[petsc-users] Automatically re-solving after MUMPS error
David Knezevic
david.knezevic at akselos.com
Tue Sep 15 06:47:30 CDT 2015
On Tue, Sep 15, 2015 at 7:29 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Sep 15, 2015 at 4:30 AM, David Knezevic <
> david.knezevic at akselos.com> wrote:
>> In some cases, I get MUMPS error -9, i.e.:
>> [2]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
>> INFO(1)=-9, INFO(2)=98927
>> This is easily fixed by re-running the executable with
>> -mat_mumps_icntl_14 on the commandline.
>> However, I would like to update my code in order to do this
>> automatically, i.e. detect the -9 error and re-run with the appropriate
>> option. Is there a recommended way to do this? It seems to me that I could
>> do this with a PETSc error handler (e.g. PetscPushErrorHandler) in order to
>> call a function that sets the appropriate option and solves again, is that
>> right? Are there any examples that illustrate this type of thing?
> I would not use the error handler. I would just check the ierr return code
> from the solver. I think you need the
> INFO output, for which you can use MatMumpsGetInfo().
OK, that sounds good (and much simpler than what I had in mind), thanks for
the help!
David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150915/bb7cf24c/attachment.html>
