[petsc-users] Insert values into matrix using MatSetValuesStencil
TAY wee-beng zonexo at gmail.com
Wed Sep 23 03:25:28 CDT 2015
Thank you
Yours sincerely,
TAY wee-beng
On 23/9/2015 4:18 PM, Timothée Nicolas wrote:
> The first thing that strikes me is your definition of the stencils
> */MatStencil  :: row(6,1),col(6,7)/**/
> Why is it not defined with
> */MatStencil  :: row(4,1),col(4,7)/**/
> instead ?
> Where does the 6 come from ?
> Timothée
Maybe I misunderstood. But in your email tutorial, last time, with 1
dof, it's
So now I have 3 dof, shouldn't it be
> 2015-09-23 17:14 GMT+09:00 TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>>:
>     Hi,
>     I have successfully used MatSetValuesStencil to insert values into
>     a Poisson eqn matrix which has 1 DOF (pressure). Now I'm trying to
>     insert values in a momentum eqn matrix which has 3 DOF (u,v,w)
>     However, I got the error:
>     /*[0]PETSC ERROR: --------------------- Error Message
>     *//*[0]PETSC ERROR: Argument out of range*//*
>     *//*[0]PETSC ERROR: Inserting a new nonzero at (111,5) in the
>     matrix*//*
>     *//*[0]PETSC ERROR: See
>     http://www.mcs.anl.gov/petsc/documentation/faq.html for trou*//*
>     *//*ble shooting.*/
>     I wonder what's wrong.  For the momentum eqn, for each DOF, at at
>     node (dof,i,j,k), I have coupling i +/- 1, j +/- 1 and k +/- 1.
>     The error happens at 111,5, which corresponds to i = 2, j = 2, k =
>     2, which is an internal node.
>     Here's part of my code below. Hope someone can help. Thanks!
>     /**/PetscScalar :: value_insert(7)/**/
>     /**/MatStencil  :: row(6,1),col(6,7)/**/
>     /**/ione = 1;   iseven = 7/**/
>     /**/if (cell_type == 'u') then/**/
>     /**/    offset = 1/**/
>     /**/else if (cell_type == 'v') then/**/
>     /**/    offset = 2/**/
>     /**/else if (cell_type == 'w') then/**/
>     /**/    offset = 3/**/
>     /**/end if/**/
>     /**/do k=ksta2,kend2/**/
>     /**/    do j = jsta2,jend2/**/
>     /**/        do i=2,size_x-1/**/
>     /**/            row(MatStencil_i,1) = i - 1/**/
>     /**/            row(MatStencil_j,1) = j - 1/**/
>     /**/            row(MatStencil_k,1) = k - 1/**/
>     /**/            row(MatStencil_c,1) = offset - 1/**/
>     /**/            value_insert = 0.d0/**/
>     /**/            col(MatStencil_i,3) = i + 1 - 1 !east/**/
>     /**/            col(MatStencil_j,3) = j - 1/**/
>     /**/            col(MatStencil_k,3) = k - 1/**/
>     /**/            col(MatStencil_c,3) = offset - 1/**/
>     /**/            value_insert(3) = -(
>     1./(cell_x(i)%pd_E+cell_x(i+1)%pd_W))*(c_yz(j,k)%fc_E)*inv_Re/**/
>     /**/            col(MatStencil_i,5) = i - 1 - 1 !west/**/
>     /**/            col(MatStencil_j,5) = j - 1/**/
>     /**/            col(MatStencil_k,5) = k - 1/**/
>     /**/            col(MatStencil_c,5) = offset - 1/**/
>     /**/            value_insert(5) = -(
>     1./(cell_x(i)%pd_W+cell_x(i-1)%pd_E))*(c_yz(j,k)%fc_E)*inv_Re/**/
>     /**/            col(MatStencil_i,2) = i - 1 !north/**/
>     /**/            col(MatStencil_j,2) = j + 1 - 1/**/
>     /**/            col(MatStencil_k,2) = k - 1/**/
>     /**/            col(MatStencil_c,2) = offset - 1/**/
>     /**/            value_insert(2) = -(
>     1./(cell_y(j)%pd_N+cell_y(j+1)%pd_S))*(c_zx(i,k)%fc_N)*inv_Re/**/
>     /**/            col(MatStencil_i,4) = i - 1 !south/**/
>     /**/            col(MatStencil_j,4) = j - 1 - 1/**/
>     /**/            col(MatStencil_k,4) = k - 1/**/
>     /**/            col(MatStencil_c,4) = offset - 1/**/
>     /**/            value_insert(4) = -(
>     1./(cell_y(j)%pd_S+cell_y(j-1)%pd_N))*(c_zx(i,k)%fc_N)*inv_Re/**/
>     /**/            col(MatStencil_i,6) = i - 1 !front/**/
>     /**/            col(MatStencil_j,6) = j - 1/**/
>     /**/            col(MatStencil_k,6) = k + 1 - 1/**/
>     /**/            col(MatStencil_c,6) = offset - 1/**/
>     /**/            value_insert(6) = -(
>     1./(cell_z(k)%pd_F+cell_z(k+1)%pd_B))*(c_xy(i,j)%fc_F)*inv_Re/**/
>     /**/            col(MatStencil_i,7) = i - 1 !back/**/
>     /**/            col(MatStencil_j,7) = j - 1/**/
>     /**/            col(MatStencil_k,7) = k - 1 - 1/**/
>     /**/            col(MatStencil_c,7) = offset - 1/**/
>     /**/            value_insert(7) = -(
>     1./(cell_z(k)%pd_B+cell_z(k-1)%pd_F))*(c_xy(i,j)%fc_F)*inv_Re/**/
>     /**/            col(MatStencil_i,1) = i - 1/**/
>     /**/            col(MatStencil_j,1) = j - 1/**/
>     /**/            col(MatStencil_k,1) = k - 1/**/
>     /**/            col(MatStencil_c,1) = offset - 1/**/
>     /**/            value_insert(1) = 2.*c(i,j,k)%vol/del_t -
>     (value_insert(2)+value_insert(3)+value_insert(4)+value_insert(5)+value_insert(6)+value_insert(7))/**/
>     /**/            call
>     MatSetValuesStencil(A_semi_xyz,ione,row,iseven,col,value_insert,INSERT_VALUES,ierr)/**/
>     /**/        end do/**/
>     /**/    end do/**/
>     /**/end do /*
>     Thank you
>     Yours sincerely,
>     TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150923/4494896b/attachment-0001.html>
