[petsc-users] MatMatMult involving MPIAIJ and MATNEST
Bikash Kanungo bikash at umich.edu
Mon May 11 09:18:44 CDT 2015
Thanks Patrick. I'll give it a shot and see if it works.
Bikash
On Mon, May 11, 2015 at 9:52 AM, Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> Ah, so I misunderstood the question - you want to *apply* AB, not assemble
> it. Perhaps you can then use MATCOMPOSITE to define a composite operator
> which applies AB.
> On Mon, May 11, 2015 at 3:47 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>> Hi Patrick,
>> Thanks for the clarification. I want it to be an efficient operation. The
>> idea is to convert a generalized eigenvalue problem (H*x = lamda*M*x) to a
>> standard one (M^{-1}*H*x = lambda*x). The M^{-1} is of type MATNEST whereas
>> H is MPIAIJ. In my problem M^{-1} is computed once whereas H changes every
>> iteration. So performing low-level matrix multiplication or creating H as
>> MATNEST and assembling it from its sub-matrices at every iteration sounds
>> inefficient.
>> Regards,
>> Bikash
>> On Mon, May 11, 2015 at 9:21 AM, Patrick Sanan <patrick.sanan at gmail.com>
>> wrote:
>>> MatMatMult with MATNEST does not seem to be supported, based only on the
>>> fact that there are no functions of the form MatMatMult_*_MatNest defined
>>> with the MATNEST implementation :
>>> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/nest/matnest.c.html
>>> Does this operation need to be efficient? (That is, are you forming this
>>> matrix for debugging or experimental purposes, or with the intention of
>>> using it within an efficient, scalable piece of code?). If not, it should
>>> be possible to use lower-level matrix operations as defined by the API to
>>> extract the appropriately-sized submatrices from A and (assuming that
>>> MatMatMult is defined between MATMPIAIJ and the submatrices of your
>>> Matnest), perform the matrix multiplications and additions "by hand" .
>>> On Mon, May 11, 2015 at 2:44 PM, Bikash Kanungo <bikash at umich.edu>
>>> wrote:
>>>> Hi,
>>>> I have two matrices: A of type MPIAIJ and B of type MATNEST. Is there
>>>> any way to perform A*B after B has been assembled from its sub-matrices?
>>>> Thanks,
>>>> Bikash
>>>> Bikash S. Kanungo
>>>> PhD Student
>>>> Computational Materials Physics Group
>>>> Mechanical Engineering
>>>> University of Michigan
>> Bikash S. Kanungo
>> PhD Student
Bikash S. Kanungo
PhD Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150511/a555ba52/attachment.html>
