[petsc-users] MUMPS error
Matthew Knepley
knepley at gmail.com
Sat May 23 06:28:58 CDT 2015
On Sat, May 23, 2015 at 2:39 AM, venkatesh g <venkateshgk.j at gmail.com>
wrote:
> Hi again,
> I have installed the Petsc and Slepc in Cray with intel compilers with
> Mumps.
> I am getting this error when I solve eigenvalue problem with large
> matrices: [201]PETSC ERROR: Error reported by MUMPS in numerical
> factorization phase: Cannot allocate required memory 9632 megabytes
It ran out of memory on the node.
> Also it is again not scaling well for small matrices.
MUMPS strong scaling for small matrices is not very good. Weak scaling is
looking at big matrices.
Matt
> Kindly let me know what to do.
> cheers,
> Venkatesh
> On Tue, May 19, 2015 at 3:02 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, May 19, 2015 at 1:04 AM, venkatesh g <venkateshgk.j at gmail.com>
>> wrote:
>>> Hi,
>>> I have attached the log of the command which I gave in the master node:
>>> make streams NPMAX=32
>>> I dont know why it says 'It appears you have only 1 node'. But other
>>> codes run in parallel with good scaling on 8 nodes.
>> If you look at the STREAMS numbers, you can see that your system is only
>> able to support about 2 cores with the
>> available memory bandwidth. Thus for bandwidth constrained operations
>> (almost everything in sparse linear algebra
>> and solvers), your speedup will not be bigger than 2.
>> Other codes may do well on this machine, but they would be compute
>> constrained, using things like DGEMM.
>> Thanks,
>> Matt
>>> Kindly let me know.
>>> Venkatesh
>>> On Mon, May 18, 2015 at 11:21 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>> Run the streams benchmark on this system and send the results.
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#computers
>>>> > On May 18, 2015, at 11:14 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>> wrote:
>>>> > Hi,
>>>> > I have emailed the mumps-user list.
>>>> > Actually the cluster has 8 nodes with 16 cores, and other codes scale
>>>> well.
>>>> > I wanted to ask if this job takes much time, then if I submit on more
>>>> cores, I have to increase the icntl(14).. which would again take long time.
>>>> > So is there another way ?
>>>> > cheers,
>>>> > Venkatesh
>>>> > On Mon, May 18, 2015 at 7:16 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>> > On Mon, May 18, 2015 at 8:29 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>> wrote:
>>>> > Hi I have attached the performance logs for 2 jobs on different
>>>> processors. I had to increase the workspace icntl(14) when I submit on more
>>>> cores since it is failing with small value of icntl(14).
>>>> > 1. performance_log1.txt is run on 8 cores (option given
>>>> -mat_mumps_icntl_14 200)
>>>> > 2. performance_log2.txt is run on 2 cores (option given
>>>> -mat_mumps_icntl_14 85 )
>>>> > 1) Your number of iterates increased from 7600 to 9600, but that is a
>>>> relatively small effect
>>>> > 2) MUMPS is just taking a lot longer to do forward/backward solve.
>>>> You might try emailing
>>>> > the list for them. However, I would bet that your system has enough
>>>> bandwidth for 2 procs
>>>> > and not much more.
>>>> > Thanks,
>>>> > Matt
>>>> > Venkatesh
>>>> > On Sun, May 17, 2015 at 6:13 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>> > On Sun, May 17, 2015 at 1:38 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>> wrote:
>>>> > Hi, Thanks for the information. I now increased the workspace by
>>>> adding '-mat_mumps_icntl_14 100'
>>>> > It works. However, the problem is, if I submit in 1 core I get the
>>>> answer in 200 secs, but with 4 cores and '-mat_mumps_icntl_14 100' it takes
>>>> 3500secs.
>>>> > Send the output of -log_summary for all performance queries.
>>>> Otherwise we are just guessing.
>>>> > Matt
>>>> > My command line is: 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1
>>>> -st_type sinvert -eps_max_it 5000 -st_ksp_type preonly -st_pc_type lu
>>>> -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14 100'
>>>> > Kindly let me know.
>>>> > Venkatesh
>>>> > On Sat, May 16, 2015 at 7:10 PM, David Knezevic <
>>>> david.knezevic at akselos.com> wrote:
>>>> > On Sat, May 16, 2015 at 8:08 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>> wrote:
>>>> > Hi,
>>>> > I am trying to solving AX=lambda BX eigenvalue problem.
>>>> > A and B are of sizes 3600x3600
>>>> > I run with this command :
>>>> > 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1 -st_type sinvert
>>>> -st_pc_factor_mat_solver_package mumps'
>>>> > I get this error: (I get result only when I give 1 or 2 processors)
>>>> > Reading COMPLEX matrices from binary files...
>>>> > [0]PETSC ERROR: --------------------- Error Message
>>>> > [0]PETSC ERROR: Error in external library!
>>>> > [0]PETSC ERROR: Error reported by MUMPS in numerical factorization
>>>> phase: INFO(1)=-9, INFO(2)=2024
>>>> > The MUMPS error types are described in Chapter 7 of the MUMPS manual.
>>>> In this case you have INFO(1)=-9, which is explained in the manual as:
>>>> > "–9 Main internal real/complex workarray S too small. If INFO(2) is
>>>> positive, then the number of entries that are missing in S at the moment
>>>> when the error is raised is available in INFO(2). If INFO(2) is negative,
>>>> then its absolute value should be multiplied by 1 million. If an error –9
>>>> occurs, the user should increase the value of ICNTL(14) before calling the
>>>> factorization (JOB=2) again, except if ICNTL(23) is provided, in which case
>>>> ICNTL(23) should be increased."
>>>> > This says that you should use ICTNL(14) to increase the working space
>>>> size:
>>>> > "ICNTL(14) is accessed by the host both during the analysis and the
>>>> factorization phases. It corresponds to the percentage increase in the
>>>> estimated working space. When significant extra fill-in is caused by
>>>> numerical pivoting, increasing ICNTL(14) may help. Except in special cases,
>>>> the default value is 20 (which corresponds to a 20 % increase)."
>>>> > So, for example, you can avoid this error via the following command
>>>> line argument to PETSc: "-mat_mumps_icntl_14 30", where 30 indicates that
>>>> we allow a 30% increase in the workspace instead of the default 20%.
>>>> > David
>>>> > What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> > -- Norbert Wiener
>>>> experiments lead.
>>>> > -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150523/9e5e3be0/attachment-0001.html>
