[petsc-users] time stepping questions
Gideon Simpson
gideon.simpson at gmail.com
Tue Mar 10 03:07:42 CDT 2015
I had two questions on time stepping routines:
1. What’s the proper usage of TSMonitorSolutionBinary? As near as I can tell from source, I need to call:
PetscViewerBinaryOpen(PETSC_COMM_WORLD, "sim.bin",FILE_MODE_WRITE, &viewer);
TSMonitorSet(ts, TSMonitorSolutionBinary, viewer,(PetscErrorCode (*)(void**))PetscViewerDestroy);
I’m guessing it’s necessary to include the PetscViewerDestroy command? Also, is there a reason why I’m not passing a pointer to the viewer, but rather just the view itself?
2. Is there a built in way to track the time steps that the TS solver takes? Assuming it’s using adaptivity, this could be variable. I imagine I could use a TSMonitor routine to print it to the screen, but is there some way to get it into a file?
-gideon
