just in
its initialization, so if you know what's going on, I would appreciate to
tell me.
Santiago Ospina
Att:
Santiago Ospina De Los Ríos
National University of Colombia
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/cb8631af/attachment.html>
