[petsc-users] MUMPS error
Hong hzhang at mcs.anl.gov
Mon May 18 11:41:19 CDT 2015
venkatesh:
The differences are in MatSolve() as Matt said.
The questions are
1. why np=2 calls 7624 MatSolve(), while np=8 calls 9600 times? With
slepc/sinvert/lu, would both runs use same algorithm?
2. with np=2, each MatSolve takes 0.027 sec, while np=8 takes 0.065 sec.
Would MatSolve be scalable?
The matrix factors for np=2 and 8 might be very different.
We would like to know what mumps' developer say about it.
Hong
> I have emailed the mumps-user list.
> Actually the cluster has 8 nodes with 16 cores, and other codes scale
> well.
> I wanted to ask if this job takes much time, then if I submit on more
> cores, I have to increase the icntl(14).. which would again take long time.
> So is there another way ?
> cheers,
> Venkatesh
> On Mon, May 18, 2015 at 7:16 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, May 18, 2015 at 8:29 AM, venkatesh g <venkateshgk.j at gmail.com>
>> wrote:
>>> Hi I have attached the performance logs for 2 jobs on different
>>> processors. I had to increase the workspace icntl(14) when I submit on more
>>> cores since it is failing with small value of icntl(14).
>>> 1. performance_log1.txt is run on 8 cores (option given
>>> -mat_mumps_icntl_14 200)
>>> 2. performance_log2.txt is run on 2 cores (option given
>>> -mat_mumps_icntl_14 85  )
>> 1) Your number of iterates increased from 7600 to 9600, but that is a
>> relatively small effect
>> 2) MUMPS is just taking a lot longer to do forward/backward solve. You
>> might try emailing
>> the list for them. However, I would bet that your system has enough
>> bandwidth for 2 procs
>> and not much more.
>>   Thanks,
>>      Matt
>>> Venkatesh
>>> On Sun, May 17, 2015 at 6:13 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Sun, May 17, 2015 at 1:38 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>> wrote:
>>>>> Hi, Thanks for the information. I now increased the workspace by
>>>>> adding '-mat_mumps_icntl_14 100'
>>>>> It works. However, the problem is, if I submit in 1 core I get the
>>>>> answer in 200 secs, but with 4 cores and '-mat_mumps_icntl_14 100' it takes
>>>>> 3500secs.
>>>> Send the output of -log_summary for all performance queries. Otherwise
>>>> we are just guessing.
>>>>     Matt
>>>> My command line is: 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1
>>>>> -st_type sinvert -eps_max_it 5000 -st_ksp_type preonly -st_pc_type lu
>>>>> -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14 100'
>>>>> Kindly let me know.
>>>>> Venkatesh
>>>>> On Sat, May 16, 2015 at 7:10 PM, David Knezevic <
>>>>> david.knezevic at akselos.com> wrote:
>>>>>> On Sat, May 16, 2015 at 8:08 AM, venkatesh g <venkateshgk.j at gmail.com
>>>>>> > wrote:
>>>>>>> Hi,
>>>>>>> I am trying to solving AX=lambda BX eigenvalue problem.
>>>>>>> A and B are of sizes 3600x3600
>>>>>>> I run with this command :
>>>>>>> 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1 -st_type sinvert
>>>>>>> -st_pc_factor_mat_solver_package mumps'
>>>>>>> I get this error: (I get result only when I give 1 or 2 processors)
>>>>>>> Reading COMPLEX matrices from binary files...
>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>> [0]PETSC ERROR: Error in external library!
>>>>>>> [0]PETSC ERROR: Error reported by MUMPS in numerical factorization
>>>>>>> phase: INFO(1)=-9, INFO(2)=2024
>>>>>> The MUMPS error types are described in Chapter 7 of the MUMPS manual.
>>>>>> In this case you have INFO(1)=-9, which is explained in the manual as:
>>>>>> "–9 Main internal real/complex workarray S too small. If INFO(2) is
>>>>>> positive, then the number of entries that are missing in S at the moment
>>>>>> when the error is raised is available in INFO(2). If INFO(2) is negative,
>>>>>> then its absolute value should be multiplied by 1 million. If an error –9
>>>>>> occurs, the user should increase the value of ICNTL(14) before calling the
>>>>>> factorization (JOB=2) again, except if ICNTL(23) is provided, in which case
>>>>>> ICNTL(23) should be increased."
>>>>>> This says that you should use ICTNL(14) to increase the working space
>>>>>> size:
>>>>>> "ICNTL(14) is accessed by the host both during the analysis and the
>>>>>> factorization phases. It corresponds to the percentage increase in the
>>>>>> estimated working space. When significant extra fill-in is caused by
>>>>>> numerical pivoting, increasing ICNTL(14) may help. Except in special cases,
>>>>>> the default value is 20 (which corresponds to a 20 % increase)."
>>>>>> So, for example, you can avoid this error via the following command
>>>>>> line argument to PETSc: "-mat_mumps_icntl_14 30", where 30 indicates that
>>>>>> we allow a 30% increase in the workspace instead of the default 20%.
>>>>>> David
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150518/98168847/attachment-0001.html>
