[petsc-users] MUMPS error
venkatesh g venkateshgk.j at gmail.com
Sat May 23 06:44:21 CDT 2015
The same eigenproblem runs with 120 GB RAM in a serial machine in Matlab.
In Cray I fired with 240*4 GB RAM in parallel. So it has to go in right ?
And for small matrices it is having negative scaling i.e 24 core is running
faster.
I have attached the submission script.
Pls see.. Kindly let me know
cheers,
Venkatesh
On Sat, May 23, 2015 at 4:58 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, May 23, 2015 at 2:39 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
>> Hi again,
>> I have installed the Petsc and Slepc in Cray with intel compilers with
>> Mumps.
>> I am getting this error when I solve eigenvalue problem with large
>> matrices: [201]PETSC ERROR: Error reported by MUMPS in numerical
>> factorization phase: Cannot allocate required memory 9632 megabytes
> It ran out of memory on the node.
>> Also it is again not scaling well for small matrices.
> MUMPS strong scaling for small matrices is not very good. Weak scaling is
> looking at big matrices.
>   Thanks,
>      Matt
>> Kindly let me know what to do.
>> cheers,
>> Venkatesh
>> On Tue, May 19, 2015 at 3:02 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, May 19, 2015 at 1:04 AM, venkatesh g <venkateshgk.j at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I have attached the log of the command which I gave in the master node:
>>>> make streams NPMAX=32
>>>> I dont know why it says 'It appears you have only 1 node'. But other
>>>> codes run in parallel with good scaling on 8 nodes.
>>> If you look at the STREAMS numbers, you can see that your system is only
>>> able to support about 2 cores with the
>>> available memory bandwidth. Thus for bandwidth constrained operations
>>> (almost everything in sparse linear algebra
>>> and solvers), your speedup will not be bigger than 2.
>>> Other codes may do well on this machine, but they would be compute
>>> constrained, using things like DGEMM.
>>>   Thanks,
>>>      Matt
>>>> Kindly let me know.
>>>> Venkatesh
>>>> On Mon, May 18, 2015 at 11:21 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>>>    Run the streams benchmark on this system and send the results.
>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#computers
>>>>> > On May 18, 2015, at 11:14 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>>> wrote:
>>>>> > Hi,
>>>>> > I have emailed the mumps-user list.
>>>>> > Actually the cluster has 8 nodes with 16 cores, and other codes
>>>>> scale well.
>>>>> > I wanted to ask if this job takes much time, then if I submit on
>>>>> more cores, I have to increase the icntl(14).. which would again take long
>>>>> time.
>>>>> > So is there another way ?
>>>>> > cheers,
>>>>> > Venkatesh
>>>>> > On Mon, May 18, 2015 at 7:16 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>> > On Mon, May 18, 2015 at 8:29 AM, venkatesh g <
>>>>> venkateshgk.j at gmail.com> wrote:
>>>>> > Hi I have attached the performance logs for 2 jobs on different
>>>>> processors. I had to increase the workspace icntl(14) when I submit on more
>>>>> cores since it is failing with small value of icntl(14).
>>>>> > 1. performance_log1.txt is run on 8 cores (option given
>>>>> -mat_mumps_icntl_14 200)
>>>>> > 2. performance_log2.txt is run on 2 cores (option given
>>>>> -mat_mumps_icntl_14 85  )
>>>>> > 1) Your number of iterates increased from 7600 to 9600, but that is
>>>>> a relatively small effect
>>>>> > 2) MUMPS is just taking a lot longer to do forward/backward solve.
>>>>> You might try emailing
>>>>> > the list for them. However, I would bet that your system has enough
>>>>> bandwidth for 2 procs
>>>>> > and not much more.
>>>>> >   Thanks,
>>>>> >      Matt
>>>>> > Venkatesh
>>>>> > On Sun, May 17, 2015 at 6:13 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>> > On Sun, May 17, 2015 at 1:38 AM, venkatesh g <
>>>>> > Hi, Thanks for the information. I now increased the workspace by
>>>>> adding '-mat_mumps_icntl_14 100'
>>>>> > It works. However, the problem is, if I submit in 1 core I get the
>>>>> answer in 200 secs, but with 4 cores and '-mat_mumps_icntl_14 100' it takes
>>>>> 3500secs.
>>>>> > Send the output of -log_summary for all performance queries.
>>>>> Otherwise we are just guessing.
>>>>> >     Matt
>>>>> > My command line is: 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1
>>>>> -st_type sinvert -eps_max_it 5000 -st_ksp_type preonly -st_pc_type lu
>>>>> -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14 100'
>>>>> > Kindly let me know.
>>>>> > Venkatesh
>>>>> > On Sat, May 16, 2015 at 7:10 PM, David Knezevic <
>>>>> david.knezevic at akselos.com> wrote:
>>>>> > On Sat, May 16, 2015 at 8:08 AM, venkatesh g <
>>>>> > Hi,
>>>>> > I am trying to solving AX=lambda BX eigenvalue problem.
>>>>> > A and B are of sizes 3600x3600
>>>>> > I run with this command :
>>>>> > 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1 -st_type sinvert
>>>>> -st_pc_factor_mat_solver_package mumps'
>>>>> > I get this error: (I get result only when I give 1 or 2 processors)
>>>>> > Reading COMPLEX matrices from binary files...
>>>>> > [0]PETSC ERROR: --------------------- Error Message
>>>>> > [0]PETSC ERROR: Error in external library!
>>>>> > [0]PETSC ERROR: Error reported by MUMPS in numerical factorization
>>>>> phase: INFO(1)=-9, INFO(2)=2024
>>>>> > The MUMPS error types are described in Chapter 7 of the MUMPS
>>>>> manual. In this case you have INFO(1)=-9, which is explained in the manual
>>>>> as:
>>>>> > "–9 Main internal real/complex workarray S too small. If INFO(2) is
>>>>> positive, then the number of entries that are missing in S at the moment
>>>>> when the error is raised is available in INFO(2). If INFO(2) is negative,
>>>>> then its absolute value should be multiplied by 1 million. If an error –9
>>>>> occurs, the user should increase the value of ICNTL(14) before calling the
>>>>> factorization (JOB=2) again, except if ICNTL(23) is provided, in which case
>>>>> ICNTL(23) should be increased."
>>>>> > This says that you should use ICTNL(14) to increase the working
>>>>> space size:
>>>>> > "ICNTL(14) is accessed by the host both during the analysis and the
>>>>> factorization phases. It corresponds to the percentage increase in the
>>>>> estimated working space. When significant extra fill-in is caused by
>>>>> numerical pivoting, increasing ICNTL(14) may help. Except in special cases,
>>>>> the default value is 20 (which corresponds to a 20 % increase)."
>>>>> > So, for example, you can avoid this error via the following command
>>>>> line argument to PETSc: "-mat_mumps_icntl_14 30", where 30 indicates that
>>>>> we allow a 30% increase in the workspace instead of the default 20%.
>>>>> > David
>>>>> > What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> > -- Norbert Wiener
>>>>> experiments lead.
>>>>> > -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150523/6c8c2f04/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150523/6c8c2f04/attachment.obj>
