[petsc-users] time stepping questions
Jed Brown
jed at jedbrown.org
Tue Mar 10 09:03:26 CDT 2015
Gideon Simpson <gideon.simpson at gmail.com> writes:
> I had two questions on time stepping routines:
> 1. What’s the proper usage of TSMonitorSolutionBinary? As near as I can tell from source, I need to call:
> PetscViewerBinaryOpen(PETSC_COMM_WORLD, "sim.bin",FILE_MODE_WRITE, &viewer);
> TSMonitorSet(ts, TSMonitorSolutionBinary, viewer,(PetscErrorCode (*)(void**))PetscViewerDestroy);
> I’m guessing it’s necessary to include the PetscViewerDestroy command?
If you created a viewer, you need to destroy it.
> Also, is there a reason why I’m not passing a pointer to the viewer,
> but rather just the view itself?
All PETSc objects are pointers.
ierr = PetscOptionsString("-ts_monitor_solution_binary","Save each solution to a binary file","TSMonitorSolutionBinary",0,monfilename,PETSC_MAX_PATH_LEN,&flg);CHKERRQ(ierr);
if (flg) {
PetscViewer ctx;
if (monfilename[0]) {
ierr = PetscViewerBinaryOpen(PetscObjectComm((PetscObject)ts),monfilename,FILE_MODE_WRITE,&ctx);CHKERRQ(ierr);
ierr = TSMonitorSet(ts,TSMonitorSolutionBinary,ctx,(PetscErrorCode (*)(void**))PetscViewerDestroy);CHKERRQ(ierr);
} else {
ctx = PETSC_VIEWER_BINARY_(PetscObjectComm((PetscObject)ts));
ierr = TSMonitorSet(ts,TSMonitorSolutionBinary,ctx,(PetscErrorCode (*)(void**))NULL);CHKERRQ(ierr);
> 2. Is there a built in way to track the time steps that the TS solver takes? Assuming it’s using adaptivity, this could be variable. I imagine I could use a TSMonitor routine to print it to the screen, but is there some way to get it into a file?
Do you want output from -ts_monitor or -ts_adapt_monitor? The former
takes a filename argument and the latter probably should (instead of
just beeing a boolean).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150310/40e2a71c/attachment.pgp>
