[petsc-users] Insert values into matrix using MatSetValuesStencil
TAY wee-beng zonexo at gmail.com
Fri Sep 25 03:20:42 CDT 2015
Hi Timothée,
I got the error sorted out. I was inserting into the wrong matrix. But
the key error was the defn of row and col.
Thank you for pointing it out.
Yours sincerely,
TAY wee-beng
On 23/9/2015 5:25 PM, Timothée Nicolas wrote:
> Hum, sorry, I don't know. I asked you to provide the definitions of
> start and end values of i,j,k, because I was concerned whether you may
> mess up the boundaries. Especially because you seem to treat x
> differently from y and z. You have the problem also on only 1 process ?
> 2015-09-23 18:13 GMT+09:00 TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>>:
>     Hi Timothée,
>     Maybe I can send you part of it 1st. I'm trying to pinpoint why my
>     matrix using MatView shows zero for a lot of the values
>     For i=1,j=1,k=1,
>     It should be :
>     Mat Object: 1 MPI processes
>       type: seqaij
>     row 0: (0, 2)  (12, -2)
>     but now it's:
>     row 0: (0, 0)  (1, 0)  (2, 0)  (3, 0)  (4, 0)  (5, 0)  (6, 0)  (7,
>     0)  (8, 0)  (12, 0)  (13, 0)  (14, 0)  (24, 0) (25, 0)  (26, 0)
>     (96, 0)  (97, 0)  (98, 0)  (192, 0) (193, 0)  (194, 0)
>     I used:
>     /call
>     DMDACreate3d(MPI_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,size_x,size_y,&//
>     //size_z,1,PETSC_DECIDE,PETSC_DECIDE,3,stencil_width,lx,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da_uvw_ast,ierr)//
>     //call DMSetMatType(da_uvw_ast,MATAIJ,ierr)//
>     //    call DMCreateMatrix(da_uvw_ast,A_semi_xyz,ierr)//
>     //    call MatSetFromOptions(A_semi_xyz,ierr)//
>     //i = 1, j = 1, k = 1//
>     //row(MatStencil_i,1) = i - 1//
>     //                    row(MatStencil_j,1) = j - 1//
>     //                    row(MatStencil_k,1) = k - 1//
>     //                    row(MatStencil_c,1) = 0//
>     //                    col(MatStencil_i,1) = i - 1//
>     //                    col(MatStencil_j,1) = j - 1//
>     //                    col(MatStencil_k,1) = k - 1//
>     //                    col(MatStencil_c,1) = 0//
>     //                    value_insert(1) = 2.//
>     //                    call
>     MatSetValuesStencil(A_mat,ione,row,ione,col(:,1),value_insert(1),INSERT_VALUES,ierr)//
>     //                    col(MatStencil_i,2) = i - 1 !north//
>     //                    col(MatStencil_j,2) = j + 1 - 1//
>     //                    col(MatStencil_k,2) = k - 1//
>     //                    col(MatStencil_c,2) = 0//
>     //                    value_insert(2) = -2.//
>     //                    call
>     MatSetValuesStencil(A_mat,ione,row,ione,col(:,2),value_insert(2),INSERT_VALUES,ierr)/
>     Thank you
>     Yours sincerely,
>     TAY wee-beng
>     On 23/9/2015 4:45 PM, Timothée Nicolas wrote:
>>     Yes, I had understood that, I am doing the same, but with 8 dof.
>>     This does not change the declaration for row and col.
>>     Can you send (i) the commands you use to create the DMDA, (ii)
>>     the commands to create the matrix and (iii) those for the
>>     definitions of ksta2,kend2,jsta2,jend2,size_x ?
>>     Timothée
>>     2015-09-23 17:37 GMT+09:00 TAY wee-beng <zonexo at gmail.com
>>         Hi Timothée,
>>         The matrix is created with 3 dof - u,v,w. So for each i,j,k,
>>         there are 3 values. Actually I got 3 eqns from the u,v,w
>>         momentum eqns. They are not coupled together so I can also
>>         solve them individually. But I was told it's faster to group
>>         them together. The global indices is something like this:
>>         i, j, k, ijk global indices, dof
>>         1 1 1 1 u
>>         1 1 1 2 v
>>         1 1 1 3 w
>>         2 1 1 4 u
>>         Hope it's clearer now.
>>         Ok, I changed the stencil, it's now working.
>>         Thank you
>>         Yours sincerely,
>>         TAY wee-beng
>>         On 23/9/2015 4:22 PM, Timothée Nicolas wrote:
>>>         Can you also tell how you created the matrix ? Just in case
>>>         you created it with the 1 dof DMDA, it would not work if you
>>>         try to input values at places where it is not allocated
>>>         (which could explain the error message)
>>>         2015-09-23 17:18 GMT+09:00 Timothée Nicolas
>>>         <timothee.nicolas at gmail.com
>>>         <mailto:timothee.nicolas at gmail.com>>:
>>>             The first thing that strikes me is your definition of
>>>             the stencils
>>>             */MatStencil  :: row(6,1),col(6,7)/**/
>>>             Why is it not defined with
>>>             */MatStencil  :: row(4,1),col(4,7)/**/
>>>             instead ?
>>>             Where does the 6 come from ?
>>>             Timothée
>>>             2015-09-23 17:14 GMT+09:00 TAY wee-beng
>>>             <zonexo at gmail.com <mailto:zonexo at gmail.com>>:
>>>                 Hi,
>>>                 I have successfully used MatSetValuesStencil to
>>>                 insert values into a Poisson eqn matrix which has 1
>>>                 DOF (pressure). Now I'm trying to insert values in a
>>>                 momentum eqn matrix which has 3 DOF (u,v,w)
>>>                 However, I got the error:
>>>                 /*[0]PETSC ERROR: --------------------- Error
>>>                 Message ----------------------------*//*
>>>                 *//*[0]PETSC ERROR: Argument out of range*//*
>>>                 *//*[0]PETSC ERROR: Inserting a new nonzero at
>>>                 (111,5) in the matrix*//*
>>>                 *//*[0]PETSC ERROR: See
>>>                 http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>                 for trou*//*
>>>                 *//*ble shooting.*/
>>>                 I wonder what's wrong.  For the momentum eqn, for
>>>                 each DOF, at at node (dof,i,j,k), I have coupling i
>>>                 +/- 1, j +/- 1 and k +/- 1.
>>>                 The error happens at 111,5, which corresponds to i =
>>>                 2, j = 2, k = 2, which is an internal node.
>>>                 Here's part of my code below. Hope someone can help.
>>>                 Thanks!
>>>                 /**/PetscScalar :: value_insert(7)/**/
>>>                 /**/MatStencil :: row(6,1),col(6,7)/**/
>>>                 /**/ione = 1;   iseven = 7/**/
>>>                 /**/if (cell_type == 'u') then/**/
>>>                 /**/offset = 1/**/
>>>                 /**/else if (cell_type == 'v') then/**/
>>>                 /**/offset = 2/**/
>>>                 /**/else if (cell_type == 'w') then/**/
>>>                 /**/offset = 3/**/
>>>                 /**/end if/**/
>>>                 /**/do k=ksta2,kend2/**/
>>>                 /**/do j = jsta2,jend2/**/
>>>                 /**/    do i=2,size_x-1/**/
>>>                 /**/row(MatStencil_i,1) = i - 1/**/
>>>                 /**/row(MatStencil_j,1) = j - 1/**/
>>>                 /**/row(MatStencil_k,1) = k - 1/**/
>>>                 /**/row(MatStencil_c,1) = offset - 1/**/
>>>                 /**/value_insert = 0.d0/**/
>>>                 /**/col(MatStencil_i,3) = i + 1 - 1 !east/**/
>>>                 /**/col(MatStencil_j,3) = j - 1/**/
>>>                 /**/col(MatStencil_k,3) = k - 1/**/
>>>                 /**/col(MatStencil_c,3) = offset - 1/**/
>>>                 /**/value_insert(3) = -(
>>>                 1./(cell_x(i)%pd_E+cell_x(i+1)%pd_W))*(c_yz(j,k)%fc_E)*inv_Re/**/
>>>                 /**/col(MatStencil_i,5) = i - 1 - 1 !west/**/
>>>                 /**/col(MatStencil_j,5) = j - 1/**/
>>>                 /**/col(MatStencil_k,5) = k - 1/**/
>>>                 /**/col(MatStencil_c,5) = offset - 1/**/
>>>                 /**/value_insert(5) = -(
>>>                 1./(cell_x(i)%pd_W+cell_x(i-1)%pd_E))*(c_yz(j,k)%fc_E)*inv_Re/**/
>>>                 /**/col(MatStencil_i,2) = i - 1 !north/**/
>>>                 /**/col(MatStencil_j,2) = j + 1 - 1/**/
>>>                 /**/col(MatStencil_k,2) = k - 1/**/
>>>                 /**/col(MatStencil_c,2) = offset - 1/**/
>>>                 /**/value_insert(2) = -(
>>>                 1./(cell_y(j)%pd_N+cell_y(j+1)%pd_S))*(c_zx(i,k)%fc_N)*inv_Re/**/
>>>                 /**/col(MatStencil_i,4) = i - 1 !south/**/
>>>                 /**/col(MatStencil_j,4) = j - 1 - 1/**/
>>>                 /**/col(MatStencil_k,4) = k - 1/**/
>>>                 /**/col(MatStencil_c,4) = offset - 1/**/
>>>                 /**/value_insert(4) = -(
>>>                 1./(cell_y(j)%pd_S+cell_y(j-1)%pd_N))*(c_zx(i,k)%fc_N)*inv_Re/**/
>>>                 /**/col(MatStencil_i,6) = i - 1 !front/**/
>>>                 /**/col(MatStencil_j,6) = j - 1/**/
>>>                 /**/col(MatStencil_k,6) = k + 1 - 1/**/
>>>                 /**/col(MatStencil_c,6) = offset - 1/**/
>>>                 /**/value_insert(6) = -(
>>>                 1./(cell_z(k)%pd_F+cell_z(k+1)%pd_B))*(c_xy(i,j)%fc_F)*inv_Re/**/
>>>                 /**/col(MatStencil_i,7) = i - 1 !back/**/
>>>                 /**/col(MatStencil_j,7) = j - 1/**/
>>>                 /**/col(MatStencil_k,7) = k - 1 - 1/**/
>>>                 /**/col(MatStencil_c,7) = offset - 1/**/
>>>                 /**/value_insert(7) = -(
>>>                 1./(cell_z(k)%pd_B+cell_z(k-1)%pd_F))*(c_xy(i,j)%fc_F)*inv_Re/**/
>>>                 /**/col(MatStencil_i,1) = i - 1/**/
>>>                 /**/col(MatStencil_j,1) = j - 1/**/
>>>                 /**/col(MatStencil_k,1) = k - 1/**/
>>>                 /**/col(MatStencil_c,1) = offset - 1/**/
>>>                 /**/value_insert(1) = 2.*c(i,j,k)%vol/del_t -
>>>                 (value_insert(2)+value_insert(3)+value_insert(4)+value_insert(5)+value_insert(6)+value_insert(7))/**/
>>>                 /**/call
>>>                 MatSetValuesStencil(A_semi_xyz,ione,row,iseven,col,value_insert,INSERT_VALUES,ierr)/**/
>>>                 /**/end do/**/
>>>                 /**/end do/**/
>>>                 /**/end do /*
>>>                 Thank you
>>>                 Yours sincerely,
>>>                 TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150925/277267ca/attachment-0001.html>
