[petsc-users] Block size
Barry Smith
bsmith at mcs.anl.gov
Fri May 22 10:36:36 CDT 2015
Eric,
There is a performance tradeoff between keeping the blocks full (with some zero padding)(which also allows one to use the BAIJ format) and treating them as fully sparse. Where one should switch between the formats is problem dependent and I don't even have any good rule of thumb for knowing when to switch. My recommendation is to write the preallocation code general enough to allow trivially switching between the two representations; that is, have code that preallocates by block and code that preallocates by point and have a run time switch between them. With that capability you will always have the freedom to use which every approach makes sense for a given run; for example for smaller runs you likely just want to run for speed and use the blocked preallocation, to squeeze the largest problem you can run you would use the point format and it will be somewhat slower but at least you will not run out of memory.
Barry
> On May 22, 2015, at 9:05 AM, Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi,
> I have another question about this.
> I am actually working on a multi-variable problem (chemical species and voltage in brain), but all variables are not fully coupled with others. Let's say I have scalar variables A, B, C and D coupled like this:
> A B C D
> A x x
> B x x
> C x x
> D x x x x
> I first number my variables continuously on each vertex, so that I have a "block size" of 4 on each vertex.
> With an {SEQ,MPI}AIJ matrix, I can preallocate the matrix by "scalar lines" them minimizing the memory allocated for the structure.
> My question is: Do all preconditionners are able to handle "sparse blocks" when block_size > 1 in {SEQ,MPI}AIJ matrix? Do they still have some gain with "sparse blocks"?
> Right now, I am over-allocation {SEQ,MPI}AIJ matrix since I use MatXAIJSetPreallocation with bs=4... But I am thinking of writing a different function to not over-allocate memory when a block_size>1 {SEQ,MPI}AIJ matrix with "sparse blocks" is used. For example, for a 2d problem, if I use bs=4 I have:
> Mat Object: (Solveur_Direct) 1 MPI processes
> type: seqaij
> rows=8588, cols=8588, bs=4
> total: nonzeros=232816, allocated nonzeros=234832
> total number of mallocs used during MatSetValues calls =0
> using I-node routines: found 2147 nodes, limit used is 5
> but if I use bs=1 I have:
> type: seqaij
> total: nonzeros=100516, allocated nonzeros=100516
> not using I-node routines
> which is 2 times less memory for this (toy)-problem. I am partly responsible for this, since I count non-zeros for blocks because I am forced to do so if use MatXAIJSetPreallocation. Since we think to go very large, let's say 100M unknowns, I want to avoid such over-allocation. But before modifying this, I am querying your knowledge...
> thanks!
> Eric
> On 10/09/2014 04:19 AM, Barry Smith wrote:
>> On Oct 9, 2014, at 3:12 AM, Natacha BEREUX <natacha.bereux at gmail.com> wrote:
>>> Dear PETSc users,
>>> I am a bit confused about blocksizes in MPI matrices.
>>> I define a MPI matrix A with a certain blocksize, let say bs = 3.
>>> As far as I understand, the sparse pattern of the matrix A is made of square blocks of size 3x3, regardless of the actual values of the terms of A.
>>> Am I right ?
>> Only if you use the BAIJ or SBAIJ matrix format. If you use AIJ then it still stores the values without regard to the block size but it carries knowledge of the block size around and that gets used in some places such as the GAMG solver.
>>> The matrix A is distributed among several processors: does the local number of rows of A on each processor have to be a multiple of bs ?
>> Correct
>>> I want to use a multigrid preconditionner to solve the linear system of matrix A : A x = b
>>> Is it mandatory to define the right hand side b as a vector with the same blocksize bs=3 ?
>> It probably doesn’t matter, but if you know something has an associated block size it is generally best to capture it as soon as you can in the problem.
>> Barry
>>> Thank you very much of your help,
>>> Best regards,
>>> Natacha
