[petsc-users] MUMPS error
venkatesh g venkateshgk.j at gmail.com
Tue May 19 01:04:48 CDT 2015
I have attached the log of the command which I gave in the master node:
make streams NPMAX=32
I dont know why it says 'It appears you have only 1 node'. But other codes
run in parallel with good scaling on 8 nodes.
Kindly let me know.
Venkatesh
On Mon, May 18, 2015 at 11:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Run the streams benchmark on this system and send the results.
> http://www.mcs.anl.gov/petsc/documentation/faq.html#computers
> > On May 18, 2015, at 11:14 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
> > Hi,
> > I have emailed the mumps-user list.
> > Actually the cluster has 8 nodes with 16 cores, and other codes scale
> well.
> > I wanted to ask if this job takes much time, then if I submit on more
> cores, I have to increase the icntl(14).. which would again take long time.
> > So is there another way ?
> > cheers,
> > Venkatesh
> > On Mon, May 18, 2015 at 7:16 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Mon, May 18, 2015 at 8:29 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
> > Hi I have attached the performance logs for 2 jobs on different
> processors. I had to increase the workspace icntl(14) when I submit on more
> cores since it is failing with small value of icntl(14).
> > 1. performance_log1.txt is run on 8 cores (option given
> -mat_mumps_icntl_14 200)
> > 2. performance_log2.txt is run on 2 cores (option given
> -mat_mumps_icntl_14 85  )
> > 1) Your number of iterates increased from 7600 to 9600, but that is a
> relatively small effect
> > 2) MUMPS is just taking a lot longer to do forward/backward solve. You
> might try emailing
> > the list for them. However, I would bet that your system has enough
> bandwidth for 2 procs
> > and not much more.
> >   Thanks,
> >      Matt
> > Venkatesh
> > On Sun, May 17, 2015 at 6:13 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Sun, May 17, 2015 at 1:38 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
> > Hi, Thanks for the information. I now increased the workspace by adding
> '-mat_mumps_icntl_14 100'
> > It works. However, the problem is, if I submit in 1 core I get the
> answer in 200 secs, but with 4 cores and '-mat_mumps_icntl_14 100' it takes
> 3500secs.
> > Send the output of -log_summary for all performance queries. Otherwise
> we are just guessing.
> >     Matt
> > My command line is: 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1
> -st_type sinvert -eps_max_it 5000 -st_ksp_type preonly -st_pc_type lu
> -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14 100'
> > Kindly let me know.
> > Venkatesh
> > On Sat, May 16, 2015 at 7:10 PM, David Knezevic <
> david.knezevic at akselos.com> wrote:
> > On Sat, May 16, 2015 at 8:08 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
> > Hi,
> > I am trying to solving AX=lambda BX eigenvalue problem.
> > A and B are of sizes 3600x3600
> > I run with this command :
> > 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1 -st_type sinvert
> -st_pc_factor_mat_solver_package mumps'
> > I get this error: (I get result only when I give 1 or 2 processors)
> > Reading COMPLEX matrices from binary files...
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Error in external library!
> > [0]PETSC ERROR: Error reported by MUMPS in numerical factorization
> phase: INFO(1)=-9, INFO(2)=2024
> > The MUMPS error types are described in Chapter 7 of the MUMPS manual. In
> this case you have INFO(1)=-9, which is explained in the manual as:
> > "–9 Main internal real/complex workarray S too small. If INFO(2) is
> positive, then the number of entries that are missing in S at the moment
> when the error is raised is available in INFO(2). If INFO(2) is negative,
> then its absolute value should be multiplied by 1 million. If an error –9
> occurs, the user should increase the value of ICNTL(14) before calling the
> factorization (JOB=2) again, except if ICNTL(23) is provided, in which case
> ICNTL(23) should be increased."
> > This says that you should use ICTNL(14) to increase the working space
> size:
> > "ICNTL(14) is accessed by the host both during the analysis and the
> factorization phases. It corresponds to the percentage increase in the
> estimated working space. When significant extra fill-in is caused by
> numerical pivoting, increasing ICNTL(14) may help. Except in special cases,
> the default value is 20 (which corresponds to a 20 % increase)."
> > So, for example, you can avoid this error via the following command line
> argument to PETSc: "-mat_mumps_icntl_14 30", where 30 indicates that we
> allow a 30% increase in the workspace instead of the default 20%.
> > David
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150519/6f0eccf1/attachment-0001.html>
cd src/benchmarks/streams; /usr/bin/gmake  --no-print-directory streams
/cluster/share/venkatesh/petsc-3.5.3/linux-gnu/bin/mpicc -o MPIVersion.o -c -fPIC -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O   -I/cluster/share/venkatesh/petsc-3.5.3/include -I/cluster/share/venkatesh/petsc-3.5.3/linux-gnu/include    `pwd`/MPIVersion.c
/cluster/share/venkatesh/petsc-3.5.3/src/benchmarks/streams/MPIVersion.c: In function ‘main’:
/cluster/share/venkatesh/petsc-3.5.3/src/benchmarks/streams/MPIVersion.c:99: warning: value computed is not used
/cluster/share/venkatesh/petsc-3.5.3/src/benchmarks/streams/MPIVersion.c:103: warning: value computed is not used
Number of MPI processes 1
Process 0 earth.ceas.iisc.ernet.in
Function      Rate (MB/s)
Copy:        6902.4288
Scale:       6686.1477
Add:         7267.3209
Triad:       7347.4177
Number of MPI processes 2
Process 1 earth.ceas.iisc.ernet.in
Copy:       17086.9319
Scale:      16523.1725
Add:        18397.7537
Triad:      18843.7471
Number of MPI processes 3
Process 2 earth.ceas.iisc.ernet.in
Copy:       18378.9967
Scale:      17876.0998
Add:        19955.7187
Triad:      20279.8005
Number of MPI processes 4
Process 3 earth.ceas.iisc.ernet.in
Copy:       18317.7102
Scale:      17908.8977
Add:        20086.3669
Triad:      20595.9138
Number of MPI processes 5
Process 4 earth.ceas.iisc.ernet.in
Copy:       18014.6277
Scale:      17749.5260
Add:        20221.8266
Triad:      20523.3457
Number of MPI processes 6
Process 5 earth.ceas.iisc.ernet.in
Copy:       17707.3799
Scale:      17312.7292
Add:        19866.6142
Triad:      20421.0646
Number of MPI processes 7
Process 6 earth.ceas.iisc.ernet.in
Copy:       18032.9462
Scale:      18227.9864
Add:        20153.5011
Triad:      20272.5224
Number of MPI processes 8
Process 7 earth.ceas.iisc.ernet.in
Copy:       18157.8195
Scale:      17795.5266
Add:        20279.1823
Triad:      20429.6992
Number of MPI processes 9
Process 8 earth.ceas.iisc.ernet.in
Copy:       17992.4195
Scale:      17895.6520
Add:        20261.2123
Triad:      20268.0128
Number of MPI processes 10
Process 9 earth.ceas.iisc.ernet.in
Copy:       18032.9722
Scale:      17803.6405
Add:        20275.4183
Triad:      20331.5734
Number of MPI processes 11
Process 10 earth.ceas.iisc.ernet.in
Copy:       17979.6366
Scale:      17938.5844
Add:        20025.9127
Triad:      20264.9269
Number of MPI processes 12
Process 11 earth.ceas.iisc.ernet.in
Copy:       17999.2694
Scale:      17836.7113
Add:        20215.8741
Triad:      20148.6332
Number of MPI processes 13
Process 12 earth.ceas.iisc.ernet.in
Copy:       17843.2142
Scale:      17913.6416
Add:        20051.1341
Triad:      20248.3982
Number of MPI processes 14
Process 13 earth.ceas.iisc.ernet.in
Copy:       17726.6043
Scale:      17846.1749
Add:        20133.6683
Triad:      20116.7300
Number of MPI processes 15
Process 14 earth.ceas.iisc.ernet.in
Copy:       17748.3574
Scale:      17730.9431
Add:        20131.9446
Triad:      20140.4377
Number of MPI processes 16
Process 15 earth.ceas.iisc.ernet.in
Copy:       17851.9776
Scale:      17612.7354
Add:        20050.5608
Triad:      20294.3173
Number of MPI processes 17
Process 16 earth.ceas.iisc.ernet.in
Copy:       17736.6966
Scale:      17799.4394
Add:        20238.6540
Triad:      19922.1132
Number of MPI processes 18
Process 17 earth.ceas.iisc.ernet.in
Copy:       17713.9050
Scale:      17704.2554
Add:        19988.1965
Triad:      20111.7783
Number of MPI processes 19
Process 18 earth.ceas.iisc.ernet.in
Copy:       17845.2428
Scale:      17716.9512
Add:        19960.8970
Triad:      19996.5972
Number of MPI processes 20
Process 19 earth.ceas.iisc.ernet.in
Copy:       17679.7657
Scale:      17788.3173
Add:        19918.5972
Triad:      20140.1278
Number of MPI processes 21
Process 20 earth.ceas.iisc.ernet.in
Copy:       17729.0197
Scale:      17551.8412
Add:        19939.2570
Triad:      20018.7010
Number of MPI processes 22
Process 21 earth.ceas.iisc.ernet.in
Copy:       17718.9268
Scale:      17646.6164
Add:        19958.9034
Triad:      20019.6979
Number of MPI processes 23
Process 22 earth.ceas.iisc.ernet.in
Copy:       17726.1052
Scale:      17586.0347
Add:        19981.6659
Triad:      20129.2205
Number of MPI processes 24
Process 23 earth.ceas.iisc.ernet.in
Copy:       17679.1036
Scale:      17557.5055
Add:        20004.1105
Triad:      20058.5391
Number of MPI processes 25
Process 24 earth.ceas.iisc.ernet.in
Copy:       17701.5456
Scale:      17660.2441
Add:        19982.5803
Triad:      20008.9784
Number of MPI processes 26
Process 25 earth.ceas.iisc.ernet.in
Copy:       17689.5153
Scale:      17690.2272
Add:        19992.6007
Triad:      20009.8738
Number of MPI processes 27
Process 26 earth.ceas.iisc.ernet.in
Copy:       17679.5819
Scale:      17723.8157
Add:        20062.3149
Triad:      20088.0081
Number of MPI processes 28
Process 27 earth.ceas.iisc.ernet.in
Copy:       17713.3862
Scale:      17653.8698
Add:        20033.4436
Triad:      20090.3366
Number of MPI processes 29
Process 28 earth.ceas.iisc.ernet.in
Copy:       17715.5523
Scale:      17658.6908
Add:        19999.5113
Triad:      20055.8129
Number of MPI processes 30
Process 29 earth.ceas.iisc.ernet.in
Copy:       17706.5495
Scale:      17632.8140
Add:        20064.5500
Triad:      20080.0843
Number of MPI processes 31
Process 30 earth.ceas.iisc.ernet.in
Copy:       17729.5745
Scale:      17674.5220
Add:        20044.3250
Triad:      20092.4184
Number of MPI processes 32
Process 31 earth.ceas.iisc.ernet.in
Copy:       17731.4969
Scale:      17660.6923
Add:        20066.4112
Triad:      20130.9258
np  speedup
1 1.0
2 2.56
3 2.76
4 2.8
5 2.79
6 2.78
7 2.76
8 2.78
9 2.76
10 2.77
11 2.76
12 2.74
13 2.76
14 2.74
15 2.74
16 2.76
17 2.71
18 2.74
19 2.72
20 2.74
21 2.72
22 2.72
23 2.74
24 2.73
25 2.72
26 2.72
27 2.73
28 2.73
29 2.73
30 2.73
31 2.73
32 2.74
Estimation of possible speedup of MPI programs based on Streams benchmark.
It appears you have 1 node(s)
Unable to open matplotlib to plot speedup
