[petsc-users] SLEPc Eigenvalue problem - Zero Pivot
Jose E. Roman jroman at dsic.upv.es
Wed May 13 10:32:17 CDT 2015
El 13/05/2015, a las 17:28, venkatesh g escribió:
> Dear All,
> I am having a block matrix Eigenvalue problem AX = lambda BX
> My B is singular, it is a block matrix and only one block has non-zero values.
> Matlab Eigs is giving the result.
> I am using option: "./ex7 -f1 A1 -f2 B1 -st_type sinvert"
> Result is: Detected zero pivot in LU factorization.
> The ex7 is an example from SLEPc.
> Pls advice what to do ?
> cheers,
> Venkatesh
If you know where your wanted eigenvalues are, set the target value, for instance:
./ex7 -f1 A1 -f2 B1 -st_type sinvert -eps_target 0.5
Jose
