[petsc-users] Mixed matrices MatMatMult
    Matthew Knepley
    knepley at gmail.com
    Thu Mar 26 17:05:18 CDT 2015
On Thu, Mar 26, 2015 at 4:06 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>
wrote:
>  Ok,
> this work is still part of my Schur complement approach using the full
> schur but with a block diagonal A00^-1.
> I implemented the computation of A00^-1 by extracting each diagonal block
> and inverting them individually.
> This works quite well and does not cost some much, especially since I can
> still use threads to accelerate this process (I might send a question about
> this in the future...).
> At the moment the most expensive part of the procedure is inverting S (I'm
> using LU at the moment to make sure that everything is implemented
> correctly) and the second most expensive procedure is MatMatMult. I'm doing
> two of these: A10 * A00^-1 and then a right multiplication by A01.
> Decreasing that cost would be nice (I attached the output of -log_summary
> for reference).
> I think I need to look for the objects that are not Destroyed too.
We will look, but this is a notoriously hard thing to speed up. You might
try the RAP code instead.
Finally I now would like to split the Schur complement into two
> submatrices. I have an IS that tracks location of these sub-matrices in the
> global system:
>        [ A00  A01  A02 ]  --> IS(0)
> A = [ A10  A11  A12 ]  --> IS(1)
>        [ A20  A21  A22 ]  --> IS(2)
> How can I use IS(1) and IS(2) to track:
> S =   [ A11  A12 ]  _  [ A10] * [A00]^-1 * [ A01 A02 ]  = [ S11  S12 ]
> --> IS(1)'
>          [ A21  A22 ]     [ A20]
> = [ S21  S22 ]  --> IS(2)'
> or is there a simple way to compute IS(1)' and IS(2)' based on IS(1) and
> IS(2)?
Aren't they identical?
     Matt
> Thanks!
> Best,
> Luc
> On 03/26/2015 04:12 PM, Matthew Knepley wrote:
>  On Thu, Mar 26, 2015 at 3:07 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>
> wrote:
>> Hi all,
>> I want to multiply two matrices together, one is MATAIJ and the second is
>> MATBAIJ, is there a way to leverage the properties of the blocked matrix in
>> the BAIJ format or should I just assemble the BAIJ matrix as AIJ?
>  I am afraid you are currently stuck with the latter.
>    Thanks,
>      Matt
>> Best,
>> Luc
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150326/17b1ed5d/attachment.html>
