[petsc-users] gamg and zero pivots
Gideon Simpson gideon.simpson at gmail.com
Fri Sep 18 22:42:02 CDT 2015
I’m getting a zero pivot in LU factorization error when I use the gamg preconditioner.  I know there is some issue with my matrix, as I get the same error if I use pc_type lu in serial, or if I use pc_type bjacobi in parallel, both of which are corrected by adding -pc_factor_shift_type NONZERO -sub_pc_factor_shift_type NONZERO, respectively.  However, I can’t quite seem to figure out the analogous command to use for the gamg preconditioner.
-gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150918/3dc17378/attachment.html>
