[petsc-users] preprocessing problem
    W. Miah
    wadud.miah at gmail.com
    Tue Jun 30 17:33:20 CDT 2015
Hi Satish,
Thanks for the Makefile.
Wadud.
On 30 June 2015 at 23:20, Satish Balay <balay at mcs.anl.gov> wrote:
> Where did you grab this example from? the 'makefile' should be in the
> same location.
> For eg: if you grabbed src/ksp/ksp/examples/tutorials/ex2f.F - then you would use:
> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/makefile
> The users manual has a section explaining the format.
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manual.pdf#subsection.16.2.1
> Satish
> On Tue, 30 Jun 2015, W. Miah wrote:
>> Hi Satish,
>> I can't find the Makefile that came with it. I'll have a trawl through
>> the petsc download again, but if you could give me the compilation
>> line that would be appreciated.
>> Best regards,
>> Wadud.
>> >> Hi,
>> >> This is probably a simple mistake, but I am getting the following
>> >> error when trying to compile a Fortran PETSc example:
>> >> [host petsc-examples]$ mpiifort -c -I/home/fcwm/petsc-3.6.0/include
>> >> -I/home/fcwm/petsc-3.6.0/include/petsc ex2f.F
>> >> ex2f.F(82): error #5082: Syntax error, found ',' when expecting one
>> >> of: ( % [ : . = =>
>> >>       Vec        x,b,u
>> >> Any help will be greatly appreciated. Thanks in advance.
>> > Are you not using the correspoding makefile that came with this example?
>> > Satish
email:   wadud.miah at gmail.com
mobile: 07905 755604
gnupg: 2E29 B22F
