[petsc-users] error using GetType in FORTRAN
Mark Adams
mfadams at lbl.gov
Fri May 29 12:20:32 CDT 2015
Well I used a fresh petsc clone and that worked.
On Fri, May 29, 2015 at 1:05 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Humm, I cleaned everything, and even cut and pasted your configure line,
> same thing. I am now trying with a fresh petsc clone.
> I add these modules:
> module load adios/1.6.0
> module load cray-hdf5-parallel
> module load cmake/2.8.11.2
> module unload darshan
> and I do not see this bfort-base.txt file:
> 10:03 edison03 master ~/petsc_install/petsc$ ll arch-xc30-opt64-intel/share
> total 32
> -rw-r--r-- 1 madams madams 4755 May 29 09:52 basedefs.txt
> -rw-r--r-- 1 madams madams 326 May 29 09:52 blueball.gif
> drwxr-x--- 2 madams madams 512 May 29 09:52 doctext
> -rw-r--r-- 1 madams madams 326 May 29 09:52 greenball.gif
> -rw-r--r-- 1 madams madams 1625 May 29 09:52 html.def
> -rw-r--r-- 1 madams madams 1668 May 29 09:52 latex.def
> drwxr-x--- 3 madams madams 512 May 29 09:52 man
> -rw-r--r-- 1 madams madams 79 May 29 09:52 next.gif
> -rw-r--r-- 1 madams madams 287 May 29 09:52 next.xbm
> -rw-r--r-- 1 madams madams 1482 May 29 09:52 nroff.def
> -rw-r--r-- 1 madams madams 79 May 29 09:52 previous.gif
> -rw-r--r-- 1 madams madams 299 May 29 09:52 previous.xbm
> -rw-r--r-- 1 madams madams 7353 May 29 09:52 pstoppm.ps
> -rw-r--r-- 1 madams madams 326 May 29 09:52 purpleball.gif
> -rw-r--r-- 1 madams madams 326 May 29 09:52 redball.gif
> -rw-r--r-- 1 madams madams 283 May 29 09:52 refman.def
> -rw-r--r-- 1 madams madams 3151 May 29 09:52 refman.sty
> -rw-r--r-- 1 madams madams 74 May 29 09:52 up.gif
> -rw-r--r-- 1 madams madams 281 May 29 09:52 up.xbm
> -rw-r--r-- 1 madams madams 324 May 29 09:52 yellowball.gif
> On Fri, May 29, 2015 at 11:23 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> I tried building on edison - and can't reproduce this problem.
>> ./configure --COPTFLAGS="-fast -no-ipo" --CXXOPTFLAGS="-fast -no-ipo"
>> --FOPTFLAGS="-fast -no-ipo" --with-ssl=0 --with-cc=cc
>> --with-clib-autodetect=0 --with-cxx=CC --with-cxxlib-autodetect=0
>> --with-debugging=0 --with-fc=ftn --with-fortranlib-autodetect=0
>> --with-shared-libraries=0 --with-x=0 --with-mpiexec=aprun LIBS=-lstdc++
>> --with-64-bit-indices PETSC_DIR=$PWD PETSC_ARCH=arch-xc30-opt64-intel
>> --prefix=$HOME/soft/test
>> The error message you get is puzzling..
>> > Unable to find bfort-base.txt config file in
>> /global/homes/m/madams/petsc_install/petsc/arch-xc30-opt64-intel/share*******
>> Can you attempt a build from a 'clean' repo?
>> rm -rf arch*
>> git clean -f -d -x
>> ./configure....
>> Satish
>> On Fri, 29 May 2015, Mark Adams wrote:
>> > Barry, It looks like you blew it.
>> > On Wed, May 27, 2015 at 4:03 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> > > Apparently all people with access to the PETSc repository (i.e.
>> > > everyone in the world with internet access) have caught a rare
>> disease that
>> > > has caused their fingers to fall off, making them incapable of fixing
>> this.
>> > > I have added all the PETSc enums to this file in master and next.
>> Make
>> > > sure you run make allfortranstubs to regenerate the stubs.
>> > > Barry
>> > > > On May 27, 2015, at 2:15 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > > > FYI, this does not seem to be fixed.
>> > > > On Sat, Apr 18, 2015 at 5:49 AM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> > > > Looks like a bunch of these things are missing from
>> > > lib/petsc/conf/bfort-petsc.txt it should be listed under native
>> > > > Barry
>> > > > > On Apr 17, 2015, at 4:43 PM, Matthew Knepley <knepley at gmail.com>
>> > > wrote:
>> > > > > Does bfort have to be told that PCCompositeType is an enum?
>> > > > > Matt "bfort's biggest fan"
>> > > > > On Fri, Apr 17, 2015 at 4:37 PM, Mark Adams <mfadams at lbl.gov>
>> wrote:
>> > > > > It looks like fieldsplitf.c has an extra PetscToPointer. type is
>> > > already a pointer:
>> > > > > PETSC_EXTERN void PETSC_STDCALL pcfieldsplitgettype_(PC
>> > > pc,PCCompositeType *type, int *__ierr ){
>> > > > > *__ierr = PCFieldSplitGetType(
>> > > > > (PC)PetscToPointer((pc) ),
>> > > > > (PCCompositeType* )PetscToPointer((type) ));
>> > > > > On Fri, Apr 17, 2015 at 4:12 PM, Barry Smith <bsmith at mcs.anl.gov>
>> > > wrote:
>> > > > > Likely need to run in the debugger to see what generates the
>> error.
>> > > Perhaps a missing ierr?
>> > > > > Barry
>> > > > > > On Apr 17, 2015, at 9:10 AM, Mark Adams <mfadams at lbl.gov>
>> wrote:
>> > > > > > I declare
>> > > > > > PCCompositeType::pcctype
>> > > > > > But PCFieldSplitGetType does not seem to like it?
>> > > > > > Mark
>> > > > > > [1]PETSC ERROR: --------------------- Error Message
>> > > > > > [1]PETSC ERROR: Invalid pointer
>> > > > > > [1]PETSC ERROR: Invalid Pointer to Int: Parameter # 2
>> > > > > > [1]PETSC ERROR: See
>> > > http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> shooting.
>> > > > > > [1]PETSC ERROR: Petsc Development GIT revision:
>> > > v3.5.3-2702-g1f714da GIT Date: 2015-04-16 11:32:06 -0500
>> > > > > > [1]PETSC ERROR: ../../XGC1_3/xgc-em on a arch-macosx-gnu-g named
>> > > MacBook-Pro.local by markadams Fri Apr 17 10:06:09 2015
>> > > > > > [1]PETSC ERROR: Configure options --download-hypre=1
>> > > --download-p4est --download-superlu=1 --download-mumps
>> --download-scalapack
>> > > --download-superlu_dist=1 --download-parmetis=1 --download-metis=1
>> > > --download-triangle=1 --with-hdf5-dir=/Users/markadams/Codes/hdf5
>> > > --with-x=0 --with-debugging=1 PETSC_ARCH=arch-macosx-gnu-g
>> > > > > > [1]PETSC ERROR: #1 PCFieldSplitGetType() line 2046 in
>> > > /Users/markadams/Codes/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>> > > > > What most experimenters take for granted before they begin their
>> > > experiments is infinitely more interesting than any results to which
>> their
>> > > experiments lead.
>> > > > > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150529/e167d105/attachment.html>
