[petsc-users] MUMPS error
venkatesh g venkateshgk.j at gmail.com
Mon May 18 11:14:26 CDT 2015
I have emailed the mumps-user list.
Actually the cluster has 8 nodes with 16 cores, and other codes scale well.
I wanted to ask if this job takes much time, then if I submit on more
cores, I have to increase the icntl(14).. which would again take long time.
So is there another way ?
cheers,
Venkatesh
On Mon, May 18, 2015 at 7:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, May 18, 2015 at 8:29 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
>> Hi I have attached the performance logs for 2 jobs on different
>> processors. I had to increase the workspace icntl(14) when I submit on more
>> cores since it is failing with small value of icntl(14).
>> 1. performance_log1.txt is run on 8 cores (option given
>> -mat_mumps_icntl_14 200)
>> 2. performance_log2.txt is run on 2 cores (option given
>> -mat_mumps_icntl_14 85  )
> 1) Your number of iterates increased from 7600 to 9600, but that is a
> relatively small effect
> 2) MUMPS is just taking a lot longer to do forward/backward solve. You
> might try emailing
> the list for them. However, I would bet that your system has enough
> bandwidth for 2 procs
> and not much more.
>   Thanks,
>      Matt
>> Venkatesh
>> On Sun, May 17, 2015 at 6:13 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sun, May 17, 2015 at 1:38 AM, venkatesh g <venkateshgk.j at gmail.com>
>>> wrote:
>>>> Hi, Thanks for the information. I now increased the workspace by adding
>>>> '-mat_mumps_icntl_14 100'
>>>> It works. However, the problem is, if I submit in 1 core I get the
>>>> answer in 200 secs, but with 4 cores and '-mat_mumps_icntl_14 100' it takes
>>>> 3500secs.
>>> Send the output of -log_summary for all performance queries. Otherwise
>>> we are just guessing.
>>>     Matt
>>> My command line is: 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1
>>>> -st_type sinvert -eps_max_it 5000 -st_ksp_type preonly -st_pc_type lu
>>>> -st_pc_factor_mat_solver_package mumps -mat_mumps_icntl_14 100'
>>>> Kindly let me know.
>>>> Venkatesh
>>>> On Sat, May 16, 2015 at 7:10 PM, David Knezevic <
>>>> david.knezevic at akselos.com> wrote:
>>>>> On Sat, May 16, 2015 at 8:08 AM, venkatesh g <venkateshgk.j at gmail.com>
>>>>> wrote:
>>>>>> Hi,
>>>>>> I am trying to solving AX=lambda BX eigenvalue problem.
>>>>>> A and B are of sizes 3600x3600
>>>>>> I run with this command :
>>>>>> 'mpiexec -np 4 ./ex7 -f1 a2 -f2 b2 -eps_nev 1 -st_type sinvert
>>>>>> -st_pc_factor_mat_solver_package mumps'
>>>>>> I get this error: (I get result only when I give 1 or 2 processors)
>>>>>> Reading COMPLEX matrices from binary files...
>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>> [0]PETSC ERROR: Error in external library!
>>>>>> [0]PETSC ERROR: Error reported by MUMPS in numerical factorization
>>>>>> phase: INFO(1)=-9, INFO(2)=2024
>>>>> The MUMPS error types are described in Chapter 7 of the MUMPS manual.
>>>>> In this case you have INFO(1)=-9, which is explained in the manual as:
>>>>> "–9 Main internal real/complex workarray S too small. If INFO(2) is
>>>>> positive, then the number of entries that are missing in S at the moment
>>>>> when the error is raised is available in INFO(2). If INFO(2) is negative,
>>>>> then its absolute value should be multiplied by 1 million. If an error –9
>>>>> occurs, the user should increase the value of ICNTL(14) before calling the
>>>>> factorization (JOB=2) again, except if ICNTL(23) is provided, in which case
>>>>> ICNTL(23) should be increased."
>>>>> This says that you should use ICTNL(14) to increase the working space
>>>>> size:
>>>>> "ICNTL(14) is accessed by the host both during the analysis and the
>>>>> factorization phases. It corresponds to the percentage increase in the
>>>>> estimated working space. When significant extra fill-in is caused by
>>>>> numerical pivoting, increasing ICNTL(14) may help. Except in special cases,
>>>>> the default value is 20 (which corresponds to a 20 % increase)."
>>>>> So, for example, you can avoid this error via the following command
>>>>> line argument to PETSc: "-mat_mumps_icntl_14 30", where 30 indicates that
>>>>> we allow a 30% increase in the workspace instead of the default 20%.
>>>>> David
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150518/c25b70b9/attachment.html>
