[petsc-users] gamg and zero pivots
    Jed Brown
    jed at jedbrown.org
    Mon Sep 21 08:21:35 CDT 2015
Matthew Knepley <knepley at gmail.com> writes:
>>At the same time, the first block, as discussed, has
>> these zeros on the diagonal, and can’t use SOR.
> Chebyshev/Jacobi is the obvious next try.
Not really; the Chebyshev polynomial exceeds 1 left of the origin, so
it's pretty non-functional on indefinite operators.  Pretending like
Gideon's saddle point problem is positive definite is not a solution.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150921/723391c8/attachment.pgp>
