[petsc-users] MatMatMult involving MPIAIJ and MATNEST
Matthew Knepley
knepley at gmail.com
Mon May 11 12:00:08 CDT 2015
On Mon, May 11, 2015 at 8:47 AM, Bikash Kanungo <bikash at umich.edu> wrote:
> Hi Patrick,
> Thanks for the clarification. I want it to be an efficient operation. The
> idea is to convert a generalized eigenvalue problem (H*x = lamda*M*x) to a
> standard one (M^{-1}*H*x = lambda*x). The M^{-1} is of type MATNEST whereas
> H is MPIAIJ. In my problem M^{-1} is computed once whereas H changes every
> iteration. So performing low-level matrix multiplication or creating H as
> MATNEST and assembling it from its sub-matrices at every iteration sounds
> inefficient.
You can solve these types of things with SLEPc without explicit MatMat.
Matt
> Regards,
> Bikash
> On Mon, May 11, 2015 at 9:21 AM, Patrick Sanan <patrick.sanan at gmail.com>
> wrote:
>> MatMatMult with MATNEST does not seem to be supported, based only on the
>> fact that there are no functions of the form MatMatMult_*_MatNest defined
>> with the MATNEST implementation :
>> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/nest/matnest.c.html
>> Does this operation need to be efficient? (That is, are you forming this
>> matrix for debugging or experimental purposes, or with the intention of
>> using it within an efficient, scalable piece of code?). If not, it should
>> be possible to use lower-level matrix operations as defined by the API to
>> extract the appropriately-sized submatrices from A and (assuming that
>> MatMatMult is defined between MATMPIAIJ and the submatrices of your
>> Matnest), perform the matrix multiplications and additions "by hand" .
>> On Mon, May 11, 2015 at 2:44 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>>> Hi,
>>> I have two matrices: A of type MPIAIJ and B of type MATNEST. Is there
>>> any way to perform A*B after B has been assembled from its sub-matrices?
>>> Thanks,
>>> Bikash
>>> Bikash S. Kanungo
>>> PhD Student
>>> Computational Materials Physics Group
>>> Mechanical Engineering
>>> University of Michigan
> Bikash S. Kanungo
> PhD Student
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150511/65c363d7/attachment.html>
