[petsc-users] block matrix without MatCreateNest
Matthew Knepley
knepley at gmail.com
Mon Aug 1 17:28:33 CDT 2016
On Mon, Aug 1, 2016 at 9:36 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Matt,
> 1) great!
> 2) ??? that's precisely why I paste the output of "cat mattry.F90" in
> the emails, so you have a small example that produces the errors I mention.
> Now I'm also attaching it to this email.
Okay, I have gone through it. You are correct that it is completely broken.
The way that MatNest currently works is that it trys to use L2G mappings
from individual blocks
and then builds a composite L2G map for the whole matrix. This is obviously
incompatible with
the primary use case, and should be changed to break up the full L2G into
one for each block.
Jed, can you fix this? I am not sure I know enough about how Nest works.
Matt
> Thanks,
> Chris
> dr. ir. Christiaan Klaij | CFD Researcher | Research & Development
> MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl | www.marin.nl
> [image: LinkedIn] <https://www.linkedin.com/company/marin> [image:
> YouTube] <http://www.youtube.com/marinmultimedia> [image: Twitter]
> <https://twitter.com/MARIN_nieuws> [image: Facebook]
> <https://www.facebook.com/marin.wageningen>
> MARIN news: Vice Admiraal De Waard maakt virtuele proefvaart op MARIN’s
> FSSS (Dutch only)
> <http://www.marin.nl/web/News/News-items/Vice-Admiraal-De-Waard-maakt-virtuele-proefvaart-op-MARINs-FSSS-Dutch-only.htm>
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Monday, August 01, 2016 4:15 PM
> *To:* Klaij, Christiaan
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] block matrix without MatCreateNest
> On Mon, Aug 1, 2016 at 8:59 AM, Klaij, Christiaan <C.Klaij at marin.nl>
> wrote:
>> Matt,
>> Thanks for your suggestions. Here's the outcome:
>> 1) without the "if type=nest" protection, I get a "Cannot
>> locate function MatNestSetSubMats_C" error when using
>> type mpiaij, see below.
> That is a bug. It should be using PetscTryMethod() there, not
> PetscUseMethod(). We will fix it. That way
> it can be called for any matrix type, which is the intention.
>> 2) with the isg in a proper array, I get the same "Invalid
>> Pointer to Object" error, see below.
> Can you send a small example that we can run? It obviously should work
> this way.
> Thanks,
> Matt
>> Chris
>> $ cat mattry.F90
>> program mattry
>> use petscksp
>> implicit none
>> #include <petsc/finclude/petsckspdef.h>
>> PetscInt :: n=4 ! setting 4 cells per process
>> PetscErrorCode :: ierr
>> PetscInt :: size,rank,i
>> Mat :: A,A02
>> MatType :: type
>> IS :: isg(3)
>> IS :: isl(3)
>> ISLocalToGlobalMapping :: map
>> integer, allocatable, dimension(:) :: idx
>> call PetscInitialize(PETSC_NULL_CHARACTER,ierr); CHKERRQ(ierr)
>> call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr); CHKERRQ(ierr)
>> call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr);CHKERRQ(ierr)
>> ! local index sets for 3 fields
>> allocate(idx(n))
>> idx=(/ (i-1, i=1,n) /)
>> call
>> ISCreateGeneral(PETSC_COMM_WORLD,n,idx,PETSC_COPY_VALUES,isl(1),ierr);CHKERRQ(ierr)
>> call
>> ISCreateGeneral(PETSC_COMM_WORLD,n,idx+n,PETSC_COPY_VALUES,isl(2),ierr);CHKERRQ(ierr)
>> call
>> ISCreateGeneral(PETSC_COMM_WORLD,n,idx+2*n,PETSC_COPY_VALUES,isl(3),ierr);CHKERRQ(ierr)
>> ! call ISView(isl3,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
>> deallocate(idx)
>> ! global index sets for 3 fields
>> allocate(idx(n))
>> idx=(/ (i-1+rank*3*n, i=1,n) /)
>> call
>> ISCreateGeneral(PETSC_COMM_WORLD,n,idx,PETSC_COPY_VALUES,isg(1),ierr);CHKERRQ(ierr)
>> call
>> ISCreateGeneral(PETSC_COMM_WORLD,n,idx+n,PETSC_COPY_VALUES,isg(2),ierr);
>> CHKERRQ(ierr)
>> call
>> ISCreateGeneral(PETSC_COMM_WORLD,n,idx+2*n,PETSC_COPY_VALUES,isg(3),ierr);
>> CHKERRQ(ierr)
>> ! call ISView(isg3,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
>> deallocate(idx)
>> ! local-to-global mapping
>> allocate(idx(3*n))
>> idx=(/ (i-1+rank*3*n, i=1,3*n) /)
>> call
>> ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD,1,3*n,idx,PETSC_COPY_VALUES,map,ierr);
>> CHKERRQ(ierr)
>> ! call ISLocalToGlobalMappingView(map,PETSC_VIEWER_STDOUT_WORLD,ierr);
>> CHKERRQ(ierr)
>> deallocate(idx)
>> ! create the 3-by-3 block matrix
>> call MatCreate(PETSC_COMM_WORLD,A,ierr); CHKERRQ(ierr)
>> call MatSetSizes(A,3*n,3*n,PETSC_DECIDE,PETSC_DECIDE,ierr);
>> CHKERRQ(ierr)
>> call MatSetUp(A,ierr); CHKERRQ(ierr)
>> call MatSetOptionsPrefix(A,"A_",ierr); CHKERRQ(ierr)
>> call MatSetLocalToGlobalMapping(A,map,map,ierr); CHKERRQ(ierr)
>> call MatSetFromOptions(A,ierr); CHKERRQ(ierr)
>> ! setup nest
>> call MatNestSetSubMats(A,3,isg,3,isg,PETSC_NULL_OBJECT,ierr);
>> CHKERRQ(ierr)
>> ! set diagonal of block A02 to 0.65
>> call MatGetLocalSubmatrix(A,isl(1),isl(3),A02,ierr); CHKERRQ(ierr)
>> do i=1,n
>> call MatSetValuesLocal(A02,1,i-1,1,i-1,0.65d0,INSERT_VALUES,ierr);
>> CHKERRQ(ierr)
>> end do
>> call MatRestoreLocalSubMatrix(A,isl(1),isl(3),A02,ierr); CHKERRQ(ierr)
>> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr); CHKERRQ(ierr)
>> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr); CHKERRQ(ierr)
>> ! verify
>> call MatGetSubmatrix(A,isg(1),isg(3),MAT_INITIAL_MATRIX,A02,ierr);
>> CHKERRQ(ierr)
>> call MatView(A02,PETSC_VIEWER_STDOUT_WORLD,ierr);CHKERRQ(ierr)
>> call PetscFinalize(ierr)
>> end program mattry
>> $ mpiexec -n 2 ./mattry -A_mat_type mpiaij
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: No support for this operation for this object type
>> [0]PETSC ERROR: Cannot locate function MatNestSetSubMats_C in object
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
>> [0]PETSC ERROR: ./mattry
>> on a linux_64bit_debug
>> named lin0322.marin.local by cklaij Mon Aug 1 15:42:10 2016
>> [0]PETSC ERROR: Configure options
>> --with-mpi-dir=/home/cklaij/ReFRESCO/Dev/trunk/Libs/install/openmpi/1.8.7
>> --with-clanguage=c++ --with-x=1 --with-debugging=1
>> --with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl
>> --with-shared-libraries=0
>> [0]PETSC ERROR: #1 MatNestSetSubMats() line 1105 in
>> /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 56.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> [1]PETSC ERROR:
>> [1]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>> batch system) has told this process to end
>> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [1]PETSC ERROR: or see
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
>> X to find memory corruption errors
>> [1]PETSC ERROR: likely location of problem given in stack below
>> [1]PETSC ERROR: --------------------- Stack Frames
>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>> available,
>> [1]PETSC ERROR: INSTEAD the line number of the start of the function
>> [1]PETSC ERROR: is given.
>> [1]PETSC ERROR: [1] PetscSleep line 35
>> /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/sys/utils/psleep.c
>> [1]PETSC ERROR: [1] PetscTraceBackErrorHandler line 193
>> /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/sys/error/errtrace.c
>> [1]PETSC ERROR: [1] PetscError line 364
>> /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/sys/error/err.c
>> [1]PETSC ERROR: [1] MatNestSetSubMats line 1092
>> [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Signal received
>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> [1]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
>> [1]PETSC ERROR: ./mattry
>> [1]PETSC ERROR: Configure options
>> [1]PETSC ERROR: #1 User provided function() line 0 in unknown file
>> [lin0322.marin.local:19455] 1 more process has sent help message
>> help-mpi-api.txt / mpi-abort
>> [lin0322.marin.local:19455] Set MCA parameter "orte_base_help_aggregate"
>> to 0 to see all help / error messages
>> $ mpiexec -n 2 ./mattry -A_mat_type nest
>> [0]PETSC ERROR: Corrupt argument:
>> [0]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
>> [1]PETSC ERROR: Corrupt argument:
>> [1]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
>> named lin0322.marin.local by cklaij Mon Aug 1 15:42:25 2016
>> [1]PETSC ERROR: #1 PetscObjectReference() line 534 in
>> /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/sys/objects/inherit.c
>> [1]PETSC ERROR: #2 MatNestSetSubMats_Nest() line 1042 in
>> [1]PETSC ERROR: #3 MatNestSetSubMats() line 1105 in
>> [0]PETSC ERROR: #1 PetscObjectReference() line 534 in
>> [0]PETSC ERROR: #2 MatNestSetSubMats_Nest() line 1042 in
>> [0]PETSC ERROR: #3 MatNestSetSubMats() line 1105 in
>> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
>> with errorcode 64.
>> [lin0322.marin.local:19465] 1 more process has sent help message
>> [lin0322.marin.local:19465] Set MCA parameter "orte_base_help_aggregate"
>> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl |
>> http://www.marin.nl
>> MARIN news:
>> http://www.marin.nl/web/News/News-items/Ship-design-in-EU-project-Holiship.htm
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/51fd5aee/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/51fd5aee/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/51fd5aee/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/51fd5aee/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/51fd5aee/attachment-0007.png>
