[petsc-users] Near nullspace for preconditioners other than GAMG?
David Knezevic david.knezevic at akselos.com
Sun Mar 8 10:38:35 CDT 2015
On Sun, Mar 8, 2015 at 10:31 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> Another situation I've been meaning to ask about: If the elasticity model
>> includes some "near rigid" regions (very high Young's modulus)
> Do you mean Poisson ratio?
No, just high Young's modulus in subregions. Engineers sometimes implement
a rotation boundary condition about a node by including rigid (or, in
practice, very high Young's modulus) parts in a model. For example, imagine
including a rigid pyramid in a model, in which the tip of the pyramid is is
clamped so that the base of the pyramid (which is connected to a surface in
the model) can rotate about the tip.
This works fine with a direct solver, so I was curious about getting a good
iterative solver for this case too.
> Nearly incompressible is hard.  bigger smoothers, like ASM, can help.
Agreed. But the Poisson ratio is still just 0.3 or so in this context, so
locking and near incompressibility aren't an issue here.
David
> On Sat, Mar 7, 2015 at 5:57 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> FYI, stüben used classical AMG for elasticity but he has articulated his
>> code for elasticity more than Hypre as I understand it.  Hypre can work OK
>> for elasticity in my experience.  Its worth a try.
>> Mark
>> On Thu, Mar 5, 2015 at 5:27 PM, David Knezevic <
>> david.knezevic at akselos.com> wrote:
>>> OK, got it, thanks!
>>> David
>>> On Thu, Mar 5, 2015 at 5:08 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>> David Knezevic <david.knezevic at akselos.com> writes:
>>>> > I was just wondering if its possible to achieve the same sort of
>>>> thing with
>>>> > other AMG solvers (e.g. BoomerAMG)? I assume that MatSetNearNullSpace
>>>> does
>>>> > nothing for external solvers like hypre, right?
>>>> It is used by ML (smoothed aggregation), but not BoomerAMG (classical
>>>> AMG) which uses an algorithm that doesn't have a natural place for such
>>>> information.  To my knowledge, classical AMG is not widely used for
>>>> elasticity.  It is very robust for M-matrices.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150308/7bf6e97c/attachment.html>
