[petsc-users] Query regarding convergence of KSP solver
Jed Brown
jed at jedbrown.org
Tue Sep 8 16:55:45 CDT 2015
Rachit Prasad <rachitp at vt.edu> writes:
> Hello,
> I am working to solve a linear system of equations using a KSP solver. The
> size of the matrix is approximately ~370,000. The following settings have
> been used to set up the solver"
> [image: Inline image 1]
> The L2 norm of the RHS for this problem is ~365, which has been calculated
> using the subroutine *VecNorm*. When I solve this system, I am finding that
> irrespective of the number of maximum iterations the L2 norm of final
> residual is pretty much constant around ~37860.
Your solver has stagnated, either due to numerical precision issues
(e.g., if the matrix entries are enormous in this case) or (more likely)
due to an inadequate/unstable preconditioner.
> The L2 norm of the residual has been found using the subroutine
> *KSPGetResidualNorm. *The following is how the residual is varying for
> different maximum iterations. *[image: Inline image 2]*
> With such being the case, I have the following doubts to clarify:
> - Are the settings used by me for the KSP solver adequate enough? Or am
> I missing something?
> - What could be reasons for my KSP solver to not converge below the
> permissible tolerance?
> - For a linear system of given size, how can one determine the number of
> maximum iterations that should be set for the KSP solver? Is there a thumb
> rule?
> Regards,
> Rachit Prasad
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150908/99ef3f2a/attachment.pgp>
