[petsc-users] Load Vec from 1D HDF5 dataset MATT READ THIS	EMAIL!
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Mar 28 22:36:27 CDT 2015
> On Mar 28, 2015, at 10:04 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Mar 28, 2015 at 9:59 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Hakon,
>     I have pushed to the branch barry/feature-hdf5-flexible-initial-dimension and next the change so that Vecs and Vecs obtained from DMCreateGlobalVector() with a DMDA will NOT have the extra dimension if BS == 1. To add that extra dimension even when bs == 1 with VecView() or to handle a file with that extra dimension with VecLoad() one must call PetscViewerHDF5SetBaseDimension2() or -viewer_hdf5_base_dimension2 true
>    Please try it out and let me know if you have any trouble
>    Thanks
>   Barry
>   Matt,
>    Scream as much as you want but adding that extra dimension automatically is not intuitive so it cannot be the default.
> Interfaces should be intuitive,  file formats should be consistent.
  Hakon sent specific examples where, because of the file format, the user interface is extremely non-intuitive (below). A user loading up a "plain old vector" from a file format expects 1 a one dimension beast and that is what we should deliver to them. Now you could argue that the HDF5 interface sucks, because it bleeds the file format through the interface, that could be true, I don't care, that is what we are stuck with.
  Barry
> This gets that entirely wrong.
>    Matt
> > On Mar 25, 2015, at 10:36 AM, Håkon Strandenes <haakon at hakostra.net> wrote:
> > Did you come to any conclusion on this issue?
> > Regards,
> > Håkon
> > On 20. mars 2015 22:02, Håkon Strandenes wrote:
> >> On 20. mars 2015 20:48, Barry Smith wrote:
> >>> Why is 1 dimension a special case that is not worthy of its own
> >>> format? The same thing would hold for 2d and 3d. One could then argue
> >>> that we should have a single six dimensional format for the files for
> >>> all vectors that PETSc produces. Then a 1d problem has five of the
> >>> dimensions being 1.
> >> This is a very good point, and support my view.
> >> Let me come with two very simple example cases:
> >> Case 1:
> >> Create a list of grid points in an external preprocessor for the purpose
> >> of loading this into a Vec later:
> >>   x = np.linspace(0.0, 1.0, num=21)
> >>   f.create_dataset('/MESH/nodes/x', data=x)
> >> vs.
> >>   x = x.reshape((21,1))
> >> Case 2:
> >> Read three Vecs written to disk by PETSc, and calculate total "bounding
> >> box volume" of the grid:
> >>   g = h5py.File('grid.h5', 'r')
> >>   x = g['/MESH/nodes/x']
> >>   y = g['/MESH/nodes/y']
> >>   z = g['/MESH/nodes/z']
> >>   Vol = (xp[-1] - xp[0])*(yp[-1] - yp[0])*(zp[-1] - zp[0])
> >> vs.
> >>   x = g['/MESH/nodes/x'][:,0]
> >>   y = g['/MESH/nodes/y'][:,0]
> >>   z = g['/MESH/nodes/z'][:,0]
> >>   Vol = (x[-1] - x[0])*(y[-1] - y[0])*(z[-1] - z[0])
> >> In both cases I think handling this extra, unnecessary dimension makes
> >> the code less attractive. It's not that either way is difficult,
> >> problematic or impossible, but it's just that 1D Vecs should intuitively
> >> be 1D datasets, and not 2D, 3D or 6D. This seriously confused me for
> >> quite a while until I figured this out, even after having written an
> >> entire Navier-Stokes DNS solver using the PETSc library for everything
> >> except time integration and filling these simple 1D coordinate arrays!
> >> Regards,
> >> Håkon
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
