[petsc-users] Load Vec from 1D HDF5 dataset MATT READ THIS EMAIL!
Matthew Knepley
knepley at gmail.com
Sat Mar 28 22:04:09 CDT 2015
On Sat, Mar 28, 2015 at 9:59 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Hakon,
> I have pushed to the branch
> barry/feature-hdf5-flexible-initial-dimension and next the change so that
> Vecs and Vecs obtained from DMCreateGlobalVector() with a DMDA will NOT
> have the extra dimension if BS == 1. To add that extra dimension even when
> bs == 1 with VecView() or to handle a file with that extra dimension with
> VecLoad() one must call PetscViewerHDF5SetBaseDimension2() or
> -viewer_hdf5_base_dimension2 true
> Please try it out and let me know if you have any trouble
> Thanks
> Barry
> Matt,
> Scream as much as you want but adding that extra dimension
> automatically is not intuitive so it cannot be the default.
Interfaces should be intuitive, file formats should be consistent. This
gets that entirely wrong.
Matt
> > On Mar 25, 2015, at 10:36 AM, Håkon Strandenes <haakon at hakostra.net>
> wrote:
> > Did you come to any conclusion on this issue?
> > Regards,
> > Håkon
> > On 20. mars 2015 22:02, Håkon Strandenes wrote:
> >> On 20. mars 2015 20:48, Barry Smith wrote:
> >>> Why is 1 dimension a special case that is not worthy of its own
> >>> format? The same thing would hold for 2d and 3d. One could then argue
> >>> that we should have a single six dimensional format for the files for
> >>> all vectors that PETSc produces. Then a 1d problem has five of the
> >>> dimensions being 1.
> >> This is a very good point, and support my view.
> >> Let me come with two very simple example cases:
> >> Case 1:
> >> Create a list of grid points in an external preprocessor for the purpose
> >> of loading this into a Vec later:
> >> x = np.linspace(0.0, 1.0, num=21)
> >> f.create_dataset('/MESH/nodes/x', data=x)
> >> vs.
> >> x = x.reshape((21,1))
> >> Case 2:
> >> Read three Vecs written to disk by PETSc, and calculate total "bounding
> >> box volume" of the grid:
> >> g = h5py.File('grid.h5', 'r')
> >> x = g['/MESH/nodes/x']
> >> y = g['/MESH/nodes/y']
> >> z = g['/MESH/nodes/z']
> >> Vol = (xp[-1] - xp[0])*(yp[-1] - yp[0])*(zp[-1] - zp[0])
> >> vs.
> >> x = g['/MESH/nodes/x'][:,0]
> >> y = g['/MESH/nodes/y'][:,0]
> >> z = g['/MESH/nodes/z'][:,0]
> >> Vol = (x[-1] - x[0])*(y[-1] - y[0])*(z[-1] - z[0])
> >> In both cases I think handling this extra, unnecessary dimension makes
> >> the code less attractive. It's not that either way is difficult,
> >> problematic or impossible, but it's just that 1D Vecs should intuitively
> >> be 1D datasets, and not 2D, 3D or 6D. This seriously confused me for
> >> quite a while until I figured this out, even after having written an
> >> entire Navier-Stokes DNS solver using the PETSc library for everything
> >> except time integration and filling these simple 1D coordinate arrays!
> >> Regards,
> >> Håkon
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150328/a9137afd/attachment.html>
