[petsc-users] DMDASetInterpolationType
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Jun 26 13:39:54 CDT 2015
  We don't currently have a "setter" allowing you to overwrite the function pointer.
  The easiest thing for you to do is "fix" the DMDA_Q0 to handle also handle periodic boundary conditions. It is DMCreateInterpolation_DA_2D_Q0() or 1d or 3d in src/dm/impls/da then send us a patch or make a pull request and we'll stick it in the development copy.
   Barry
> On Jun 26, 2015, at 1:20 PM, Michele Rosso <mrosso at uci.edu> wrote:
> Hi,
> I am wondering if there is a way to use a custom interpolation routine for DMDA.
> The reason is that DMDA_Q0 does not support periodic BCs and I need that.
> Thanks,
> Michele
