[petsc-users] block matrix without MatCreateNest
Klaij, Christiaan C.Klaij at marin.nl
Mon Aug 1 03:00:02 CDT 2016
Matt, Barry
Thanks for your replies! I've added a call to MatNestSetSubMats()
but something's still wrong, see below.
Chris
$ cat mattry.F90
program mattry
  use petscksp
  implicit none
#include <petsc/finclude/petsckspdef.h>
  PetscInt :: n=4   ! setting 4 cells per process
  PetscErrorCode         :: ierr
  PetscInt               :: size,rank,i
  Mat                    :: A,A02
  MatType                :: type
  IS                     :: isg0,isg1,isg2
  IS                     :: isl0,isl1,isl2
  ISLocalToGlobalMapping :: map
  integer, allocatable, dimension(:) :: idx
  call PetscInitialize(PETSC_NULL_CHARACTER,ierr); CHKERRQ(ierr)
  call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr); CHKERRQ(ierr)
  call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr);CHKERRQ(ierr)
  ! local index sets for 3 fields
  allocate(idx(n))
  idx=(/ (i-1, i=1,n) /)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx,PETSC_COPY_VALUES,isl0,ierr);CHKERRQ(ierr)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx+n,PETSC_COPY_VALUES,isl1,ierr);CHKERRQ(ierr)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx+2*n,PETSC_COPY_VALUES,isl2,ierr);CHKERRQ(ierr)
!  call ISView(isl3,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
  deallocate(idx)
  ! global index sets for 3 fields
  allocate(idx(n))
  idx=(/ (i-1+rank*3*n, i=1,n) /)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx,PETSC_COPY_VALUES,isg0,ierr);CHKERRQ(ierr)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx+n,PETSC_COPY_VALUES,isg1,ierr); CHKERRQ(ierr)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx+2*n,PETSC_COPY_VALUES,isg2,ierr); CHKERRQ(ierr)
!  call ISView(isg3,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
  deallocate(idx)
  ! local-to-global mapping
  allocate(idx(3*n))
  idx=(/ (i-1+rank*3*n, i=1,3*n) /)
  call ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD,1,3*n,idx,PETSC_COPY_VALUES,map,ierr); CHKERRQ(ierr)
!  call ISLocalToGlobalMappingView(map,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
  deallocate(idx)
  ! create the 3-by-3 block matrix
  call MatCreate(PETSC_COMM_WORLD,A,ierr); CHKERRQ(ierr)
  call MatSetSizes(A,3*n,3*n,PETSC_DECIDE,PETSC_DECIDE,ierr); CHKERRQ(ierr)
  call MatSetUp(A,ierr); CHKERRQ(ierr)
  call MatSetOptionsPrefix(A,"A_",ierr); CHKERRQ(ierr)
  call MatSetLocalToGlobalMapping(A,map,map,ierr); CHKERRQ(ierr)
  call MatSetFromOptions(A,ierr); CHKERRQ(ierr)
  ! setup nest
  call MatGetType(A,type,ierr); CHKERRQ(ierr)
  if (type.eq."nest") then
     call MatNestSetSubMats(A,3,(/isg0,isg1,isg2/),3,(/isg0,isg1,isg2/),PETSC_NULL_OBJECT,ierr); CHKERRQ(ierr)
  end if
  ! set diagonal of block A02 to 0.65
  call MatGetLocalSubmatrix(A,isl0,isl2,A02,ierr); CHKERRQ(ierr)
  do i=1,n
     call MatSetValuesLocal(A02,1,i-1,1,i-1,0.65d0,INSERT_VALUES,ierr); CHKERRQ(ierr)
  end do
  call MatRestoreLocalSubMatrix(A,isl0,isl2,A02,ierr); CHKERRQ(ierr)
  call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr); CHKERRQ(ierr)
  call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr); CHKERRQ(ierr)
  ! verify
  call MatGetSubmatrix(A,isg0,isg2,MAT_INITIAL_MATRIX,A02,ierr); CHKERRQ(ierr)
  call MatView(A02,PETSC_VIEWER_STDOUT_WORLD,ierr);CHKERRQ(ierr)
  call PetscFinalize(ierr)
end program mattry
$ mpiexec -n 2 ./mattry -A_mat_type nest
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Corrupt argument: http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
[0]PETSC ERROR: ./mattry        on a linux_64bit_debug named lin0322.marin.local by cklaij Mon Aug  1 09:54:07 2016
[0]PETSC ERROR: Configure options --with-mpi-dir=/home/cklaij/ReFRESCO/Dev/trunk/Libs/install/openmpi/1.8.7 --with-clanguage=c++ --with-x=1 --with-debugging=1 --with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl --with-shared-libraries=0
[0]PETSC ERROR: #1 PetscObjectReference() line 534 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/sys/objects/inherit.c
[0]PETSC ERROR: #2 MatNestSetSubMats_Nest() line 1042 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
[0]PETSC ERROR: #3 MatNestSetSubMats() line 1105 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
[1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: Corrupt argument: http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[1]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
[1]PETSC ERROR: ./mattry        on a linux_64bit_debug named lin0322.marin.local by cklaij Mon Aug  1 09:54:07 2016
[1]PETSC ERROR: Configure options --with-mpi-dir=/home/cklaij/ReFRESCO/Dev/trunk/Libs/install/openmpi/1.8.7 --with-clanguage=c++ --with-x=1 --with-debugging=1 --with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl --with-shared-libraries=0
[1]PETSC ERROR: #1 PetscObjectReference() line 534 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/sys/objects/inherit.c
[1]PETSC ERROR: #2 MatNestSetSubMats_Nest() line 1042 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
[1]PETSC ERROR: #3 MatNestSetSubMats() line 1105 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 64.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[lin0322.marin.local:14326] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[lin0322.marin.local:14326] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
dr. ir. Christiaan Klaij | CFD Researcher | Research & Development
MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | www.marin.nl<http://www.marin.nl>
[LinkedIn]<https://www.linkedin.com/company/marin> [YouTube] <http://www.youtube.com/marinmultimedia>  [Twitter] <https://twitter.com/MARIN_nieuws>  [Facebook] <https://www.facebook.com/marin.wageningen>
MARIN news: Joint Industry Project LifeLine kicks off<http://www.marin.nl/web/News/News-items/Joint-Industry-Project-LifeLine-kicks-off.htm>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/936594e0/attachment-0001.html>
Type: image/png
Desc: image2bc716.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/936594e0/attachment-0004.png>
Type: image/png
Desc: imageaadb69.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/936594e0/attachment-0005.png>
Type: image/png
Desc: imagedd86d2.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/936594e0/attachment-0006.png>
Type: image/png
Desc: imaged1a140.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160801/936594e0/attachment-0007.png>
