[petsc-users] MUMPS error and superLU error
venkatesh g
venkateshgk.j at gmail.com
Tue May 26 09:03:49 CDT 2015
I posted a while ago in MUMPS forums but no one seems to reply.
I am solving a large generalized Eigenvalue problem.
I am getting the following error which is attached, after giving the
command:
/cluster/share/venkatesh/petsc-3.5.3/linux-gnu/bin/mpiexec -np 64 -hosts
compute-0-4,compute-0-6,compute-0-7,compute-0-8 ./ex7 -f1 a72t -f2 b72t
-st_type sinvert -eps_nev 3 -eps_target 0.5 -st_ksp_type preonly
-st_pc_type lu -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14
200000
IT IS impossible to allocate so much memory per processor.. it is asking
like around 70 GB per processor.
A serial job in MATLAB for the same matrices takes < 60GB.
After trying out superLU_dist, I have attached the error there also
(segmentation error).
Kindly help me.
Venkatesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150526/9f294866/attachment-0001.html>
Generalized eigenproblem stored in file.
Reading COMPLEX matrices from binary files...
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Error in external library
[0]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 451597 megabytes
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[0]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[2]PETSC ERROR: Error in external library
[2]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 457041 megabytes
[2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[2]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[2]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[2]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[2]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: Error in external library
[8]PETSC ERROR: [6]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[6]PETSC ERROR: Error in external library
[6]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 64063 megabytes
[6]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[6]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[6]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[6]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[6]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[6]PETSC ERROR: [5]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[5]PETSC ERROR: Error in external library
[5]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 64043 megabytes
[5]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[5]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[5]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[5]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[5]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[16]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[16]PETSC ERROR: Error in external library
[16]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65710 megabytes
[16]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[16]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[16]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[16]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[16]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[16]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[16]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[10]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[10]PETSC ERROR: Error in external library
[10]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 64488 megabytes
[10]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[10]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[10]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[10]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[10]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[10]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[10]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[10]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[10]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[10]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[10]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[10]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[10]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[17]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[17]PETSC ERROR: Error in external library
[17]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 71786 megabytes
[17]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[17]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[17]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[17]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[17]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[17]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[32]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[32]PETSC ERROR: Error in external library
[32]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 73270 megabytes
[32]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[32]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[32]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[32]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[32]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[32]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[32]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[32]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[32]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[32]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[3]PETSC ERROR: Error in external library
[3]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 59714 megabytes
[3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[3]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[3]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[3]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[3]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[3]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[3]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[3]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[3]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[3]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[3]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[3]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[3]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[3]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[3]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 3
[cli_3]: aborting job:
[18]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[18]PETSC ERROR: Error in external library
[18]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 74466 megabytes
[18]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[18]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[18]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[18]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[18]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[18]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[18]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[18]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[18]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[18]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[18]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[18]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[18]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[18]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[18]PETSC ERROR: [33]PETSC ERROR: [48]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[48]PETSC ERROR: Error in external library
[48]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 79966 megabytes
[48]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[48]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[48]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[48]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[48]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[48]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[48]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[48]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[48]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[48]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[48]PETSC ERROR: [7]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[7]PETSC ERROR: Error in external library
[7]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 56809 megabytes
[7]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[7]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[7]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[7]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[7]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[7]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[7]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[7]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[7]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[7]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[7]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[7]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[7]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[7]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[7]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 7
[cli_7]: aborting job:
[2]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[2]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[2]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[2]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[2]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[2]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[2]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[2]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[2]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[2]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[1]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 63961 megabytes
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[1]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[1]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[1]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[1]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[1]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[0]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[0]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[0]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[0]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[19]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[19]PETSC ERROR: Error in external library
[19]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 66131 megabytes
[19]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[19]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[19]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[19]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[19]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[19]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[19]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[19]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[19]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[19]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[19]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[19]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[19]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[19]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[19]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 19
[cli_19]: aborting job:
[6]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[6]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[6]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[6]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[6]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[6]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[6]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[6]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[6]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[5]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[5]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[5]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[5]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[5]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[5]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[5]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[5]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[16]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[16]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[16]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[16]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[16]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[16]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[16]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[16]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[23]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[23]PETSC ERROR: Error in external library
[23]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 67701 megabytes
[23]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[23]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[23]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[23]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[23]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[23]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[23]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[23]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[23]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[23]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[23]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[23]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[23]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[23]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[23]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 23
[10]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[10]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[17]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[17]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[17]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[17]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[17]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[17]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[17]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[20]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[20]PETSC ERROR: Error in external library
[20]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65476 megabytes
[20]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[20]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[20]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[20]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[20]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[20]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[20]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[20]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[20]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[20]PETSC ERROR: [35]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[35]PETSC ERROR: Error in external library
[35]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 57572 megabytes
[35]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[35]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[35]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[35]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[35]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[35]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[35]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[35]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[35]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[35]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[35]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[35]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[35]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[35]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[35]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 35
[14]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[14]PETSC ERROR: Error in external library
[14]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 76742 megabytes
[14]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[14]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[14]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[14]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[14]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[14]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[14]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[14]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[14]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[14]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[14]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[14]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[14]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[21]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[21]PETSC ERROR: Error in external library
[21]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 61748 megabytes
[21]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[21]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[21]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[21]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[21]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[21]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[21]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[21]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[21]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[21]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[21]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[21]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[21]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[32]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[32]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[32]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[32]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[32]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[39]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[39]PETSC ERROR: Error in external library
[39]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 64773 megabytes
[39]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[39]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[39]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[39]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[39]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[39]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[39]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[39]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[39]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[39]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[39]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[39]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[39]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[39]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[39]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 39
[cli_39]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 18
[37]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[37]PETSC ERROR: Error in external library
[37]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 55361 megabytes
[37]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[37]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[37]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[37]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[37]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[37]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[40]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[40]PETSC ERROR: Error in external library
[40]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65450 megabytes
[40]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[40]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[40]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[40]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[40]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[40]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[40]PETSC ERROR: [43]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[43]PETSC ERROR: Error in external library
[43]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58608 megabytes
[43]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[43]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[43]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[43]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[43]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[43]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[43]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[43]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[43]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[43]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[43]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[43]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[43]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[43]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[43]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 43
[cli_43]: aborting job:
[22]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[22]PETSC ERROR: Error in external library
[22]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65695 megabytes
[22]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[22]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[22]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[22]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[22]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[22]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[22]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[22]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[22]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[41]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[41]PETSC ERROR: Error in external library
[41]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 54285 megabytes
[41]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[41]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[41]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[41]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[41]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[41]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[41]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[41]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[41]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[41]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[41]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[41]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[41]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[41]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[41]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[48]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[48]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[48]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[48]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[55]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[55]PETSC ERROR: Error in external library
[55]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 48241 megabytes
[55]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[55]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[55]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[55]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[55]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[55]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[55]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[55]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[55]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[55]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[55]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[55]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[55]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[55]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[55]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 55
[cli_55]: aborting job:
[34]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[34]PETSC ERROR: Error in external library
[34]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58458 megabytes
[34]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[34]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[34]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[34]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[34]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[34]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[34]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[34]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[34]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[34]PETSC ERROR: [1]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[1]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[1]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[1]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[1]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[1]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[1]PETSC ERROR: [56]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[56]PETSC ERROR: Error in external library
[56]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58551 megabytes
[56]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[56]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[56]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[56]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[56]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[56]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[56]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[56]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[56]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[56]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[56]PETSC ERROR: [42]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[42]PETSC ERROR: Error in external library
[42]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 49860 megabytes
[42]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[42]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[42]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[42]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[42]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[42]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[42]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[42]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[42]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[42]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[42]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[5]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[5]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[0]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[0]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[0]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[0]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[0]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[46]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[46]PETSC ERROR: Error in external library
[46]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 71031 megabytes
[46]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[46]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[46]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[46]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[46]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[46]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[46]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[46]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[46]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[46]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[46]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[46]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[46]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[46]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[46]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[17]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[17]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 17
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 16
[cli_16]: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 2
[cli_2]: aborting job:
[21]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 21
[20]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[20]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[20]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[20]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[20]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 20
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 6
[cli_6]: aborting job:
[25]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[25]PETSC ERROR: Error in external library
[25]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 68676 megabytes
[25]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[25]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[25]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[25]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[25]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[25]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[25]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[25]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 32
[cli_32]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 10
[cli_10]: aborting job:
[37]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[37]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[37]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[37]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[37]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[37]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[37]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[37]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[40]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[40]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[40]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[40]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[40]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[40]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[14]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[14]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 14
[cli_14]: aborting job:
[1]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 48
[cli_48]: aborting job:
[cli_18]: aborting job:
[cli_5]: aborting job:
[56]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[56]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[56]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[56]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[22]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[22]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[22]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[22]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[22]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[22]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 22
[cli_21]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 0
[34]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[34]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[34]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[34]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[34]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 34
[25]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[25]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[25]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[25]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[25]PETSC ERROR: aborting job:
[42]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[42]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[42]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[42]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 42
[37]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 37
[cli_20]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 46
[cli_46]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 41
[cli_41]: aborting job:
[40]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[40]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 40
[cli_22]: aborting job:
[cli_1]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 56
[cli_56]: aborting job:
[cli_34]: aborting job:
[cli_17]: aborting job:
[cli_0]: aborting job:
[cli_42]: aborting job:
[25]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[25]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[cli_40]: aborting job:
[26]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[26]PETSC ERROR: Error in external library
[26]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58191 megabytes
[26]PETSC ERROR: [cli_37]: aborting job:
[12]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[26]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[26]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[26]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[26]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 25
[cli_25]: aborting job:
[26]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[52]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[52]PETSC ERROR: Error in external library
[52]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58405 megabytes
[52]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[52]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[52]PETSC ERROR: [26]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[26]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[26]PETSC ERROR: [33]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[52]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[52]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[26]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[26]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[52]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[52]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[52]PETSC ERROR: [26]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[26]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[26]PETSC ERROR: [33]PETSC ERROR: [24]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[24]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[26]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 46237 megabytes
[52]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[52]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[52]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 26
[33]PETSC ERROR: Error in external library
[24]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 69315 megabytes
[24]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[24]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[24]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[24]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[cli_26]: aborting job:
[28]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[28]PETSC ERROR: Error in external library
[28]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: [52]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[52]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[52]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[52]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[9]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[9]PETSC ERROR: Error in external library
[9]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 70478 megabytes
[9]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[9]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[9]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[9]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[9]PETSC ERROR: [24]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[24]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[24]PETSC ERROR: [30]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 68179 megabytes
[28]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[28]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[28]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[28]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[28]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[38]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[38]PETSC ERROR: Error in external library
[38]PETSC ERROR: [13]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[13]PETSC ERROR: Error in external library
[13]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 70887 megabytes
[13]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[13]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[13]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[13]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[24]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[24]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[24]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 63402 megabytes
[38]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[38]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[38]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[38]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[29]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[29]PETSC ERROR: Error in external library
[29]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 66349 megabytes
[29]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[29]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[29]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[29]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[29]PETSC ERROR: [28]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[28]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[28]PETSC ERROR: [38]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[13]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[13]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[36]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[36]PETSC ERROR: Error in external library
[36]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 67737 megabytes
[36]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[36]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[36]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[36]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[36]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[38]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[29]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[29]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 52
[cli_52]: aborting job:
[38]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[38]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[13]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[13]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[24]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[24]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[24]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[24]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[38]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[38]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[38]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[29]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[29]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[28]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[28]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[28]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[28]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[28]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[50]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[50]PETSC ERROR: Error in external library
[50]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 61866 megabytes
[50]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[50]PETSC ERROR: [9]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[9]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[9]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[9]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[36]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[36]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[36]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[36]PETSC ERROR: [38]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[38]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[38]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[13]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[13]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[13]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[13]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 24
[50]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[50]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[50]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[29]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[29]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[29]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[28]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[28]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[54]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[54]PETSC ERROR: Error in external library
[54]PETSC ERROR: [9]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[9]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[9]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[36]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[36]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[36]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[36]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 38
[13]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[13]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[cli_24]: aborting job:
[50]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[29]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[29]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 28
[cli_28]: aborting job:
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 49070 megabytes
[54]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[54]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[54]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[54]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[54]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[9]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[9]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[9]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[36]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[36]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[cli_38]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 13
[cli_13]: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 36
[50]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[50]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[50]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[50]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 29
[cli_36]: aborting job:
[50]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[50]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[50]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 9
[12]PETSC ERROR: [54]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[54]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[54]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[54]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
aborting job:
[50]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[50]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[cli_29]: aborting job:
[12]PETSC ERROR: [54]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[54]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[54]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[cli_9]: aborting job:
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 63360 megabytes
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 50
[12]PETSC ERROR: [54]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[54]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[54]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[33]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[cli_50]: aborting job:
[12]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 54
[cli_54]: aborting job:
[33]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 57090 megabytes
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[30]PETSC ERROR: [33]PETSC ERROR: [12]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[8]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[30]PETSC ERROR: [33]PETSC ERROR: [8]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[12]PETSC ERROR: [30]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 33
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65248 megabytes
[cli_33]: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[30]PETSC ERROR: aborting job:
[8]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[45]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[45]PETSC ERROR: Error in external library
[45]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 46032 megabytes
[45]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[45]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[45]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[45]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[45]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[45]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[12]PETSC ERROR: [30]PETSC ERROR: [45]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[45]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[45]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[45]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[45]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[45]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[45]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[45]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[45]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[8]PETSC ERROR: [30]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 45
[cli_45]: aborting job:
[49]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[49]PETSC ERROR: Error in external library
[49]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 54280 megabytes
[49]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[49]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[49]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[49]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[49]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[49]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[30]PETSC ERROR: [57]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[57]PETSC ERROR: Error in external library
[57]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 54334 megabytes
[57]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[57]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[57]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[57]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[57]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[57]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[57]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[57]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[57]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[57]PETSC ERROR: [12]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[49]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[49]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[49]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[49]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[49]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[49]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[49]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[49]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 49
[cli_49]: aborting job:
[8]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 30
[57]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[57]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[57]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[57]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[57]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 57
[cli_30]: [cli_57]: aborting job:
aborting job:
[8]PETSC ERROR: [58]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[58]PETSC ERROR: Error in external library
[58]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 89756 megabytes
[58]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[58]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[58]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[58]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[58]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[58]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[58]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[58]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[58]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[58]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[58]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[58]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[12]PETSC ERROR: [62]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[62]PETSC ERROR: Error in external library
[62]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 57502 megabytes
[62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[62]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[62]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[62]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[62]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[62]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[62]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[62]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[62]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[62]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[62]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[62]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[62]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[62]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[62]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 62
[58]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[58]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[58]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 58
[cli_58]: aborting job:
[11]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[11]PETSC ERROR: Error in external library
[11]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 61538 megabytes
[11]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[11]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[11]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[11]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[11]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[11]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[11]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[11]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[11]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[11]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[11]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[11]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[11]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[11]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[11]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 11
[cli_11]: aborting job:
[cli_62]: aborting job:
[8]PETSC ERROR: [15]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[15]PETSC ERROR: Error in external library
[15]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 61278 megabytes
[15]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[15]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[15]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[15]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[15]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[15]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[15]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[15]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[15]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[15]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[15]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[15]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[15]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[15]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[15]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 15
Generalized eigenproblem stored in file.
Reading COMPLEX matrices from binary files...
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Error in external library
[0]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 451597 megabytes
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[0]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[2]PETSC ERROR: Error in external library
[2]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 457041 megabytes
[2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[2]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[2]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[2]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[2]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: Error in external library
[8]PETSC ERROR: [6]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[6]PETSC ERROR: Error in external library
[6]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 64063 megabytes
[6]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[6]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[6]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[6]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[6]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[6]PETSC ERROR: [5]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[5]PETSC ERROR: Error in external library
[5]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 64043 megabytes
[5]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[5]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[5]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[5]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[5]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[16]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[16]PETSC ERROR: Error in external library
[16]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65710 megabytes
[16]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[16]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[16]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[16]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[16]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[16]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[16]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[10]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[10]PETSC ERROR: Error in external library
[10]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 64488 megabytes
[10]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[10]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[10]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[10]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[10]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[10]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[10]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[10]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[10]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[10]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[10]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[10]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[10]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[17]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[17]PETSC ERROR: Error in external library
[17]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 71786 megabytes
[17]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[17]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[17]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[17]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[17]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[17]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[32]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[32]PETSC ERROR: Error in external library
[32]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 73270 megabytes
[32]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[32]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[32]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[32]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[32]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[32]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[32]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[32]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[32]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[32]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[3]PETSC ERROR: Error in external library
[3]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 59714 megabytes
[3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[3]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[3]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[3]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[3]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[3]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[3]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[3]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[3]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[3]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[3]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[3]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[3]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[3]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[3]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[cli_3]: aborting job:
[18]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[18]PETSC ERROR: Error in external library
[18]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 74466 megabytes
[18]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[18]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[18]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[18]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[18]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[18]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[18]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[18]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[18]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[18]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[18]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[18]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[18]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[18]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[18]PETSC ERROR: [33]PETSC ERROR: [48]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[48]PETSC ERROR: Error in external library
[48]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 79966 megabytes
[48]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[48]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[48]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[48]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[48]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[48]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[48]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[48]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[48]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[48]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[48]PETSC ERROR: [7]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[7]PETSC ERROR: Error in external library
[7]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 56809 megabytes
[7]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[7]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[7]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[7]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[7]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[7]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[7]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[7]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[7]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[7]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[7]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[7]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[7]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[7]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[7]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 7
[cli_7]: aborting job:
[2]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[2]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[2]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[2]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[2]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[2]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[2]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[2]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[2]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[2]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[1]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 63961 megabytes
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[1]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[1]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[1]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[1]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[1]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[0]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[0]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[0]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[0]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[19]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[19]PETSC ERROR: Error in external library
[19]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 66131 megabytes
[19]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[19]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[19]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[19]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[19]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[19]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[19]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[19]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[19]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[19]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[19]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[19]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[19]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[19]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[19]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 19
[cli_19]: aborting job:
[6]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[6]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[6]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[6]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[6]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[6]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[6]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[6]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[6]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[5]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[5]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[5]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[5]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[5]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[5]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[5]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[5]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[16]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[16]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[16]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[16]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[16]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[16]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[16]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[16]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[23]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[23]PETSC ERROR: Error in external library
[23]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 67701 megabytes
[23]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[23]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[23]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[23]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[23]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[23]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[23]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[23]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[23]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[23]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[23]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[23]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[23]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[23]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[23]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 23
[10]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[10]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[17]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[17]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[17]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[17]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[17]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[17]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[17]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[20]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[20]PETSC ERROR: Error in external library
[20]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65476 megabytes
[20]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[20]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[20]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[20]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[20]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[20]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[20]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[20]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[20]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[20]PETSC ERROR: [35]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[35]PETSC ERROR: Error in external library
[35]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 57572 megabytes
[35]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[35]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[35]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[35]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[35]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[35]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[35]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[35]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[35]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[35]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[35]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[35]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[35]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[35]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[35]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 35
[14]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[14]PETSC ERROR: Error in external library
[14]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 76742 megabytes
[14]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[14]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[14]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[14]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[14]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[14]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[14]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[14]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[14]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[14]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[14]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[14]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[14]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[21]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[21]PETSC ERROR: Error in external library
[21]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 61748 megabytes
[21]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[21]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[21]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[21]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[21]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[21]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[21]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[21]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[21]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[21]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[21]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[21]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[21]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[32]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[32]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[32]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[32]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[32]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[39]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[39]PETSC ERROR: Error in external library
[39]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 64773 megabytes
[39]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[39]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[39]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[39]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[39]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[39]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[39]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[39]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[39]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[39]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[39]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[39]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[39]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[39]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[39]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 39
[cli_39]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 18
[37]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[37]PETSC ERROR: Error in external library
[37]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 55361 megabytes
[37]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[37]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[37]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[37]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[37]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[37]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[40]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[40]PETSC ERROR: Error in external library
[40]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65450 megabytes
[40]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[40]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[40]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[40]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[40]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[40]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[40]PETSC ERROR: [43]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[43]PETSC ERROR: Error in external library
[43]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58608 megabytes
[43]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[43]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[43]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[43]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[43]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[43]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[43]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[43]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[43]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[43]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[43]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[43]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[43]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[43]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[43]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 43
[cli_43]: aborting job:
[22]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[22]PETSC ERROR: Error in external library
[22]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65695 megabytes
[22]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[22]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[22]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[22]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[22]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[22]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[22]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[22]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[22]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[41]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[41]PETSC ERROR: Error in external library
[41]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 54285 megabytes
[41]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[41]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[41]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[41]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[41]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[41]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[41]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[41]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[41]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[41]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[41]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[41]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[41]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[41]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[41]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[48]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[48]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[48]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[48]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[55]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[55]PETSC ERROR: Error in external library
[55]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 48241 megabytes
[55]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[55]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[55]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[55]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[55]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[55]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[55]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[55]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[55]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[55]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[55]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[55]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[55]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[55]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[55]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 55
[cli_55]: aborting job:
[34]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[34]PETSC ERROR: Error in external library
[34]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58458 megabytes
[34]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[34]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[34]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[34]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[34]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[34]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[34]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[34]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[34]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[34]PETSC ERROR: [1]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[1]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[1]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[1]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[1]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[1]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[1]PETSC ERROR: [56]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[56]PETSC ERROR: Error in external library
[56]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58551 megabytes
[56]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[56]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[56]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[56]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[56]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[56]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[56]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[56]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[56]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[56]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[56]PETSC ERROR: [42]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[42]PETSC ERROR: Error in external library
[42]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 49860 megabytes
[42]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[42]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[42]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[42]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[42]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[42]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[42]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[42]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[42]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[42]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[42]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[5]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[5]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[0]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[0]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[0]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[0]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[0]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[46]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[46]PETSC ERROR: Error in external library
[46]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 71031 megabytes
[46]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[46]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[46]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[46]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[46]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[46]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[46]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[46]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[46]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[46]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[46]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[46]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[46]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[46]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[46]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[17]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[17]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 17
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 16
[cli_16]: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 2
[cli_2]: aborting job:
[21]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 21
[20]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[20]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[20]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[20]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[20]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 20
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 6
[cli_6]: aborting job:
[25]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[25]PETSC ERROR: Error in external library
[25]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 68676 megabytes
[25]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[25]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[25]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[25]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[25]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[25]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[25]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[25]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 32
[cli_32]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 10
[cli_10]: aborting job:
[37]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[37]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[37]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[37]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[37]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[37]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[37]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[37]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[40]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[40]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[40]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[40]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[40]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[40]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[14]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[14]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 14
[cli_14]: aborting job:
[1]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 48
[cli_48]: aborting job:
[cli_18]: aborting job:
[cli_5]: aborting job:
[56]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[56]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[56]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[56]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[22]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[22]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[22]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[22]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[22]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[22]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 22
[cli_21]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 0
[34]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[34]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[34]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[34]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[34]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 34
[25]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[25]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[25]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[25]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[25]PETSC ERROR: aborting job:
[42]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[42]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[42]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[42]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 42
[37]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 37
[cli_20]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 46
[cli_46]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 41
[cli_41]: aborting job:
[40]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[40]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 40
[cli_22]: aborting job:
[cli_1]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 56
[cli_56]: aborting job:
[cli_34]: aborting job:
[cli_17]: aborting job:
[cli_0]: aborting job:
[cli_42]: aborting job:
[25]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[25]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[cli_40]: aborting job:
[26]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[26]PETSC ERROR: Error in external library
[26]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58191 megabytes
[26]PETSC ERROR: [cli_37]: aborting job:
[12]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[26]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[26]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[26]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[26]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 25
[cli_25]: aborting job:
[26]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[52]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[52]PETSC ERROR: Error in external library
[52]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 58405 megabytes
[52]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[52]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[52]PETSC ERROR: [26]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[26]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[26]PETSC ERROR: [33]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[52]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[52]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[26]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[26]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[52]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[52]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[52]PETSC ERROR: [26]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[26]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[26]PETSC ERROR: [33]PETSC ERROR: [24]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[24]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[26]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 46237 megabytes
[52]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[52]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[52]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 26
[33]PETSC ERROR: Error in external library
[24]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 69315 megabytes
[24]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[24]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[24]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[24]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[cli_26]: aborting job:
[28]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[28]PETSC ERROR: Error in external library
[28]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: [52]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[52]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[52]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[52]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[9]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[9]PETSC ERROR: Error in external library
[9]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 70478 megabytes
[9]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[9]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[9]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[9]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[9]PETSC ERROR: [24]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[24]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[24]PETSC ERROR: [30]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 68179 megabytes
[28]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[28]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[28]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[28]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[28]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[38]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[38]PETSC ERROR: Error in external library
[38]PETSC ERROR: [13]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[13]PETSC ERROR: Error in external library
[13]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 70887 megabytes
[13]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[13]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[13]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[13]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[24]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[24]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[24]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 63402 megabytes
[38]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[38]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[38]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[38]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[29]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[29]PETSC ERROR: Error in external library
[29]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 66349 megabytes
[29]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[29]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[29]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[29]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[29]PETSC ERROR: [28]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[28]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[28]PETSC ERROR: [38]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[13]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[13]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[36]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[36]PETSC ERROR: Error in external library
[36]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 67737 megabytes
[36]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[36]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[36]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
[36]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[36]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[38]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[29]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[29]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 52
[cli_52]: aborting job:
[38]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[38]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[13]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[13]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[24]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[24]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[24]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[24]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[38]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[38]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[38]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[29]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[29]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[28]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[28]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[28]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[28]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[28]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[50]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[50]PETSC ERROR: Error in external library
[50]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 61866 megabytes
[50]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[50]PETSC ERROR: [9]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[9]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[9]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[9]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[36]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[36]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[36]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[36]PETSC ERROR: [38]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[38]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[38]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[13]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[13]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[13]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[13]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 24
[50]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[50]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[50]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[29]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[29]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[29]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[28]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[28]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[54]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[54]PETSC ERROR: Error in external library
[54]PETSC ERROR: [9]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[9]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[9]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[36]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[36]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[36]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[36]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 38
[13]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[13]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[cli_24]: aborting job:
[50]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[29]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[29]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 28
[cli_28]: aborting job:
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 49070 megabytes
[54]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[54]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[54]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[54]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[54]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[9]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[9]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[9]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[36]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[36]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[cli_38]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 13
[cli_13]: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 36
[50]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[50]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[50]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[50]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 29
[cli_36]: aborting job:
[50]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[50]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[50]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 9
[12]PETSC ERROR: [54]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[54]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[54]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[54]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
aborting job:
[50]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[50]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[cli_29]: aborting job:
[12]PETSC ERROR: [54]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[54]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[54]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[cli_9]: aborting job:
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 63360 megabytes
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 50
[12]PETSC ERROR: [54]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[54]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[54]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[33]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[cli_50]: aborting job:
[12]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 54
[cli_54]: aborting job:
[33]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-4.local by venkatesh Wed May 27 00:28:30 2015
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 57090 megabytes
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[12]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[30]PETSC ERROR: [33]PETSC ERROR: [12]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[8]PETSC ERROR: [30]PETSC ERROR: [33]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[30]PETSC ERROR: [33]PETSC ERROR: [8]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[12]PETSC ERROR: [30]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 33
Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 65248 megabytes
[cli_33]: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[30]PETSC ERROR: aborting job:
[8]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[45]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[45]PETSC ERROR: Error in external library
[45]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 46032 megabytes
[45]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[45]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[45]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[45]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[45]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[45]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[12]PETSC ERROR: [30]PETSC ERROR: [45]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[45]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[45]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[45]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[45]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[45]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[45]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[45]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[45]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[8]PETSC ERROR: [30]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 45
[cli_45]: aborting job:
[49]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[49]PETSC ERROR: Error in external library
[49]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 54280 megabytes
[49]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[49]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[49]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[49]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[49]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[49]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[30]PETSC ERROR: [57]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[57]PETSC ERROR: Error in external library
[57]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 54334 megabytes
[57]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[57]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[57]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-6.local by venkatesh Wed May 27 00:29:26 2015
[57]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[57]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[57]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[57]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[57]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[57]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[57]PETSC ERROR: [12]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
[49]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[49]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[49]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[49]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[49]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[49]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[49]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[49]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 49
[cli_49]: aborting job:
[8]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 76) - process 30
[57]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[57]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[57]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[57]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[57]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 57
[cli_30]: [cli_57]: aborting job:
aborting job:
[8]PETSC ERROR: [58]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[58]PETSC ERROR: Error in external library
[58]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 89756 megabytes
[58]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[58]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[58]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[58]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[58]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[58]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[58]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[58]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[58]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[58]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[58]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[58]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[12]PETSC ERROR: [62]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[62]PETSC ERROR: Error in external library
[62]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 57502 megabytes
[62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[62]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[62]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-7.local by venkatesh Wed May 27 00:28:43 2015
[62]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[62]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[62]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[62]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[62]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[62]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[62]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[62]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[62]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[62]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[62]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[62]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 62
[58]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[58]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[58]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 58
[cli_58]: aborting job:
[11]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[11]PETSC ERROR: Error in external library
[11]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 61538 megabytes
[11]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[11]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[11]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[11]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[11]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[11]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[11]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[11]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[11]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[11]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[11]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[11]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[11]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[11]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[11]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 11
[cli_11]: aborting job:
[cli_62]: aborting job:
[8]PETSC ERROR: [15]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[15]PETSC ERROR: Error in external library
[15]PETSC ERROR: Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 61278 megabytes
[15]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[15]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[15]PETSC ERROR: ./ex7 on a linux-gnu named compute-0-8.local by venkatesh Wed May 27 00:28:08 2015
[15]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=/cluster/share/apps/fblaslapack-3.4.2.tar.gz --download-mpich=/cluster/share/apps/mpich-3.1.tar.gz --download-mumps=/cluster/share/apps/MUMPS_4.10.0-p3.tar.gz --download-scalapack=/cluster/share/apps/scalapack-2.0.2.tgz --download-blacs=/cluster/share/apps/blacs-dev.tar.gz --download-parmetis=/cluster/share/apps/parmetis-4.0.2-p5.tar.gz --download-metis=/cluster/share/apps/metis-5.0.2-p3.tar.gz --download-cmake=/cluster/share/apps/cmake-2.8.12.2.tar.gz --with-scalar-type=complex --with-fortran-kernels=1 --with-large-file-io=1 --with-debugging=no
[15]PETSC ERROR: #1 MatFactorNumeric_MUMPS() line 743 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/impls/aij/mpi/mumps/mumps.c
[15]PETSC ERROR: #2 MatLUFactorNumeric() line 2893 in /cluster/share/venkatesh/petsc-3.5.3/src/mat/interface/matrix.c
[15]PETSC ERROR: #3 PCSetUp_LU() line 152 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[15]PETSC ERROR: #4 PCSetUp() line 902 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/pc/interface/precon.c
[15]PETSC ERROR: #5 KSPSetUp() line 306 in /cluster/share/venkatesh/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[15]PETSC ERROR: #6 STSetUp_Sinvert() line 145 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c
[15]PETSC ERROR: #7 STSetUp() line 301 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[15]PETSC ERROR: #8 EPSSetUp() line 207 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[15]PETSC ERROR: #9 EPSSolve() line 88 in /cluster/share/venkatesh/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[15]PETSC ERROR: #10 main() line 146 in /cluster/share/venkatesh/petsc-3.5.3/eigs/ex7.c
[15]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 15
Generalized eigenproblem stored in file.
Reading COMPLEX matrices from binary files...
[20]PETSC ERROR: [17]PETSC ERROR: ------------------------------------------------------------------------
[20]PETSC ERROR: ------------------------------------------------------------------------
Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[17]PETSC ERROR: [20]PETSC ERROR: [14]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[20]PETSC ERROR: [22]PETSC ERROR: [15]PETSC ERROR: ------------------------------------------------------------------------
[23]PETSC ERROR: ------------------------------------------------------------------------
or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[14]PETSC ERROR: [20]PETSC ERROR: [21]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[15]PETSC ERROR: [22]PETSC ERROR: ------------------------------------------------------------------------
[14]PETSC ERROR: [19]PETSC ERROR: [15]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[22]PETSC ERROR: [14]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[21]PETSC ERROR: [23]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[15]PETSC ERROR: [18]PETSC ERROR: ------------------------------------------------------------------------
[14]PETSC ERROR: [19]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[15]PETSC ERROR: [21]PETSC ERROR: ------------------------------------------------------------------------
[22]PETSC ERROR: [23]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[18]PETSC ERROR: [19]PETSC ERROR: [21]PETSC ERROR: [20]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[22]PETSC ERROR: likely location of problem given in stack below
[23]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[20]PETSC ERROR: [21]PETSC ERROR: [18]PETSC ERROR: [19]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
--------------------- Stack Frames ------------------------------------
[20]PETSC ERROR: [14]PETSC ERROR: [19]PETSC ERROR: [18]PETSC ERROR: likely location of problem given in stack below
Note: The EXACT line numbers in the stack are not available,
[14]PETSC ERROR: [15]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[14]PETSC ERROR: [20]PETSC ERROR: [15]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
INSTEAD the line number of the start of the function
[22]PETSC ERROR: [20]PETSC ERROR: [21]PETSC ERROR: likely location of problem given in stack below
is given.
[14]PETSC ERROR: [20]PETSC ERROR: [21]PETSC ERROR: [15]PETSC ERROR: INSTEAD the line number of the start of the function
[22]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[14]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[15]PETSC ERROR: is given.
[20] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[14]PETSC ERROR: [20]PETSC ERROR: [21]PETSC ERROR: [19]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[20] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[22]PETSC ERROR: [21]PETSC ERROR: [20]PETSC ERROR: INSTEAD the line number of the start of the function
[20] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[21]PETSC ERROR: [22]PETSC ERROR: [15]PETSC ERROR: [14] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
is given.
[20]PETSC ERROR: is given.
[22]PETSC ERROR: [20] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[21]PETSC ERROR: [14]PETSC ERROR: [15]PETSC ERROR: is given.
[21] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[22]PETSC ERROR: [14] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[15] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[14]PETSC ERROR: [22] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[21]PETSC ERROR: [20]PETSC ERROR: [22]PETSC ERROR: [14] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[15]PETSC ERROR: [21] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[20] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[21]PETSC ERROR: [22] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[14]PETSC ERROR: [15] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[14] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[22]PETSC ERROR: [14]PETSC ERROR: [15]PETSC ERROR: [14] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[20]PETSC ERROR: [15] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[14]PETSC ERROR: [20] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[21] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[16]PETSC ERROR: [22] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[21]PETSC ERROR: [20]PETSC ERROR: [21] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[14] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[15]PETSC ERROR: [16]PETSC ERROR: [22]PETSC ERROR: [21]PETSC ERROR: [20] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[15] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[14]PETSC ERROR: [21] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[20]PETSC ERROR: [22] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[21]PETSC ERROR: [20] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[21] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[14] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[15]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[21]PETSC ERROR: [22]PETSC ERROR: [14]PETSC ERROR: [15] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[21] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[16]PETSC ERROR: [14] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[22] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[15] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[22]PETSC ERROR: [21]PETSC ERROR: [22] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[15]PETSC ERROR: [16]PETSC ERROR: [21] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[15] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[22]PETSC ERROR: [16]PETSC ERROR: [22] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[15]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[15] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[22]PETSC ERROR: [22] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[17]PETSC ERROR: [20]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[14]PETSC ERROR: [17]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[21]PETSC ERROR: [20]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
Signal received
[17]PETSC ERROR: [20]PETSC ERROR: [21]PETSC ERROR: [15]PETSC ERROR: [14]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[23]PETSC ERROR: Signal received
[14]PETSC ERROR: likely location of problem given in stack below
Signal received
[15]PETSC ERROR: [20]PETSC ERROR: [21]PETSC ERROR: Signal received
[14]PETSC ERROR: [23]PETSC ERROR: [15]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[18]PETSC ERROR: [15]PETSC ERROR: [14]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[15]PETSC ERROR: ./ex7 on a linux-intel_superlu named nid01474 by esdveng Tue May 26 08:14:47 2015
[18]PETSC ERROR: ./ex7 on a linux-intel_superlu named nid01474 by esdveng Tue May 26 08:14:47 2015
[15]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-sdot-returns-double=0 --known-snrm2-returns-double=0 PETSC_ARCH=linux-intel_superlu -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140 --with-scalar-type=complex --with-fortran-kernels=1 -known-mpi-shared-libraries=0 --with-large-file-io=1 --with-64-bit-indices=0 --with-batch FC=ifort --with-valgrind-dir=/mnt/lustre/esd2/esdveng/valgrind --download-parmetis=/home/proj/14/esdveng/apps/parmetis-4.0.2-p5.tar.gz --download-superlu_dist=/home/proj/14/esdveng/apps/superlu_dist_3.3.tar.gz --download-metis=/home/proj/14/esdveng/apps/metis-5.0.2-p3.tar.gz
[14]PETSC ERROR: [17]PETSC ERROR: [15]PETSC ERROR: likely location of problem given in stack below
#1 User provided function() line 0 in unknown file
[17]PETSC ERROR: [19]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[22]PETSC ERROR: [17]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[19]PETSC ERROR: [22]PETSC ERROR: [17]PETSC ERROR: Signal received
[22]PETSC ERROR: [19]PETSC ERROR: [17]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
is given.
[22]PETSC ERROR: [19]PETSC ERROR: [17]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
is given.
[17] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[19]PETSC ERROR: [22]PETSC ERROR: [17]PETSC ERROR: [19] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[17] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[19]PETSC ERROR: [22]PETSC ERROR: [17]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-sdot-returns-double=0 --known-snrm2-returns-double=0 PETSC_ARCH=linux-intel_superlu -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140 --with-scalar-type=complex --with-fortran-kernels=1 -known-mpi-shared-libraries=0 --with-large-file-io=1 --with-64-bit-indices=0 --with-batch FC=ifort --with-valgrind-dir=/mnt/lustre/esd2/esdveng/valgrind --download-parmetis=/home/proj/14/esdveng/apps/parmetis-4.0.2-p5.tar.gz --download-superlu_dist=/home/proj/14/esdveng/apps/superlu_dist_3.3.tar.gz --download-metis=/home/proj/14/esdveng/apps/metis-5.0.2-p3.tar.gz
[19] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[17] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[19]PETSC ERROR: [22]PETSC ERROR: [17]PETSC ERROR: #1 User provided function() line 0 in unknown file
[16]PETSC ERROR: [17] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[19] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[19]PETSC ERROR: likely location of problem given in stack below
[17]PETSC ERROR: [19] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[16]PETSC ERROR: [17] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[19]PETSC ERROR: [17]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[19] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[17] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[16]PETSC ERROR: [19]PETSC ERROR: [17]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[19] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[17] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[16]PETSC ERROR: [19]PETSC ERROR: INSTEAD the line number of the start of the function
[17]PETSC ERROR: [16]PETSC ERROR: [19] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[17] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
is given.
[19]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[19] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
Rank 14 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 14
Rank 15 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 15
[16]PETSC ERROR: [21]PETSC ERROR: [16] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[21]PETSC ERROR: [16]PETSC ERROR: [20]PETSC ERROR: ./ex7 on a linux-intel_superlu named nid01474 by esdveng Tue May 26 08:14:47 2015
[16] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[21]PETSC ERROR: [16]PETSC ERROR: [17]PETSC ERROR: Rank 22 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 22
[20]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[16] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[21]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-sdot-returns-double=0 --known-snrm2-returns-double=0 PETSC_ARCH=linux-intel_superlu -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140 --with-scalar-type=complex --with-fortran-kernels=1 -known-mpi-shared-libraries=0 --with-large-file-io=1 --with-64-bit-indices=0 --with-batch FC=ifort --with-valgrind-dir=/mnt/lustre/esd2/esdveng/valgrind --download-parmetis=/home/proj/14/esdveng/apps/parmetis-4.0.2-p5.tar.gz --download-superlu_dist=/home/proj/14/esdveng/apps/superlu_dist_3.3.tar.gz --download-metis=/home/proj/14/esdveng/apps/metis-5.0.2-p3.tar.gz
[16]PETSC ERROR: [17]PETSC ERROR: [20]PETSC ERROR: #1 User provided function() line 0 in unknown file
[16] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
Signal received
[17]PETSC ERROR: [16]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[18]PETSC ERROR: [16] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[17]PETSC ERROR: [16]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[16] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[18]PETSC ERROR: [17]PETSC ERROR: INSTEAD the line number of the start of the function
[16]PETSC ERROR: [18]PETSC ERROR: ./ex7 on a linux-intel_superlu named nid01474 by esdveng Tue May 26 08:14:47 2015
[16] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
is given.
[16]PETSC ERROR: [17]PETSC ERROR: [16] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[18]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-sdot-returns-double=0 --known-snrm2-returns-double=0 PETSC_ARCH=linux-intel_superlu -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140 --with-scalar-type=complex --with-fortran-kernels=1 -known-mpi-shared-libraries=0 --with-large-file-io=1 --with-64-bit-indices=0 --with-batch FC=ifort --with-valgrind-dir=/mnt/lustre/esd2/esdveng/valgrind --download-parmetis=/home/proj/14/esdveng/apps/parmetis-4.0.2-p5.tar.gz --download-superlu_dist=/home/proj/14/esdveng/apps/superlu_dist_3.3.tar.gz --download-metis=/home/proj/14/esdveng/apps/metis-5.0.2-p3.tar.gz
[18] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[23]PETSC ERROR: [17]PETSC ERROR: [18]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[18] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[23]PETSC ERROR: [18]PETSC ERROR: INSTEAD the line number of the start of the function
[19]PETSC ERROR: [18] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[23]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
is given.
[18]PETSC ERROR: [19]PETSC ERROR: [18] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[18]PETSC ERROR: [23] MatLUFactorNumeric_SuperLU_DIST line 273 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
Rank 20 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 20
Rank 21 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 21
[23]PETSC ERROR: [19]PETSC ERROR: [18] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[23] MatLUFactorNumeric line 2882 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/mat/interface/matrix.c
[16]PETSC ERROR: [23]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[18]PETSC ERROR: [23] PCSetUp_LU line 99 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/pc/impls/factor/lu/lu.c
[19]PETSC ERROR: [18] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
[19]PETSC ERROR: [18]PETSC ERROR: [23] KSPSetUp line 220 /mnt/lustre/esd2/esdveng/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c
[18] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[23]PETSC ERROR: [16]PETSC ERROR: [23] STSetUp_Shift line 103 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/impls/shift/shift.c
[18]PETSC ERROR: [23]PETSC ERROR: [19]PETSC ERROR: [18] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[23] STSetUp line 269 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c
Signal received
[19]PETSC ERROR: [23]PETSC ERROR: [16]PETSC ERROR: #1 User provided function() line 0 in unknown file
[23] EPSSetUp line 58 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssetup.c
[16]PETSC ERROR: [23]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
Rank 17 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 17
[16]PETSC ERROR: [23] EPSSolve line 83 /mnt/lustre/esd2/esdveng/petsc-3.5.3/slepc-3.5.3/src/eps/interface/epssolve.c
[16]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-sdot-returns-double=0 --known-snrm2-returns-double=0 PETSC_ARCH=linux-intel_superlu -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140 --with-scalar-type=complex --with-fortran-kernels=1 -known-mpi-shared-libraries=0 --with-large-file-io=1 --with-64-bit-indices=0 --with-batch FC=ifort --with-valgrind-dir=/mnt/lustre/esd2/esdveng/valgrind --download-parmetis=/home/proj/14/esdveng/apps/parmetis-4.0.2-p5.tar.gz --download-superlu_dist=/home/proj/14/esdveng/apps/superlu_dist_3.3.tar.gz --download-metis=/home/proj/14/esdveng/apps/metis-5.0.2-p3.tar.gz
[18]PETSC ERROR: [16]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[18]PETSC ERROR: Signal received
[18]PETSC ERROR: [23]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[18]PETSC ERROR: [23]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
Signal received
[23]PETSC ERROR: [18]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[23]PETSC ERROR: [18]PETSC ERROR: ./ex7 on a linux-intel_superlu named nid01474 by esdveng Tue May 26 08:14:47 2015
[23]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-sdot-returns-double=0 --known-snrm2-returns-double=0 PETSC_ARCH=linux-intel_superlu -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140 --with-scalar-type=complex --with-fortran-kernels=1 -known-mpi-shared-libraries=0 --with-large-file-io=1 --with-64-bit-indices=0 --with-batch FC=ifort --with-valgrind-dir=/mnt/lustre/esd2/esdveng/valgrind --download-parmetis=/home/proj/14/esdveng/apps/parmetis-4.0.2-p5.tar.gz --download-superlu_dist=/home/proj/14/esdveng/apps/superlu_dist_3.3.tar.gz --download-metis=/home/proj/14/esdveng/apps/metis-5.0.2-p3.tar.gz
[23]PETSC ERROR: Rank 19 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 19
Rank 16 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 16
Rank 18 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 18
Rank 23 [Tue May 26 08:14:47 2015] [c7-0c2s0n2] application called MPI_Abort(MPI_COMM_WORLD, 59) - process 23
_pmiu_daemon(SIGCHLD): [NID 01474] [c7-0c2s0n2] [Tue May 26 08:14:47 2015] PE RANK 14 exit signal Aborted
[NID 01474] 2015-05-26 18:46:18 Apid 406256: initiated application termination
Application 406256 exit codes: 134
Application 406256 resources: utime ~0s, stime ~2s, Rss ~13516, inblocks ~1675, outblocks ~287
