[petsc-users] Near nullspace for preconditioners other than GAMG?
Mark Adams
mfadams at lbl.gov
Sun Mar 8 09:31:55 CDT 2015
On Sat, Mar 7, 2015 at 6:27 PM, David Knezevic <david.knezevic at akselos.com>
wrote:
> OK, thanks for letting me know.
> I've tried GAMG and ML with MatNullSpaceCreateRigidBody and those both
> work well for me. (I tried ML after Jed pointed out that ML also uses the
> near nullspace.)
> I have also tried hypre but the convergence hasn't been as good for the
> elasticity models I've been using, though I may not have been setting the
> hypre options in an optimal way for elasticity.
As Jed said, SA should be better for elasticity but it is worth testing.
> Another situation I've been meaning to ask about: If the elasticity model
> includes some "near rigid" regions (very high Young's modulus)
Do you mean Poisson ratio? Nearly incompressible is hard. bigger
smoothers, like ASM, can help.
> all iterative solvers I've tried fare poorly. I guess it's because the
> highly contrasting stiffnesses give a large condition number. Is there a
> standard way to get the preconditioner compensate for this?
> Thanks,
> David
> On Sat, Mar 7, 2015 at 5:57 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> FYI, stüben used classical AMG for elasticity but he has articulated his
>> code for elasticity more than Hypre as I understand it. Hypre can work OK
>> for elasticity in my experience. Its worth a try.
>> Mark
>> On Thu, Mar 5, 2015 at 5:27 PM, David Knezevic <
>> david.knezevic at akselos.com> wrote:
>>> OK, got it, thanks!
>>> David
>>> On Thu, Mar 5, 2015 at 5:08 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>> David Knezevic <david.knezevic at akselos.com> writes:
>>>> > I was just wondering if its possible to achieve the same sort of
>>>> thing with
>>>> > other AMG solvers (e.g. BoomerAMG)? I assume that MatSetNearNullSpace
>>>> does
>>>> > nothing for external solvers like hypre, right?
>>>> It is used by ML (smoothed aggregation), but not BoomerAMG (classical
>>>> AMG) which uses an algorithm that doesn't have a natural place for such
>>>> information. To my knowledge, classical AMG is not widely used for
>>>> elasticity. It is very robust for M-matrices.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150308/85d819ba/attachment.html>
