[petsc-users] Multigrid preconditioning of entire linear systems for discretized coupled multiphysics problems
Mon Mar 2 17:32:09 CST 2015
On Mon, Mar 2, 2015 at 5:29 PM, Jed Brown <jed at jedbrown.org> wrote:
> Fabian Gabel <gabel.fabian at gmail.com> writes:
> > Dear PETSc Team,
> > I came across the following paragraph in your publication "Composable
> > Linear Solvers for Multiphysics" (2012):
> > "Rather than splitting the matrix into large blocks and
> > forming a preconditioner from solvers (for example, multi-
> > grid) on each block, one can perform multigrid on the entire
> > system, basing the smoother on solves coming from the tiny
> > blocks coupling the degrees of freedom at a single point (or
> > small number of points). This approach is also handled in
> > PETSc, but we will not elaborate on it here."
> > How would I use a multigrid preconditioner (GAMG)
> The heuristics in GAMG are not appropriate for indefinite/saddle-point
> systems such as arise from Navier-Stokes.  You can use geometric
> multigrid and use the fieldsplit techniques described in the paper as a
> smoother, for example.
> > from PETSc on linear systems of the form (after reordering the
> > variables):
> > [A_uu   0     0   A_up  A_uT]
> > [0    A_vv    0   A_vp  A_vT]
> > [0      0   A_ww  A_up  A_wT]
> > [A_pu A_pv  A_pw  A_pp   0  ]
> > [A_Tu A_Tv  A_Tw  A_Tp  A_TT]
> > where each of the block matrices A_ij, with i,j \in {u,v,w,p,T}, results
> > directly from a FVM discretization of the incompressible Navier-Stokes
> > equations and the temperature equation. The fifth row and column are
> > optional, depending on the method I choose to couple the temperature.
> > The Matrix is stored as one AIJ Matrix.
If you have an unstructured grid, we have examples using regular refinement
and GMG. We are working towards having irregular refinement using the
Pragmatic library from ICL.
     Matt
> > Regards,
> > Fabian Gabel
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150302/27cff010/attachment.html>
