[petsc-users] pesc4py setValue of dense matrix segfaults
Miroslav Kuchta
mirok at math.uio.no
Mon Mar 9 10:59:20 CDT 2015
Thanks, that helped.
MK
On 03/09/2015 04:37 PM, Jed Brown wrote:
> Miroslav Kuchta <mirok at math.uio.no> writes:
>> Hi everyone,
>> I have a problem when setting values of a dense matrix with petsc4py. The minimal example is
>> import petsc4py
>> petsc4py.init()
>> from petsc4py import PETSc
>> mat = PETSc.Mat()
>> mat.createAIJ(size=(2, 2))
> Add mat.setUp() here if you are not going to preallocate. Of course we
> should be able to produce a better error message in this case.
>> mat.setValue(0, 0, 1) # Crash here
>> mat.assemble()
>> print mat.getValues([0, 1], [0, 1])
>> This works nicely with version 3.4 but using version 3.5 I get
>> [mirok at nefele src]$ python petsc4py_bug.py
>> [0]PETSC ERROR: ------------------------------------------------------------------------
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>> [0]PETSC ERROR: to get more information on the crash.
>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>> Can you point out what is going wrong? Thanks for your help.
>> Regards, Miro
