[petsc-users] FEM 101
    Matthew Knepley
    knepley at gmail.com
    Mon Mar 30 23:14:18 CDT 2015
On Mon, Mar 30, 2015 at 4:39 PM, Justin Pogacnik <j.pogacnik at auckland.ac.nz>
wrote:
>  Hello,
>  I'm beginning to write a finite element solid mechanics code in F90 and
> am having some problems getting started with finite element basics within
> Petsc. I'm using an unstructured grid and the DMPlex class and able to
> access most of the mesh information required for FE numerical integration.
> I've used PetscFECreateDefault and have found the quadrature point
> locations/data. I'm trying to determine how to find the values of standard
> trilinear basis functions and their derivatives at the element quadrature
> points and then to perform the integration on the element. Can anyone
> advise what the proper routines are that I should call? It's possible that
> I'm way off target. I've seen "PetscFEGetBasisSpace", but I'm unsure what
> to do with the resulting output space. I've also seen the PetscFEIntegrate
> routines, but unsure how their intended to be used and don't see any
> fortran wrappers.
>  I hope this question is clear. Please let me know if you require more
> information. I appreciate any help and guidance that anyone can offer.
Here is the plain vanilla integration routine:
https://bitbucket.org/petsc/petsc/src/1c9d18e7633f5b782021dca6d8727de2838ee261/src/dm/dt/interface/dtfe.c?at=master#cl-3380
which is an implementation of PetscFEIntegrate(). The idea is that this
integrates a bunch of elements, and then there is an outer
loop over the whole mesh, which is currently DMPlexIntegrateResidual().
Unfortunately, this function also does a bunch of other
stuff, and right now I do not see how to simplify it.
Does this make sense?
     Matt
> Many thanks,
>  Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150330/e8846379/attachment.html>
