[petsc-users] SLEPc - Generalized symmetric eigenproblem using ARPACK
Harshad Sahasrabudhe harshad.sahasrabudhe at gmail.com
Wed Mar 25 15:47:39 CDT 2015
> With MUMPS you should not get spurious eigenvalues.
I get only a few spurious eigenvalues when using MUMPS with ARPACK, but the
eigenvectors are definitely wrong.
Did you try the krylovschur solver?
Yes, Krylov-Schur gives me correct results.
How do you know the eigenvalues are wrong?
I'm testing my implementation of Schrodinger equation solver with a 3D
harmonic oscillator potential. I'm getting correct results using FEAST and
krylovschur solvers.
Are you setting problem type to GHEP?
Yes
On Wed, Mar 25, 2015 at 4:37 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 25/03/2015, a las 21:29, Harshad Sahasrabudhe escribió:
> > Hi,
> > I'm trying to use the ARPACK interface in SLEPc for calculating smallest
> eigenvalues with eigenvectors of a generalized eigenproblem. The matrices
> are symmetric.
> > What are the suggested linear solvers/preconditioners for this type of a
> system when using ARPACK? I am using shift and invert with a shift of 0.
> > I get a lot of spurious eigenvalues when I use GMRES linear solver or
> MUMPS for LU factorization. Chebyshev doesn't seem to converge (I don't
> have a good guess for the higher end of eigenvalues).
> > Thanks,
> > Harshad
> With MUMPS you should not get spurious eigenvalues. Did you try the
> krylovschur solver? How do you know the eigenvalues are wrong? Are you
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150325/7b3fbc57/attachment-0001.html>
