[petsc-users] Changing a few entries in a matrix
Matthew Knepley
knepley at gmail.com
Fri May 8 16:15:56 CDT 2015
On Fri, May 8, 2015 at 4:14 PM, Ganesh Vijayakumar <ganesh.iitm at gmail.com>
wrote:
> Hello,
> Thanks. Looks like I could set all the possible entries I'll use to zero
> and selectively overwrite them.
> Can I overwrite any entries without incurring additional cost in memory?
> I currently use MatSetValue with the option INSERT_VALUES? Does Petsc have
> an option to OVERWRITE the existing value?
Here INSERT means the same as overwrite. You only incur costs if you have
not previously set the element.
Natt
> ganesh
> On Fri, May 8, 2015 at 5:10 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Ganesh Vijayakumar <ganesh.iitm at gmail.com> writes:
>> > Hello,
>> > I have a CFD application where some entries of the matrix change every
>> > time step.
>> The entries change value or the set of nonzero entries changes? If the
>> former, just MatSetValues and carry on. If the latter, either allocate
>> for the union of all possible nonzeros (storing some explicit zeros) or
>> reallocate the matrix each time.
>> > However, the total number of non-zero elements never changes. Is there
>> > anyway I can efficiently do this. My current attempts at doing this
>> > results in running over the total initial memory allocation very soon.
>> > ganesh
> ganesh
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150508/6bef4f23/attachment-0001.html>
