[petsc-users] gamg and zero pivots
Gideon Simpson gideon.simpson at gmail.com
Mon Sep 21 08:44:43 CDT 2015
Thanks for the suggestions guys.  Barry’s field split approach gives sensible behavior.  Now I’m working on tuning it.
-gideon
> On Sep 21, 2015, at 9:21 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
>>> At the same time, the first block, as discussed, has
>>> these zeros on the diagonal, and can’t use SOR.
>> Chebyshev/Jacobi is the obvious next try.
> Not really; the Chebyshev polynomial exceeds 1 left of the origin, so
> it's pretty non-functional on indefinite operators.  Pretending like
> Gideon's saddle point problem is positive definite is not a solution.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150921/0ac81913/attachment.html>
