[petsc-users] working with petsc-dev
Tabrez Ali stali at geology.wisc.edu
Sun Mar 1 12:09:19 CST 2015
OK Thanks. Yes, I wont be pulling often. Once a month should be more
than enough. I just wanted to make sure about the need for a complete
reconf.
T
On 03/01/2015 11:49 AM, Barry Smith wrote:
>    It depends on how much has been changed in the repository since you pulled last. It may be a simple make is enough or it may be that a complete clear and rebuild is required. Unfortunately it is not possible to know, thus it is only safe to do a complete reconfigure. Note that unless you are pulling to get a specific new feature that was added there probably isn't a reason to git pull all that often (certainly not daily) maybe every couple of weeks or even once a month.
>     Barry
>> On Mar 1, 2015, at 11:42 AM, Tabrez Ali <stali at geology.wisc.edu> wrote:
>> Hello
>> When working with the development version of PETSc what exactly should I do each time I perform "git pull"?
>> Can I simply run make all or do I have to run make distclean and reconfigure/rebuild everything from scratch (so that external packages are also updated as needed).
>> Thanks in advance.
>> T
