[petsc-users] SNESVINEWTONRSLS: definition of active set?
Barry Smith
bsmith at mcs.anl.gov
Thu May 28 14:26:23 CDT 2015
Ozzy,
I cannot say why it is implemented as >= (could be in error). Just try changing the PETSc code (just run make gnumake in the PETSc directory after you change the source to update the library) and see how it affects your code run.
Barry
> On May 28, 2015, at 3:15 AM, Asbjørn Nilsen Riseth <riseth at maths.ox.ac.uk> wrote:
> Dear PETSc developers,
> Is the active set in NewtonRSLS defined differently from the reference* you give in the documentation on purpose?
> The reference defines the active set as:
> x_i = 0 and F_i > 0,
> whilst the PETSc code defines it as x_i = 0 and F_i >= 0 (vi.c: 356) :
> !((PetscRealPart(x[i]) > PetscRealPart(xl[i]) + 1.e-8 || (PetscRealPart(f[i]) < 0.0)
> So PETSc freezes the variables if f[i] == 0.
> I've been using the Newton RSLS method to ensure positivity in a subsurface flow problem I'm working on. My solution stays almost constant for two timesteps (seemingly independent of the size of the timestep), before it goes towards the expected solution.
> From my initial conditions, certain variables are frozen because x_i = 0 and f[i] = 0, and I was wondering if that could be the cause of my issue.
> - T. S. Munson, and S. Benson. Flexible Complementarity Solvers for Large-Scale Applications, Optimization Methods and Software, 21 (2006).
> Regards,
> Ozzy
