[petsc-users] SLEPc Bogus eigenvalues for large -eps_nev
Vijay Gopal Chilkuri
vijay.gopal.c at gmail.com
Thu May 14 09:08:00 CDT 2015
I am using SLEPc to get the lowest m eigenvalues of a large sparse
hermitian matrix using Krylov-Schur.
The problem is that while asking for a large number of eigenvalues (e.g.
300) for a large problem
consisting of a 91454220 X 91454220 system, the solver does not give the
lowest 300 eigenvalues.
Instead it gives the following arbitrary negative values followed by a few
correct ones.
-4733.882429 0.999888
> -4729.554413 1.0006
> -4725.841715 0.999887
> -4702.457861 1.00061
> -4700.608105 0.999887
> -4691.142733 0.999885
> -6.361168 1.18973
> -6.361102 6.05898e-09
> -6.361099 6.71e-09
> -6.361093 7.66471e-09
> -6.361082 1.17659
Although the solver says that it has successfully converged the 300
eigenvalues !
Please find the relevant files attached.
Could anyone tell me what I'm doing wrong ?
thanks,
Vijay
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/ed9a9dd1/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/ed9a9dd1/attachment-0001.c>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/ed9a9dd1/attachment-0001.obj>
