[petsc-users] Unequal sparse matrix row distribution for MPI MatMult
Steena M
stm8086 at yahoo.com
Sun Mar 29 23:05:06 CDT 2015
Thanks Matt. I used PETSC_DETERMINE but I'm now getting an allocation-based error:
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Argument out of range!
[0]PETSC ERROR: New nonzero at (2,18) caused a malloc!
[0]PETSC ERROR: ------------------------------------------------------------------------
I tried preallocating on each rank for the diagonal and off diagonal section of the matrix as the next step My current approximations for preallocation
CHKERRQ( MatMPIBAIJSetPreallocation(A,1,5,PETSC_DEFAULT,5,PETSC_DEFAULT));
are throwing segmentation errors.
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
Any insights into what I'm doing wrong?
Steena
On Sun, 3/29/15, Matthew Knepley <knepley at gmail.com> wrote:
Subject: Re: [petsc-users] Unequal sparse matrix row distribution for MPI MatMult
To: "Steena M" <stm8086 at yahoo.com>
Cc: "Barry Smith" <bsmith at mcs.anl.gov>, petsc-users at mcs.anl.gov
Date: Sunday, March 29, 2015, 10:02 PM
On Sun, Mar 29, 2015 at
9:56 PM, Steena M <stm8086 at yahoo.com>
wrote:
Hi
Barry,
I am trying to partition a 20 row and 20 col sparse matrix
between two procs such that proc 0 has 15 rows and 20 cols
and proc 1 has 5 rows and 20 cols. The code snippet:
CHKERRQ(MatCreate(PETSC_COMM_WORLD,&A)); //
at runtime: -matload_block_size 1
if (rank ==0)
CHKERRQ( MatSetSizes(A, 15, 20, 20,
20) ); //rank 0 gets 75% of the rows
CHKERRQ( MatSetType(A, MATMPIBAIJ)
CHKERRQ( MatLoad(A,fd) );
else
CHKERRQ( MatSetSizes(A, 5, 20, 20,
20) ); //rank 1 gets 25% of the rows
This throws the following error (probably from psplit.c):
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Nonconforming object sizes!
[1]PETSC ERROR: Sum of local lengths 40 does not equal
global length 20, my local length 20
likely a call to VecSetSizes() or MatSetSizes() is
wrong.
See http://www.mcs.anl.gov/petsc/documentation/faq.html#split!
This error printout doesn't quite make sense to me.
I'm trying to specify a total matrix size of 20x20... I
haven't yet figured out where the '40' comes
from in the error message.
Any thoughts on what might be going wrong?
Its the column specification. Just
use PETSC_DETERMINE for the local columns since all our
sparse matrixformats are row divisions
anyway.
Matt
Thanks in advance,
Steena
On Sun, 3/22/15, Barry Smith <bsmith at mcs.anl.gov>
Cc: petsc-users at mcs.anl.gov
Date: Sunday, March 22, 2015, 3:58 PM
Steena,
I am
a little unsure of your question.
1) you can create a MPIBAIJ
matrix with any distribution of block rows per process
you
want, just set the local row size for each process to
be
what you like. Use MatCreateVecs() to get
correspondingly
laid out vectors.
or 2) if you have a MPIBAIJ
matrix with "equal" row layout and you want a
new
one with uneven row layout you can simply use
MatGetSubMatrix() to create that new matrix.
Barry
Unless you have another reason to have the
matrix with an equal number row layout I would just
generate
the matrix with the layout you want.
> On Mar 22, 2015, at 5:50 PM, Steena M
wrote:
> Hello,
> I need to distribute
a sparse matrix such that each proc owns an unequal
number
of blocked rows before I proceed with MPI MatMult. My
initial thoughts on doing this:
> 1) Use MatGetSubMatrices() on the test
MATMPIBAIJ matrix to produce a new matrix where each
proc
has an unequal number of rows.
> 2) Provide scatter context for vector X
(for MatMult )using IS iscol from MatGetSubMatrices()
while
creating the vector X.
> 3) Call MatMult()
> Will MatMult_MPIBAIJ continue to scatter
this matrix and vector such that each proc will own an
equal
number of matrix rows and corresponding diagonal vector
elements? Should I write my own MPIMatMult function to
retain my redistribution of the matrix and vector?
> Thanks in
advance,
> Steena
What most experimenters
take for granted before they begin their experiments is
infinitely more interesting than any results to which their
experiments lead.
-- Norbert
Wiener
