[petsc-users] block matrix without MatCreateNest
Mon Aug 1 08:09:11 CDT 2016
On Mon, Aug 1, 2016 at 3:00 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Matt, Barry
> Thanks for your replies! I've added a call to MatNestSetSubMats()
> but something's still wrong, see below.
> Chris
> $ cat mattry.F90
> program mattry
>   use petscksp
>   implicit none
> #include <petsc/finclude/petsckspdef.h>
>   PetscInt :: n=4   ! setting 4 cells per process
>   PetscErrorCode         :: ierr
>   PetscInt               :: size,rank,i
>   Mat                    :: A,A02
>   MatType                :: type
>   IS                     :: isg0,isg1,isg2
>   IS                     :: isl0,isl1,isl2
>   ISLocalToGlobalMapping :: map
>   integer, allocatable, dimension(:) :: idx
>   call PetscInitialize(PETSC_NULL_CHARACTER,ierr); CHKERRQ(ierr)
>   call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr); CHKERRQ(ierr)
>   call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr);CHKERRQ(ierr)
>   ! local index sets for 3 fields
>   allocate(idx(n))
>   idx=(/ (i-1, i=1,n) /)
>   call
> ISCreateGeneral(PETSC_COMM_WORLD,n,idx,PETSC_COPY_VALUES,isl0,ierr);CHKERRQ(ierr)
>   call
> ISCreateGeneral(PETSC_COMM_WORLD,n,idx+n,PETSC_COPY_VALUES,isl1,ierr);CHKERRQ(ierr)
>   call
> ISCreateGeneral(PETSC_COMM_WORLD,n,idx+2*n,PETSC_COPY_VALUES,isl2,ierr);CHKERRQ(ierr)
> !  call ISView(isl3,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
>   deallocate(idx)
>   ! global index sets for 3 fields
>   allocate(idx(n))
>   idx=(/ (i-1+rank*3*n, i=1,n) /)
>   call
> ISCreateGeneral(PETSC_COMM_WORLD,n,idx,PETSC_COPY_VALUES,isg0,ierr);CHKERRQ(ierr)
>   call
> ISCreateGeneral(PETSC_COMM_WORLD,n,idx+n,PETSC_COPY_VALUES,isg1,ierr);
> CHKERRQ(ierr)
>   call
> ISCreateGeneral(PETSC_COMM_WORLD,n,idx+2*n,PETSC_COPY_VALUES,isg2,ierr);
> CHKERRQ(ierr)
> !  call ISView(isg3,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
>   deallocate(idx)
>   ! local-to-global mapping
>   allocate(idx(3*n))
>   idx=(/ (i-1+rank*3*n, i=1,3*n) /)
>   call
> ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD,1,3*n,idx,PETSC_COPY_VALUES,map,ierr);
> CHKERRQ(ierr)
> !  call ISLocalToGlobalMappingView(map,PETSC_VIEWER_STDOUT_WORLD,ierr);
> CHKERRQ(ierr)
>   deallocate(idx)
>   ! create the 3-by-3 block matrix
>   call MatCreate(PETSC_COMM_WORLD,A,ierr); CHKERRQ(ierr)
>   call MatSetSizes(A,3*n,3*n,PETSC_DECIDE,PETSC_DECIDE,ierr); CHKERRQ(ierr)
>   call MatSetUp(A,ierr); CHKERRQ(ierr)
>   call MatSetOptionsPrefix(A,"A_",ierr); CHKERRQ(ierr)
>   call MatSetLocalToGlobalMapping(A,map,map,ierr); CHKERRQ(ierr)
>   call MatSetFromOptions(A,ierr); CHKERRQ(ierr)
>   ! setup nest
>   call MatGetType(A,type,ierr); CHKERRQ(ierr)
>   if (type.eq."nest") then
1) Get rid of this protection, you do not need it.
2) It looks like the (/ /) notation does not work here. Can you put them in
proper array?
     Matt
>      call
> MatNestSetSubMats(A,3,(/isg0,isg1,isg2/),3,(/isg0,isg1,isg2/),PETSC_NULL_OBJECT,ierr);
> CHKERRQ(ierr)
>   end if
>   ! set diagonal of block A02 to 0.65
>   call MatGetLocalSubmatrix(A,isl0,isl2,A02,ierr); CHKERRQ(ierr)
>   do i=1,n
>      call MatSetValuesLocal(A02,1,i-1,1,i-1,0.65d0,INSERT_VALUES,ierr);
> CHKERRQ(ierr)
>   end do
>   call MatRestoreLocalSubMatrix(A,isl0,isl2,A02,ierr); CHKERRQ(ierr)
>   call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr); CHKERRQ(ierr)
>   call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr); CHKERRQ(ierr)
>   ! verify
>   call MatGetSubmatrix(A,isg0,isg2,MAT_INITIAL_MATRIX,A02,ierr);
> CHKERRQ(ierr)
>   call MatView(A02,PETSC_VIEWER_STDOUT_WORLD,ierr);CHKERRQ(ierr)
>   call PetscFinalize(ierr)
> end program mattry
> $ mpiexec -n 2 ./mattry -A_mat_type nest
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Corrupt argument:
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
> [0]PETSC ERROR:
> ./mattry
>       on a linux_64bit_debug named lin0322.marin.local by cklaij Mon Aug  1
> 09:54:07 2016
> [0]PETSC ERROR: Configure options
> --with-mpi-dir=/home/cklaij/ReFRESCO/Dev/trunk/Libs/install/openmpi/1.8.7
> --with-clanguage=c++ --with-x=1 --with-debugging=1
> --with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl
> --with-shared-libraries=0
> [0]PETSC ERROR: #1 PetscObjectReference() line 534 in
> /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/sys/objects/inherit.c
> [0]PETSC ERROR: #2 MatNestSetSubMats_Nest() line 1042 in
> /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
> [0]PETSC ERROR: #3 MatNestSetSubMats() line 1105 in
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Corrupt argument:
> [1]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [1]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
> [1]PETSC ERROR:
> ./mattry
> 09:54:07 2016
> [1]PETSC ERROR: Configure options
> [1]PETSC ERROR: #1 PetscObjectReference() line 534 in
> [1]PETSC ERROR: #2 MatNestSetSubMats_Nest() line 1042 in
> [1]PETSC ERROR: #3 MatNestSetSubMats() line 1105 in
> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
> with errorcode 64.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> [lin0322.marin.local:14326] 1 more process has sent help message
> help-mpi-api.txt / mpi-abort
> [lin0322.marin.local:14326] Set MCA parameter "orte_base_help_aggregate"
> to 0 to see all help / error messages
> dr. ir. Christiaan Klaij | CFD Researcher | Research & Development
> MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl | www.marin.nl
> [image: LinkedIn] <https://www.linkedin.com/company/marin> [image:
> YouTube] <http://www.youtube.com/marinmultimedia> [image: Twitter]
> <https://twitter.com/MARIN_nieuws> [image: Facebook]
> <https://www.facebook.com/marin.wageningen>
> MARIN news: Joint Industry Project LifeLine kicks off
> <http://www.marin.nl/web/News/News-items/Joint-Industry-Project-LifeLine-kicks-off.htm>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/4a2263e0/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/4a2263e0/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/4a2263e0/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/4a2263e0/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/4a2263e0/attachment-0003.png>
