[petsc-users] SLEPc Eigenvalue problem - Zero Pivot
venkatesh g
venkateshgk.j at gmail.com
Thu May 14 01:52:04 CDT 2015
Hi Jose, all,
I tried that too, it is telling the same error of "Detected Zero pivot in
LU factorization".
My matrix B in AX=lambda BX has large no. of zeros and is singular.
Is there another way ?
Venkatesh
On Wed, May 13, 2015 at 9:02 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 13/05/2015, a las 17:28, venkatesh g escribió:
> > Dear All,
> > I am having a block matrix Eigenvalue problem AX = lambda BX
> > My B is singular, it is a block matrix and only one block has non-zero
> values.
> > Matlab Eigs is giving the result.
> > I am using option: "./ex7 -f1 A1 -f2 B1 -st_type sinvert"
> > Result is: Detected zero pivot in LU factorization.
> > The ex7 is an example from SLEPc.
> > Pls advice what to do ?
> > cheers,
> > Venkatesh
> If you know where your wanted eigenvalues are, set the target value, for
> instance:
> ./ex7 -f1 A1 -f2 B1 -st_type sinvert -eps_target 0.5
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150514/2647ce52/attachment.html>
