[petsc-users] Multigrid preconditioning of entire linear systems for discretized coupled multiphysics problems
Jed Brown
jed at jedbrown.org
Mon Mar 2 17:29:49 CST 2015
Fabian Gabel <gabel.fabian at gmail.com> writes:
> Dear PETSc Team,
> I came across the following paragraph in your publication "Composable
> Linear Solvers for Multiphysics" (2012):
> "Rather than splitting the matrix into large blocks and
> forming a preconditioner from solvers (for example, multi-
> grid) on each block, one can perform multigrid on the entire
> system, basing the smoother on solves coming from the tiny
> blocks coupling the degrees of freedom at a single point (or
> small number of points). This approach is also handled in
> PETSc, but we will not elaborate on it here."
> How would I use a multigrid preconditioner (GAMG)
The heuristics in GAMG are not appropriate for indefinite/saddle-point
systems such as arise from Navier-Stokes. You can use geometric
multigrid and use the fieldsplit techniques described in the paper as a
smoother, for example.
> from PETSc on linear systems of the form (after reordering the
> variables):
> [A_uu 0 0 A_up A_uT]
> [0 A_vv 0 A_vp A_vT]
> [0 0 A_ww A_up A_wT]
> [A_pu A_pv A_pw A_pp 0 ]
> [A_Tu A_Tv A_Tw A_Tp A_TT]
> where each of the block matrices A_ij, with i,j \in {u,v,w,p,T}, results
> directly from a FVM discretization of the incompressible Navier-Stokes
> equations and the temperature equation. The fifth row and column are
> optional, depending on the method I choose to couple the temperature.
> The Matrix is stored as one AIJ Matrix.
> Regards,
> Fabian Gabel
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150302/1de99dff/attachment.pgp>
