[petsc-users] FW: Reg : PETSc Installation
Manish Kumar K
Manishkumar.K at LntTechservices.com
Thu May 14 02:03:12 CDT 2015
Dear PETSc team,
Greetings of the day.
I am facing error while installing PETSc on Windows using Cygwin shell/terminal .
Following is the steps followed for the installation from Cygwin shell
Method 1:
1)cd c:/cygwin64/package/petsc-3.3-p7 //PETSc top level directory
2) ./configure --with-cl=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack --download-mpich //command to configure and install PETSc
I am getting an error on this commands invoked in Cygwin
Error message : C compiler you provided with -with-cc=gcc does not work
Method 2:
./configure --with-cc=cl --with-cxx=g++ --with-fc=gfortran --download-fblaslapack --download-mpich
Error message : C compiler you provided with -with-cc=cl does not work
Method 3:
./configure --with-cc='win32fe cl' --with-fc='win32fe ifort' --with-cxx='win32fe cl' --download-fblaslapack
Error message : C compiler you provided with -with-cc=win32fe cl does not work
I have attached a log file on this
Any help on this would be of great value to me and my customers.
Best Regards
Manish K
L&T Technology Services Ltd
www.LntTechservices.com<http://www.lnttechservices.com/>
This Email may contain confidential or privileged information for the intended recipient (s). If you are not the intended recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/3e9866ba/attachment-0001.html>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/3e9866ba/attachment-0001.obj>
