[petsc-users] Unequal sparse matrix row distribution for MPI MatMult
Matthew Knepley
knepley at gmail.com
Sun Mar 29 22:02:49 CDT 2015
On Sun, Mar 29, 2015 at 9:56 PM, Steena M <stm8086 at yahoo.com> wrote:
> Hi Barry,
> I am trying to partition a 20 row and 20 col sparse matrix between two
> procs such that proc 0 has 15 rows and 20 cols and proc 1 has 5 rows and 20
> cols. The code snippet:
> CHKERRQ(MatCreate(PETSC_COMM_WORLD,&A)); // at runtime:
> -matload_block_size 1
> if (rank ==0)
> CHKERRQ( MatSetSizes(A, 15, 20, 20, 20) ); //rank 0 gets
> 75% of the rows
> CHKERRQ( MatSetType(A, MATMPIBAIJ) );
> CHKERRQ( MatLoad(A,fd) );
> else
> CHKERRQ( MatSetSizes(A, 5, 20, 20, 20) ); //rank 1 gets
> 25% of the rows
> This throws the following error (probably from psplit.c):
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Nonconforming object sizes!
> [1]PETSC ERROR: Sum of local lengths 40 does not equal global length 20,
> my local length 20
> likely a call to VecSetSizes() or MatSetSizes() is wrong.
> See http://www.mcs.anl.gov/petsc/documentation/faq.html#split!
> This error printout doesn't quite make sense to me. I'm trying to specify
> a total matrix size of 20x20... I haven't yet figured out where the '40'
> comes from in the error message.
> Any thoughts on what might be going wrong?
Its the column specification. Just use PETSC_DETERMINE for the local
columns since all our sparse matrix
formats are row divisions anyway.
Matt
> Thanks in advance,
> Steena
> On Sun, 3/22/15, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Subject: Re: [petsc-users] Unequal sparse matrix row distribution for MPI
> MatMult
> To: "Steena M" <stm8086 at yahoo.com>
> Cc: petsc-users at mcs.anl.gov
> Date: Sunday, March 22, 2015, 3:58 PM
> Steena,
> I am
> a little unsure of your question.
> 1) you can create a MPIBAIJ
> matrix with any distribution of block rows per process you
> want, just set the local row size for each process to be
> what you like. Use MatCreateVecs() to get correspondingly
> laid out vectors.
> or 2) if you have a MPIBAIJ
> matrix with "equal" row layout and you want a new
> one with uneven row layout you can simply use
> MatGetSubMatrix() to create that new matrix.
> Barry
> Unless you have another reason to have the
> matrix with an equal number row layout I would just generate
> the matrix with the layout you want.
> > On Mar 22, 2015, at 5:50 PM, Steena M
> wrote:
> > Hello,
> > I need to distribute
> a sparse matrix such that each proc owns an unequal number
> of blocked rows before I proceed with MPI MatMult. My
> initial thoughts on doing this:
> > 1) Use MatGetSubMatrices() on the test
> MATMPIBAIJ matrix to produce a new matrix where each proc
> has an unequal number of rows.
> > 2) Provide scatter context for vector X
> (for MatMult )using IS iscol from MatGetSubMatrices() while
> creating the vector X.
> > 3) Call MatMult()
> > Will MatMult_MPIBAIJ continue to scatter
> this matrix and vector such that each proc will own an equal
> number of matrix rows and corresponding diagonal vector
> elements? Should I write my own MPIMatMult function to
> retain my redistribution of the matrix and vector?
> > Thanks in
> advance,
> > Steena
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150329/c9afc1ec/attachment.html>
