[petsc-users] petsc4py: Passing command line switches
    Florian Lindner
    mailinglists at xgm.de
    Thu Mar 26 07:32:05 CDT 2015
Am Donnerstag, 26. März 2015, 13:59:33 schrieb Lisandro Dalcin:
> On 25 March 2015 at 18:34, Matthew Knepley <knepley at gmail.com> wrote:
> > That file is obviously old and was removed.
> After installing petsc4py, you can do "make docs" in the top level
> source tree, and the docs/ directory will be populated. For this to
> work, you need sphinx and epydoc installed.
> > Lisandro, are we generating documentation somewhere?
> Two places:
> + http://petsc4py.readthedocs.org/ - This does not contain the
> epydoc-generated API reference. I'm not sure if setting up readthedocs
> to use epydoc is ever possible.
> + https://pythonhosted.org/petsc4py/,  - It is for the last release,
> not the in-development version.
Great, that is exactly what I was looking for!
