[petsc-users] MUMPS error and superLU error
Hong
hzhang at mcs.anl.gov
Tue May 26 10:32:54 CDT 2015
'A serial job in MATLAB for the same matrices takes < 60GB. '
Can you run this case in serial? If so, try petsc, superlu or mumps to make
sure the matrix is non-singular.
Both mumps and superlu_dist show crash in MatFactorNumeric(). Mumps gives
error
[16]PETSC ERROR: Error reported by MUMPS in numerical factorization phase:
Cannot allocate required memory 65710 megabytes.
Does your code work for smaller problems?
Try using more processors?
Why use such huge '-mat_mumps_icntl_14 200000' (percentage of estimated
workspace increase)? The default is 20. Try 40?
Superlu_dist usually uses less memory than mumps, but it also crashes. I
guess something wrong with your matrix. Is it singular?
Run superlu_dist on a slightly smaller matrix with option
'-mat_superlu_dist_statprint' which displays memory usage info., e.g.,
petsc/src/ksp/ksp/examples/tutorials (maint)
$ mpiexec -n 2 ./ex2 -pc_type lu -pc_factor_mat_solver_package superlu_dist
Nonzeros in L 560
Nonzeros in U 560
nonzeros in L+U 1064
nonzeros in LSUB 248
NUMfact space (MB) sum(procs): L\U 0.01 all 0.05
Total highmark (MB): All 0.05 Avg 0.02 Max 0.02
EQUIL time 0.00
ROWPERM time 0.00
COLPERM time 0.00
SYMBFACT time 0.00
DISTRIBUTE time 0.00
FACTOR time 0.00
Factor flops 1.181000e+04 Mflops 4.80
SOLVE time 0.00
SOLVE time 0.00
Solve flops 2.194000e+03 Mflops 4.43
SOLVE time 0.00
Solve flops 2.194000e+03 Mflops 5.14
Norm of error 1.18018e-15 iterations 1
Hong
On Tue, May 26, 2015 at 9:03 AM, venkatesh g <venkateshgk.j at gmail.com>
wrote:
> I posted a while ago in MUMPS forums but no one seems to reply.
> I am solving a large generalized Eigenvalue problem.
> I am getting the following error which is attached, after giving the
> command:
> /cluster/share/venkatesh/petsc-3.5.3/linux-gnu/bin/mpiexec -np 64 -hosts
> compute-0-4,compute-0-6,compute-0-7,compute-0-8 ./ex7 -f1 a72t -f2 b72t
> -st_type sinvert -eps_nev 3 -eps_target 0.5 -st_ksp_type preonly
> -st_pc_type lu -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14
> 200000
> IT IS impossible to allocate so much memory per processor.. it is asking
> like around 70 GB per processor.
> After trying out superLU_dist, I have attached the error there also
> (segmentation error).
> Kindly help me.
> Venkatesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150526/e9c3a487/attachment.html>
