[petsc-users] Mixed matrices MatMatMult
Luc Berger-Vergiat lb2653 at columbia.edu
Thu Mar 26 16:06:55 CDT 2015
Ok,
this work is still part of my Schur complement approach using the full
schur but with a block diagonal A00^-1.
I implemented the computation of A00^-1 by extracting each diagonal
block and inverting them individually.
This works quite well and does not cost some much, especially since I
can still use threads to accelerate this process (I might send a
question about this in the future...).
At the moment the most expensive part of the procedure is inverting S
(I'm using LU at the moment to make sure that everything is implemented
correctly) and the second most expensive procedure is MatMatMult. I'm
doing two of these: A10 * A00^-1 and then a right multiplication by A01.
Decreasing that cost would be nice (I attached the output of
-log_summary for reference).
I think I need to look for the objects that are not Destroyed too.
Finally I now would like to split the Schur complement into two
submatrices. I have an IS that tracks location of these sub-matrices in
the global system:
        [ A00  A01  A02 ]  --> IS(0)
A = [ A10  A11  A12 ]  --> IS(1)
        [ A20  A21  A22 ]  --> IS(2)
How can I use IS(1) and IS(2) to track:
S =   [ A11  A12 ]  _  [ A10] * [A00]^-1 * [ A01 A02 ]  = [ S11  S12 ]
--> IS(1)'
          [ A21  A22 ]     [
A20]                                          = [ S21  S22 ]  --> IS(2)'
or is there a simple way to compute IS(1)' and IS(2)' based on IS(1) and
IS(2)?
Thanks!
Best,
Luc
On 03/26/2015 04:12 PM, Matthew Knepley wrote:
> On Thu, Mar 26, 2015 at 3:07 PM, Luc Berger-Vergiat
> <lb2653 at columbia.edu <mailto:lb2653 at columbia.edu>> wrote:
>     Hi all,
>     I want to multiply two matrices together, one is MATAIJ and the
>     second is MATBAIJ, is there a way to leverage the properties of
>     the blocked matrix in the BAIJ format or should I just assemble
>     the BAIJ matrix as AIJ?
> I am afraid you are currently stuck with the latter.
>   Thanks,
>     Matt
>     Best,
>     Luc
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150326/74911791/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150326/74911791/attachment-0001.bin>
