[petsc-users] Trivial parallelizing in SLEPc
Hong
hzhang at mcs.anl.gov
Wed Sep 23 10:37:18 CDT 2015
Anders:
> Dear PETSc Users,
> I want to find the smallest eigenpairs of a hermitian operator, A,
> implemented as a matrix-less operator.
Do you mean matrix-free operator?
There are slepc examples using shell matrix:
slepc/src/eps/examples/tutorials
grep -i shell *.c
ex3.c
ex9.c
ex10.c
Take a look at these examples.
> When computing y = Ax, I need the entire vector x, and I calculate the
> entire vector y, therefore I want to avoid the ownership of x and y to be
> spread over different processes.
Do you mean you want x and y owned by a single process, not distributed?
Suggest doing sequential computation first, then move to parallel execution.
> To what extend can this problem be parallelized in SLEPc. For instance can
> I use a block Krylov or block JD algorithm where different processes
> compute different matrix vector multiplications. If I provide the correct
> operations when constructing my MatShell, can I expect the FEAST algorithm
> to compute each contour point on a different process?
Slepc developer might answer this question.
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150923/eb113f17/attachment.html>
