[petsc-users] saving views as images
Theler German Guillermo gtheler at cites-gss.com
Tue Mar 10 10:30:20 CDT 2015
On Sat, 2015-03-07 at 15:51 -0600, Barry Smith wrote:
>  Did you follow the directions in the manual page for PetscDrawSetSave()?
>  "Requires that PETSc be configured with the option --with-afterimage to save the images and ffmpeg must be in your path to make the movie"
Yes. For some reason configure does not find libAfterImage in Debian's
default location, but it works if I provide both with-afterimage-lib and
with-afterimage-include. Debian Jessie provides packages
libafterimage-dev and libafterimage0, both marked as version 2.2.12-3.
gtheler at blinky:~/libs/petsc-3.5.3$ ./configure
--with-afterimage-lib=/usr/lib/x86_64-linux-gnu/libAfterImage.so
--with-afterimage-include=/usr/include/libAfterImage
             Configuring PETSc to compile on your
system
TESTING: alternateConfigureLibrary from
PETSc.packages.petsc4py(config/PETSc/packages/petsc4py.py:74)
Compilers:
  C Compiler:         mpicc  -fPIC -Wall -Wwrite-strings
-Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
  C++ Compiler:       mpicxx  -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -g -O0   -fPIC
  Fortran Compiler:   mpif90  -fPIC -Wall -Wno-unused-variable
-ffree-line-length-0 -Wno-unused-dummy-argument -g -O0
Linkers:
  Shared linker:   mpicc  -shared  -fPIC -Wall -Wwrite-strings
  Dynamic linker:   mpicc  -shared  -fPIC -Wall -Wwrite-strings
make:
MPI:
  Includes: -I/usr/include/mpich
BLAS/LAPACK: -llapack -lblas
cmake:
X:
  Library:  -lX11
pthread:
  Library:  -lpthread
ssl:
  Library:  -lssl -lcrypto
afterimage:
  Includes: -I/usr/include/libAfterImage
  Library:  -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -lAfterImage
valgrind:
  Arch:
PETSc:
  PETSC_ARCH: arch-linux2-c-debug
  PETSC_DIR: /home/gtheler/libs/petsc-3.5.3
  Clanguage: C
  shared libraries: enabled
  Scalar type: real
  Precision: double
  Memory alignment: 16
xxx=========================================================================xxx
 Configure stage complete. Now build PETSc libraries with (gnumake
build):
   make PETSC_DIR=/home/gtheler/libs/petsc-3.5.3
PETSC_ARCH=arch-linux2-c-debug all
Now, consider the attached source file (based on
mat/examples/tutorials/ex16.c). It does compile and gets linked to
libAfterImage:
gtheler at blinky:~/codigos/mat2img$ make
mpicc -c -o mat2img.o mat2img.c -Wall
-I/home/gtheler/libs/petsc-3.5.3/include
-I/home/gtheler/libs/petsc-3.5.3/arch-linux2-c-debug/include
-I/usr/include/libAfterImage -I/usr/include/mpich
mpicc -o mat2img mat2img.o
-Wl,-rpath,/home/gtheler/libs/petsc-3.5.3/arch-linux2-c-debug/lib
-L/home/gtheler/libs/petsc-3.5.3/arch-linux2-c-debug/lib  -lpetsc
-llapack -lblas -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -lAfterImage -lX11 -lpthread -lssl -lcrypto
-lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.9
-L/usr/lib/gcc/x86_64-linux-gnu/4.9 -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -lmpichf90 -lgfortran -lm -lgfortran -lm
-lquadmath -lm -lmpichcxx -lstdc++ -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.9
-L/usr/lib/gcc/x86_64-linux-gnu/4.9 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -ldl -lmpich -lopa -lmpl -lrt -lcr -lpthread
-lgcc_s -ldl
gtheler at blinky:~/codigos/mat2img$ ldd mat2img | grep After
        libAfterImage.so.0
=> /usr/lib/x86_64-linux-gnu/libAfterImage.so.0 (0x00007f95bc4b7000)
        libAfterBase.so.0 => /usr/lib/x86_64-linux-gnu/libAfterBase.so.0
(0x00007f95b7ad4000)
However, an empty directory called "test" is created when running the
code:
gtheler at blinky:~/codigos/mat2img$ ./mat2img -info
[0] PetscInitialize(): PETSc successfully started: number of processors
= 1
[0] PetscGetHostName(): Rejecting domainname, likely is NIS
blinky.(none)
[0] PetscInitialize(): Running on machine: blinky
[0] PetscCommDuplicate(): Duplicating a communicator 1140850688
-2080374784 max tags = 536870911
[0] PetscGetFileStat(): System call stat() succeeded on file matrix.bin
[0] PetscTestOwnership(): System call access() succeeded on file
matrix.bin
[0] PetscFileRetrieve(): Found file matrix.bin
[0] PetscGetFileStat(): System call stat() failed on file
matrix.bin.info
[0] PetscFileRetrieve(): Did not find file matrix.bin.info
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
-2080374784
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 20 X 20; storage space: 0
unneeded,58 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is
0
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 3
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows
0)/(num_localrows 20) < 0.6. Do not use CompressedRow routines.
[0] Mat_CheckInode(): Found 20 nodes out of 20 rows. Not using Inode
routines
-2080374784
[0] PetscDrawSetUpColormap_Shared(): Successfully allocated colors
blinky.(none)
[0] PetscPOpen(): Running command :rm -fr matrix matrix.m4v
blinky.(none)
[0] PetscPOpen(): Running command :mkdir matrix
[0] PetscFinalize(): PetscFinalize() called
I cannot find out what I am missing.
>  So you have to install afterimage on your machine and then ./configure PETSc so it knows about it. If you have done all that and PETSc is being linked with the afterimage libraries then run your code with -info and send all the output; it may indicate why the images are not being saved.
>   Barry
> > On Mar 7, 2015, at 3:38 PM, Theler German Guillermo <gtheler at cites-gss.com> wrote:
> > Hi
> > Last week I asked how to dump a matrix structure into an image and Barry kindly pointed me out the  PetscDrawSetSave function. But I cannot figure out how to use it. So far, I can show my matrix structure into an X window with something like
> >    PetscViewerDrawOpen(PETSC_COMM_WORLD, PETSC_NULL, "R", 100, 100, size, size, &viewer);
> >    MatView(milonga.R, viewer);
> > I tried with this snippet of code but had no luck:
> >    PetscViewerDrawGetDraw(viewer, 0, &draw);
> >    PetscDrawFlush(draw);
> >    PetscDrawSetSave(draw, "test.gif", PETSC_FALSE);
> >    PetscDrawSetSaveFinalImage(draw, "test2.gif");
> > The result is that test.gif and test2.gif are created but they are empty directories.
> > What am I missing?
> > jeremy
> > ________________________________
> > Imprima este mensaje sólo si es absolutamente necesario.
> > Para imprimir, en lo posible utilice el papel de ambos lados.
> > El Grupo Sancor Seguros se compromete con el cuidado del medioambiente.
> > ************AVISO DE CONFIDENCIALIDAD************
> > El Grupo Sancor Seguros comunica que:
> > Este mensaje y todos los archivos adjuntos a el son para uso exclusivo del destinatario y pueden contener información confidencial o propietaria, cuya divulgación es sancionada por ley. Si usted recibió este mensaje erróneamente, por favor notifíquenos respondiendo al remitente, borre el mensaje original y destruya las copias (impresas o grabadas en cualquier medio magnético) que pueda haber realizado del mismo. Todas las opiniones contenidas en este mail son propias del autor del mensaje. La publicación, uso, copia o impresión total o parcial de este mensaje o documentos adjuntos queda prohibida.
> > Disposición DNDP 10-2008. El titular de los datos personales tiene la facultad de ejercer el derecho de acceso a los mismos en forma gratuita a intervalos no inferiores a seis meses, salvo que acredite un interés legítimo al efecto conforme lo establecido en el artículo 14, inciso 3 de la Ley 25.326. La DIRECCIÓN NACIONAL DE PROTECCIÓN DE DATOS PERSONALES, Organo de Control de la Ley 25.326, tiene la atribución de atender las denuncias y reclamos que se interpongan con relación al incumplimiento de las normas sobre la protección de datos personales.
Type: text/x-csrc
Desc: mat2img.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150310/45b1d8e5/attachment-0001.c>
Type: text/x-makefile
Desc: makefile
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150310/45b1d8e5/attachment-0002.bin>
Desc: matrix.bin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150310/45b1d8e5/attachment-0003.bin>
