[petsc-users] SNESVINEWTONRSLS: definition of active set?
Asbjørn Nilsen Riseth riseth at maths.ox.ac.uk
Fri May 29 04:19:14 CDT 2015
Barry,
I changed the code, but it only makes a difference at the order of 1e-10 -
so that's not the cause. I've attached (if that's appropriate?) the patch
in case anyone is interested.
Investigating the function values, I see that the first Newton step goes
towards the expected solution for my function values. Then it shoots back
close to the initial conditions.
At the time the solver hits tolerance for the inactive set; the function
value is 100-1000 at some of the active set indices.
Reducing the timestep by an order of magnitude shows the same behavior for
the first two timesteps.
Maybe VI is not the right approach. The company I work with seem to just be
projecting negative values.
I'll investigate further.
Ozzy
On Thu, 28 May 2015 at 20:26 Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Ozzy,
>      I cannot say why it is implemented as >=  (could be in error). Just
> try changing the PETSc code (just run make gnumake in the PETSc directory
> after you change the source to update the library) and see how it affects
> your code run.
>    Barry
> > On May 28, 2015, at 3:15 AM, Asbjørn Nilsen Riseth <
> riseth at maths.ox.ac.uk> wrote:
> > Dear PETSc developers,
> > Is the active set in NewtonRSLS defined differently from the reference*
> you give in the documentation on purpose?
> > The reference defines the active set as:
> > x_i = 0 and F_i > 0,
> > whilst the PETSc code defines it as x_i = 0 and F_i >= 0 (vi.c: 356) :
> > !((PetscRealPart(x[i]) > PetscRealPart(xl[i]) + 1.e-8 ||
> (PetscRealPart(f[i]) < 0.0)
> > So PETSc freezes the variables if f[i] == 0.
> > I've been using the Newton RSLS method to ensure positivity in a
> subsurface flow problem I'm working on. My solution stays almost constant
> for two timesteps (seemingly independent of the size of the timestep),
> before it goes towards the expected solution.
> > From my initial conditions, certain variables are frozen because x_i = 0
> and f[i] = 0, and I was wondering if that could be the cause of my issue.
> > - T. S. Munson, and S. Benson. Flexible Complementarity Solvers for
> Large-Scale Applications, Optimization Methods and Software, 21 (2006).
> > Regards,
> > Ozzy
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150529/8e4674cf/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150529/8e4674cf/attachment.bin>
